Sugestions for a house lantern
I second that, as long as you have enough flashlights.
Diffuers are not great, though they are the most budget-friendly option.
LT1 is great but quite expensive, especially if you need several.
LT1 in the living room with flashlights elsewhere would be a fine and moderately priced choice.
If you have a powerbank and would like to use it for illumination,
string lights like Page Not Found - Aliexpress.com are a good option.
I have quite a few LED lanterns which I’ve bought over the years. Sadly, some of my favorites (Fenix CL20) aren’t made anymore. I’m a fan of the Mr. Beams MB480 lanterns. Runs for 30 hours (high) on 3 D cells. It’s best attribute is the lovely 4000K neutral white light it puts out. It feels far more cozy than the cheap, nasty blue-white lanterns you’ll find everywhere else. And when the price is right, they’re under $20.
I did order the BLF LT1s, but I haven’t received them yet…and for the occasional user they’re overkill.
@FollowspotDude
The LT1 is a bit overkill BUT they are very nice :frowning: :frowning:
if you have other flashlights and the ceiling reflection is not enough use translucent white plastic/paper/yogurt cup/… to diffuse the light
I am familiar with your problem. There is often a power outage in my area. Our power grids are very vulnerable, primarily due to natural phenomena. Only recently, I found the President’s National Infrastructure Advisory Council’s report on “Surviving a Catastrophic Power Outage” (released in December 2018). The information doesn’t provide new explanations but only highlights the problems. I put all the necessary things in a box in case of a power outage. I’m happy with my led lanterns by Vont. These lights hold a reasonable charge and run on batteries. If you put it in the house, it illuminates the whole room. They are safe and solid, a good option.
2000k Fireflies Nov-MU with its diffusion lampshade on is basically a candle. You can even program anduril into candle mode for that subtle candle flicker effect. Very efficient buck driver, especially with the 21x e21a array.
You need 1 lantern for each room of the house, and at least 2 flashlights per room as backups. If you don’t have this many, you are not a flashaholic. :smiley:
My BLF Q8 makes a fabulous ceiling bouncer at about 1/2 power. The Sofirn SP36 will do nicely, too.
here is a diffuser link:
it is what i use.
I use my sp36 with something like: Amazon.com
I use this setup when fishing to make a makeshift lantern. Works pretty good actually.
I have been using 3D printed diffusers/stands.
I’ve got an LT1 and usually buy a diffuser if I get a higher power light. Figure it will run longer on lower modes, for longer outages.
Got a Sofirn SP36pro with diffuser and getting an Astrolux MF01 with diffuser soon.
Now just need the power to go out…….
Not!!!
Sofirn LT1 is a good choice ! BRIGHT & LONG-LASTING lantern CLICK TO CHECK
Came across this today. Don’t know anything about it. Batteries don’t appear to be removable which would be a deal killer for me.
I have recently refreshed my house yard with a few lanterns so might be able to help you. But first, what's your budget?
https://estimationfrancaise.fr
i recommend a nice lantern like the blf lt1 for the living room and a bunch of these flashlights that look like lightbulbs.
i put a bulb shaped light in each room. lt1 where everyone is congregating. lots of regular flashlights to ceiling bounce in coffee mugs.
https://www.amazon.com/Compact-Included-Backpacking-Hurricane-Emergency/dp/B0777DRJKN/ref=sr_1_2?keywords=battery%2Bcamping%2Blight%2Bbulb&qid=1639681250&sr=8-2&th=1
StreamLight Siege 3D.
Energizer Weathermatic 3D/3AA.
Both more than enough and my power went out for 84 hours during hurricane Irma in ’17.
However, a few Dollar Store 5oz. teacup candles strategically placed in each room did most of the heavy lifting.
Chris
I second the StreamLight Siege 3D. I have the 3AA one as well.
I mentioned the Zanflare T1 above, which came in handy one Christmas when I lost power (whole block fried), which lasted on nice warm-white light at (guessing) half-power all night long, and was just at its last gasp when daylight came.
But I stuck my Wuben E03 (?) with magnetic tail and come-with diffuser, onto the light fixture in the basement above where my cats’ litterbox is, just to let them see where they’re going. One AA on moonlight was more than enough probably for a week if I’d need it.
If you want to light up a kitchen like The Flasholic does, yeah, you’ll need something with more oomf and with more capacity, obviously.
And I got a pair of… Litom?… motion-detecting outdoor solar-lights, which I use downstairs for the cats and me, so it lights up when anyone comes down the stairs. It crokes, I swap the one that’s sunning itself for the one that’s spent, then reverse when that one crokes.
So it depends on what you want to use it for, I guess. Don’t think I can say that there’s THE lantern for everything, but nice variations.
And you can use something like a Q8 as a ceiling-bounce light. Not terribly efficient, but ceiling-bounce works nicely enough, and no harsh shadows.
The original post was Feb 5, 2020. I’m assuming the OP found some LED lanterns by now. Would be interested to know what was picked.
I made mine from a vinegar bottle from WM.
The diffuser came with the light; the orange color is from the switch cover from a cheap light stuffed into the diffuser.
The grommet is a 1/2” top hat.
I live in Florida and the orange does not attract bugs.
I have run it for 36 hours on low with an EBL AA.! !
