As my IR “sensor” is a cheap mini-“action”-camera, I can’t use it at more than 50 meters (the camera doesn’t show anything useful further): I mainly use it as a very close range flood light
You may get 100-150m, but I can’t tell…
Many people dislikes anti-reflective coatings. I dislike them too. This is because the standard anti-reflective coating used for flashlight lenses is λ/4 MgF2 centered at 550nm, which being centered at 550nm, a frequency of green, boosts this frequency and those around it more than the remaining frequencies in the visible spectrum. This can be seen in the following graph chart at Edmund Optics:
In the above graph it can be clearly seen how the λ/4 MgF2 550nm curve is lowest around 550nm, and goes higher (higher reflection, or less effective) around it. Therefore, the gains of this AR-coating are unbalanced and noticeably screw up the tint and even the CRI of emitters to some extent.
What does this mean? Many customers would buy plain lenses anytime, lenses without anti-reflective coating. Customers of high-CRI lights and emitters, namely.
I agree and am willing to buy extra lenses that are either uncoated or that have a green coating. Tint is so important and noticeable to most users while transmission losses are not.
To make things worse, recent AR coatings have been causing magenta artifacts around the periphery of the beam. This is terrible.
Please offer uncoated glass, especially for hi cri lights.
From a cost perspective, I’d rather put the money into better (clearer) glass than coatings.
Above I was speaking about the λ/4 MgF2 550nm, a coating centered in a frequency of green (in the middle of the 400-700nm visible spectrum), which is a common low cost coating. This coating gives lenses a very subtle purplish colour, this is most noticeable when a source of light is seen reflected over its surface, makes it look purple. I am right now looking at an incandescent lightbulb reflected over the lens of an S21A I have at hand, and the bulb indeed looks purplish over the lens.
People is complaining about the effects of the standard anti-reflective coating in flashlight lenses. This is because the anti-reflective coating changes the tint of the beam, raising its Duv because of somewhat more green output. We already have enough green in most production led emitters, this is not what we want.
You said “I will change the blue ar-coating or the red into a green ar-coating”, but what does this mean?
If you change the anti-reflective coating for a different one without knowing the actual effects in the beam tint, how is this going to be a solution?
Plain or uncoated lenses are a known solution. 100% sure.
Yeah, what Barkuti said. If knowingly new AR coating will eliminate Duv raise then it’s ok to change process, otherwise plain and simple uncoated lenses are just perfect.
If Simon wants to endorse some new product, I can understand. But from the perspective of a buyer, a new product must provide a useful, advantageous reason to be.
I could for example say that, if aiming for lenses with a double coating, one could be set at 475nm (at the cyan dip the usual blue pumped white leds have), and the other could be centered at 650nm (to boost reds). I've checked a few led spectograms around here to conclude this (1, 2, 3 and 4). This would cover the visible spectrum a lot better, while a double coating may still be affordable.
Still, plain or uncoated lenses are a sure win. They're also the cheapest ones so, how about some uncoated lenses? ;-)
