Amazon Deal Alerts & Discussion Thread
Nicron N7 w/rotating head $12.99. It's been a little cheaper in the past but not by much. Worked fine as a bump to qualify for free ship for the $15 motion lights posted by will34 above.
https://www.amazon.com/dp/B07FFKJVT1/?coliid=IQSN9TYYRVGZC&colid=192BRNMSPYV29&psc=1&ref_=lv_ov_lig_dp_it#
slmjim
Thanks for the heads up. Just purchased these under counter LED lights. My wife has been asking for LED lighting just like this.
She wanted them for a closet and one under a counter in the kitchen. I’m sure she’ll be happy when they arrive.
Thank you, purchased!
Received the 8 aa/charger deal today. What’s up with the charger? It gets very hot.
I stopped using mine because the batteries were to hot to touch before they were fully charged. I put them in my PowerEx MAHA MH-C9000 charger
and set to charge at 200mAh and they don’t get hot. It wasn’t like I even needed the charger anyway. The upside is all 8 “AA” are good and none were
defective.
Odd. 2 boxes of 4, first box as I listed yesterday all clocked in consistently at about 2050mAH.
Second box this morning (run overnight) showed 1500mAH or less for all 4. Rerunning it from scratch to see if maybe it cut off early or something.
They all stay cool when bulk-charging and when discharging, but get a bit toasty when topping off (the whole –ΔV part).
Followup, yeah, might’ve been only partially charged (ie, sketchy “I’m charged” indicator). They all clocked in about 2050mAH on average, so all is well.
Do yours heat up when charging? One of my chargers which was at .5 amp heated them up and another didn’t . The EBL also heated them up.
Yikes! I got the 2 for deal in august and been using one in my garage since - it's been doing fine, and my son-n-law is using the other. Haven't checked the heat but I don't really leave it on long either.
Yeah, the EBL batteries seem fine… time will only tell if they are capable of a reasonable low self discharge. And who knows if they’ll live for as many charging cycles as claimed. But that charger is a bit suspect. I like the compact size and very readable charging status display, but I’m finding it tends to overcharge cells. I charged an older Eneloop AA on it… got 1.52v. However, I’ve yet to find any cells feeling appreciably warm or hot. The fact that at least a few people here are seeing hot cells means the QC is spotty on this stuff. Figures!
Like I mentioned, at least in my Ope, they stay pretty cool bulk-charging and discharging, but get a little toasty when topping off.
Any experience with this handheld mini cordless chainsaw?
https://m.myvipon.com/#/product/8850968?sl=
checkout AVE on youtube, for tool reviews he opens the box w/ the proper version. they seem useless to me tbh, or at least only useful for very specific cases, which admittedly some people have…
I don’t get it. Why a chainsaw vs a sawzall-type recip?
I’d rather replace a blade to suit (wood, metal, demo, etc.) vs replace a chain, and even then it’s iffy that you’d be able to get any beyond the spare(s) in the kit.
Looks tres kewl, though.
Digital Clamp Meter, Smart T-RMS 6000 Counts Multimeter Voltage Tester Auto-ranging, Measures Current Voltage Temperature Capacitance Resistance Diodes Continuity Duty-Cycle, AC/DC Current
Coupon will save an extra 50% of $35.99.
It has all functions like Uni-T UT210E + temp measurement.
I’ll give it a shot — I’ve only bought 2 DMM in the last few days —— This cheap one was around $16 through Vipon —It’s big though —I’d hate to be hit over the head with it —pretty accurate compared to my Fluke
https://www.amazon.com/gp/product/B08Y5HKF2B
What coupon?
slmjim
Another Poweradd product with 50% off = $130
280Wh/400W power station, has 100W PD input/output and regulated 12V DC output (says 13.3V 10A). That makes it better than the aftime, however the aftime has MPPT input and this one only has PWM, which is not a big deal unless you plan to charge it via solar.
https://www.amazon.com/Portable-78000mAh-Generator-Outdoors-Emergency/dp/B09BJPYC5N
I’m starting to wonder if these are in fact genuine poweradd stuff…
I received my EBL batteries and charger — I went ahead and top them off in m y Powerex Charger —they top off easily —but today when I ran a capacity test they all tested around 2000 mah —- then they all charged up to that same capacity except one — that one cell was still charging after putting 2900 mah in it —- on a battery that size I usually charge at 800-1000 ma — I think thats what’s happening with the supplied charger —- I tried out the EBL charger with some Turnigy batteries and it worked fine
I don’t see a coupon on the Amazon page either… and no results when searching on Vipon
