Ordered! Thanks for the coupon!
Hi freeme, I’m interested in the SFT40 version. Thanks!
i agree with you, centering was a little tough. Actually the right Height was a little tough to achieve. I am interested to see what people get from this and how well the beam is focused before I order. My started with a dark halo around the hotspot, but now through tirelessly adjusting it is much better but not perfect like my L21a
Pip: ArtieT59:Just an FYI- when I did the Lux test on my ft03 with sft40 (I reflowed and centered myself a couple weeks ago) I got 410,000 cd. This light THROWS with this led.
I’ll second that. I changed the led in mine to the sft40 and it made a huge difference. Mine isn’t even centered well because the mcpcb is off a little but it’s still an incredibly bright light at this price.
Im holding off purchasing for the same reasons. Astrolux shamelessly used an incorrect reflector that wouldn’t tightly focus the 90.2 emitter in these same flashlights. Which means they didn’t even take the time to test pre-production samples before slapping them into these $115 lights. Everyone got screwed on that deal. Lets hope they did better with the STF40.
Yea I will only buy if people report that theirs are perfectly centered or at minimum very well centered. Because I already have one that I put a couple hours into adjusting the reflector for.
Hello, interested in purchasing a FT03/SFT40
Hi, Freeme. Interested in the SFT40 version. Any chance of a 26800 tube version with bundled battery?
I will request for it. Will get back to you in 2 days time.
Thanks Freeme, just bought one
Thanks!
Bought one, thanks for your work freeme!
Code please
Shared!
Code please :+1:
Hi Freeme,
Please check your PMs from yesterday, thanks!
aggalitsas:Hi, Freeme. Interested in the SFT40 version. Any chance of a 26800 tube version with bundled battery?
Would be interested in this combo too.
At this point of time, BG has decided NOT to bundle with 26800 battery or tube, due to limited supply for SFT40 LEDs received.
Will this be available with the 26800 tube?
freeme:I will request for it. Will get back to you in 2 days time.
At this point of time, BG has decide NOT to bundle with 26800 battery or tube, due to limited supply for SFT40 LEDs received.
will34:Will this be available with the 26800 tube?
Mblackes: freeme:I will request for it. Will get back to you in 2 days time.
Ok, then please the code only for the flashlight.
Thanks!
Code for flashlight please.
Since the bundle offer is unavailable as an option at this time can you share the coupon code?
Coupon for 26800 tube. https://budgetlightforum.com/t/-/66576
