【convoy】GT FC40 1800-2000K R9050
6475 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 2 hours 25 min ago
icpart wrote:
I wanted a Black S2+ with metal switch too. But no, it doesn’t have.[…]
Not from Convoy, but check this:
https://www.aliexpress.com/item/33018646981.html
icpart
Last seen: 2 hours 33 min ago
Oops Blushing
I mispronounced. I wanted metal switch with black color, not flashlight color body.
MascaratumB
Oops Blushing
Ok, now I get it! My bad, I understood it wrong Oops
I would ask Simon if can sell you one! The shiny ones are for sale out there, but I am not sure about the black one.
Maverick1947
Maverick1947's picture
Last seen: 22 hours 34 min ago
I wonder if Simon will ever sell a triple S2+… I would love one but don’t have the skills to build it myself.
There’s no replacement for displacement.
alex64
alex64's picture
Last seen: 1 day 7 hours ago
It would be a must have.
Funtastic
Funtastic's picture
Last seen: 4 hours 10 min ago
I think an S21A triple is in the works
Funtastic
Funtastic's picture
Simon Mao wrote:
driver for M21E with KW CULPM1.T/SFT40 in production now
That’s excellent news!!
m47mu74nt
Last seen: 8 hours 24 min ago
Hey! just noticed the presale for 940nm IR S2+ (https://fr.aliexpress.com/item/1005003202811071.html)
I will take it as soon as it is available Hat
Will it work with lighted metal switch ? (https://fr.aliexpress.com/item/1005002370385808.html) : is the driver compatible? and the body ?
Rat
m47mu74nt wrote:
Hello Simon,
Since I modded my Z1 with a 4 LEDs 10W IR emitter … so now I’d like to “know” when it lighten up or turned off (without looking directly at the LEDs which emit a dim red when ON) : could it be possible to get a lighted switch that would fit the Z1?
thank you
How did that light perform ? I need a IR light was looking at the Z1.
Funtastic
Funtastic's picture
Can you show a photo of your modded Z1 with 4x IR?
m47mu74nt
Rat wrote:
m47mu74nt wrote:
Hello Simon,
thank you
Quite nicely Smile going all the way from super floody to the ‘LED’ picture on the subject , got the 4 LED pcb and driver here : https://fr.aliexpress.com/item/32996731684.html
I’m not a big fan of zoomy, and the Z1 is quite bigger than I really need, that’s why a S2+ would be better for me, but I was too lazy for the mod.
yeah, next time I use it Smile
it’s nothing fancy, I had quite some trouble reassembling the head though (the o-ring messed up a few times)
Funtastic
Funtastic's picture
Don’t bother showing me then, no need to take it apart again
Thank you for the link, that’s what I needed.
Funtastic
Funtastic's picture
m47mu74nt wrote:
Quite nicely Smile going all the way from super floody to the ‘LED’ picture on the subject , got the 4 LED pcb and driver here : https://fr.aliexpress.com/item/32996731684.html I’m not a big fan of zoomy, and the Z1 is quite bigger than I really need, that’s why a S2+ would be better for me, but I was too lazy for the mod.
What range roughly are you getting?
Pilotboy
Pilotboy's picture
Last seen: 7 hours 45 min ago
Is there a way of removing the AR coating from the glass on my convoy s2+?
I have the convoy s2+ with the 219b sw45k emitter and I noticed that when I remove the glass, the tint looks slightly better. When lighting up white objects with the glass in place they look a little green, and I suspect it has to do with the AR coating.
Lightbringer
Lightbringer's picture
Last seen: 9 hours 48 min ago
Scrub, scrub, scrub.
Seriously.
Pilotboy
Pilotboy's picture
Seriously.
With what? And how do I not scratch it?
max
max's picture
Last seen: 1 hour 16 min ago
Lots of previous posts on how to remove AR coatings. One of which is what LB just mentioned. I advise you to search.
 max
Lightbringer
Same principle like using a razor to scrape your old registration sticker off your windshield. Glass might be brittle, but it’s incredibly hard. Steel wool works nice, but it’s tedious to do, and you gotta get both sides if it’s coated on both sides, too.
DON’T use sandpaper of any kind, not even fine grit, as that is harder than glass, and will frost it.
I only tried it (steel wool) because I was okay if it’d frost it, as I’d likely be using diffusion film anyway if I wanted a flooder. Wasn’t an S2/S2+, but I vaguely vaguely vaguely recall it was one of the older Sofirn SPs that had AR coating on the glass. Might be mistaken, though.
Anyway, it came out fine, enough so that I can’t even recall which light it was. Ie, not “damn, I ruined the glass on that light…” or anything.
Sit back and veg out watching teevee while doing it, as it’s tedious and takes quite a while.
Pilotboy
Pilotboy's picture
Thanks Lightbringer Beer
Ima get scrubbing!
Rat
Hey Funtastic whats your plans?
I was looking at buying a Z1 and fitting one of those 10w 850nm IR led into it and see how it goes as I think my IR is the weak link with my old scope.
Before I go out and buy a new NV scope for my new Air gun “rabbit hunting”. I would like to try a better IR light on my old trusty Photon XT.
Thx
m47mu74nt
As my IR “sensor” is a cheap mini-“action”-camera, I can’t use it at more than 50 meters (the camera doesn’t show anything useful further): I mainly use it as a very close range flood light
You may get 100-150m, but I can’t tell…
Funtastic
Funtastic's picture
Hmmm, okay, no good for me then. I need something for 300-350m for my store, I was hoping the L21B would be capable, but maybe not.
I wonder if Simon would ever consider the Vscel IR lasers. That’s entirely unfamiliar territory for me though.
Simon Mao
Simon Mao's picture
Last seen: 11 hours 25 min ago
m47mu74nt wrote:
Hey! just noticed the presale for 940nm IR S2+ (https://fr.aliexpress.com/item/1005003202811071.html) I will take it as soon as it is available Hat Will it work with lighted metal switch ? (https://fr.aliexpress.com/item/1005002370385808.html) : is the driver compatible? and the body ?
yes, suitable .
Simon Mao
Simon Mao's picture
i have normal glass lens ,
i can send you some for free in your next parcel if you need it
Rat
Simon
Convoy S12 with IR LED,infrared 850nm when will they be available ?
Can you make me a Z1 850nm also?
“S12 IR”: https://www.aliexpress.com/item/1005003202778007.html?spm=a2g0o.detail.1...
thx
Barkuti
Barkuti's picture
Last seen: 1 day 2 hours ago
Pilotboy wrote:
Is there a way of removing the AR coating from the glass on my convoy s2+? I have the convoy s2+ with the 219b sw45k emitter and I noticed that when I remove the glass, the tint looks slightly better. When lighting up white objects with the glass in place they look a little green, and I suspect it has to do with the AR coating.
max wrote:
Lots of previous posts on how to remove AR coatings. One of which is what Lightbringer just mentioned. I advise you to search.
Are you listening, Simon? I hope you are.
Many people dislikes anti-reflective coatings. I dislike them too. This is because the standard anti-reflective coating used for flashlight lenses is λ/4 MgF2 centered at 550nm, which being centered at 550nm, a frequency of green, boosts this frequency and those around it more than the remaining frequencies in the visible spectrum. This can be seen in the following graph chart at Edmund Optics:
In the above graph it can be clearly seen how the λ/4 MgF2 550nm curve is lowest around 550nm, and goes higher (higher reflection, or less effective) around it. Therefore, the gains of this AR-coating are unbalanced and noticeably screw up the tint and even the CRI of emitters to some extent.
What does this mean? Many customers would buy plain lenses anytime, lenses without anti-reflective coating. Customers of high-CRI lights and emitters, namely.
Hope this is of service.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Viruses DON'T cause diseases, they rather are a consequence of them. Read the book “Béchamp or Pasteur” by Ethel Hume for more information.
trakcon
trakcon's picture
Last seen: 1 hour 48 min ago
Pilotboy wrote:
Seriously.
I use Sunshine Cloths to polish the coatings off.
id30209
id30209's picture
Last seen: 12 min 24 sec ago
I am using JoshK "Delete Green" paint on all Convoy lenses.
Well not all, i have a few without coating.
WTB Titanium 4sevens 2xAA tube
JaredM
JaredM's picture
Last seen: 4 min 35 sec ago
I agree and am willing to buy extra lenses that are either uncoated or that have a green coating. Tint is so important and noticeable to most users while transmission losses are not.
To make things worse, recent AR coatings have been causing magenta artifacts around the periphery of the beam. This is terrible.
Please offer uncoated glass, especially for hi cri lights.
From a cost perspective, I’d rather put the money into better (clearer) glass than coatings.
https://fundrazr.com/osturaband
No affiliation, just a fan.
Lightbringer
Ooh, UCL glass would be soooooo nice!
