A mod that’s been devised a long time ago (back in Jan. ’21). Replacing the stock SST40s (6000ºK) with Osram’s CULPM1.TG (HX Boost) in a Sofirn SD01.
I didn’t want to splurge on Convoy’s so I went with YinDing’s which were half price. Initially made a bench test and these are not up to specs. They go angry bluish-white at 8 Amps, but they do work well at about 6½ A.
I tried to measure the tail amps, but in no manner I could get any proper readings. Sofirn SD01 tail amp woes
Then there was the cracking open of this light. Sofirn is renowned for gluing things and I foresaw some problems. The 3 bezels have the smallest of indents and not much stick-out for any wrench. I had ordered a watch cover removing tool, but being of low quality, the metal prongs had to be replaced with some hardened ones. I used the shanks from some broken drills, 7/64” being a common pre-drill for #8 hardwoods.
The driver is readily removable via 3 screws and the board seems well laid out. There are 3 FETs and controlled via the MCU, no sense resistor here, all pre-programmed PWM. Switching via 4 HAL effect transistors, magnetic ring. I can’t figure out if / how the ring can be disassembled.
So they didn’t glue this end, may have a brute shot at the bezels? Well, first try the tool would twist open. So I had to add some retaining screws and trying my best, one did finally give. No glue! That was encouraging, but still a strong man’s test for the next two. After much fiddling and re-working the indents, got them all opened.
So, based on the manufacturer’s specs, the SST40 would have a Vf = 3.3 at 5 A. and the HX = 3.35 at 6 A. – I’ll try my luck as they are in the same ballpark.
The original MCPCB is 24 mm and my CULPMs are mounted on 20 mm. There is no retainer but a screw shank through the shelf that acts as an anti-rotational lock. This did catch my smaller board. The bezel with the reflector holds the star in place. The Osram footprint is 4 x 4 mm, I used a 5.7 mm x 7 mm (ID x OD) gasket being just 0.1 oversized ID. May not be perfectly centred, but there is an inner ring artifact. Something I’ve never encountered before. Dome-less, I doubt the LED be too deep in the reflector’s throat, but the lens doesn’t seem to have any AR. Stray reflections?
Here I have some beam shots. Living in an urban environment, my closest target is the parish church. This is not far enough for a proper thrower, but it gives me a relative idea of the beam characteristics.
The first pics are of the SST40, the seconds are the Osram HX.
The YinDing’s are above their power curve, the light is in the violet hue * on a white wall, but this is not seen outside. So I would suspect about 7 Amp draw. The lumens also took a hit, from 5900 down to 3300 . I foresaw some lower values, but again the YD’s aren’t up to par. I suspect they are seconds from Osram, but that is just speculation. (Is there a W2.2 neutral white?) Also, at lower levels (Low, Med1, and Med2), the beam is considerable lime green – argh! The light does get hot faster than the SST40s.
As for throw; was 77 kCd, now is 87 kCd. A tad improvement.
In conclusion, I’ll play with this for a while, and revert back to the original SST40s. They are not too harsh, somewhat on the warm side for a cool white CCT. The YinDings may eventually find themselves in some future project(s).
*Edits (Sept 16 ’21):
Only one emitter was in the violet. Changed (had a four-pack) and the beam is better: ~3450 lm. which is in line with my other CULPM1 (Simon’s) in a K0B host.
The green is not as bad as I had originally said.
