Smart screen displays mode, lumens, voltage and power
Operation:
Press and hold for three seconds and then turn on the flashlight, display WELCOME, then enter L1 mode (200LM), click again to enter L2 mode (500LM)
Click again to enter L3 mode (1200LM), click again to enter L4 mode (STR flashes), click again to return to L1 mode
Quickly double-click to enter H mode (2200LM super bright mode), click in this mode to enter SOS mode, and click again to return to H mode
Long press for three seconds to turn off, the screen displays GOODBYE
LED Source: 1pc OSRAM PUSRA1.PM (3W) LED & 3pcs OSRAM PUSRA1.PM (2W) LED
Output: Max 3050 Lumens with Turbo
3*LED 6000K (CW): 2350 Lumens
1*LED 3000K (NW): 1100 Lumens respectively
Intensity: 8380cd with medium brightness
Beam distance: 183 Meter with medium brightness
Switch: Side control Switch with LED indicator to monitor battery level
Charging Port: Type-C Fast charging
Battery: One high drain and unprotected 18350/20350 cell (not included)
User interfaces: Press side switch to on/off. Hold the switch after on, smooth ramping will be able to switch the brightness from low to high and high to low. Ability to toggle between Smooth and Stepped ramping. Double clicks will get instant access for turbo mode.
Other functions/modes: Timing mode, Flash alternative mode, Power monitoring, Firefly mode, Single or dual head mode. (pls refer to user manual for more exciting modes)
Lockout: Yes, clicks 4 times to lock and unlock
Memory: Yes. Will memorize the last brightness mode
Optic: Standard TIR Optic Lens for 3*LEDs Lens and Orange Peel reflector for 1*LED Lens
New Arrival OLIGHT MARAUDER 2 LED Flashlight Set
12*OSRAM P9+1*OSRAM PM1 / 15-mode / 14000LM / pure white / 3*21700 / USB-C rechargeable / US / 800m spotlight beam / power bank function
Extremely Powerful and Flexible: Featuring an 800-meter spotlight beam from the central LED, and a 14000-lumen floodlight beam from 12 surrounding LEDs. Built-in 54Wh rechargeable lithium-ion battery pack (three 5000mAh 21700 batteries), ensuring up to 59 hours of runtime.
Double Button Cooperative Power: A simple toggle switch to select either spotlight or floodlight; an intuitive rotary knob switch to turn on the light and circle through 7 output levels. (Note: Rotate the knob switch quickly over 90 degrees to unlock it.)
Equipped With Powerful Power Supply: Capable of 30W charging and 30W reverse charging. Only take 2.5 hours to fully charge. Able to charge a phone, a pad, or any device that uses a USB Type C power source.
Durable Quality and Unique Design: The aperture-blade-style port cover can be opened and closed by twisting the tail cap, IPX8 (2m), Drop Test: 1m. Silicone surface for a solid grip; hidden lanyard hole for portability; indicators to reveal brightness level, battery level, and charging status.
With intelligent temperature control
The head has a built-in light sensor, if it is blocked by an object, it will automatically reduce the brightness to ensure safe use
Compatible charging protocol: QC2.0, QC3.0, PD2.0, PD 3.0, APPLE, DCP, AFC
Charging voltage/current: 5V3A, 9V3A, 12V2.5A, 15V2A, 20V1.5A
Reverse charging voltage and current: 5V3A, 9V3A, 12V2.5A, 15V2A, 20V1.5A
Please note:
When used as a mobile power source, the flashlight can only charge one device at a time. It is prohibited to use any multi-port USB hub to charge other devices or to use two or more devices at the same time.
Do not shine the light directly on the eyes, it may cause temporary blindness or permanent damage to the eyes
Lumens: Spotlight (white main light): 50-1200LM; Floodlight (white auxiliary light): 50-500LM; Both of spotlight and floodlight synchronously turns on: 1400LM
Up and down 90 degrees rotation
But the listed specs are all wrong. It’s not “1-mode” or “350 lumens.” Please correct…it is SST-40, 1400 lumens, 495 meters beam distance, and 4-modes. This is one of the all-time best lights ever made!
C01S is a tiny Keychain light that is upgraded from BLF C01. With 2 modes and update to 100lm output. It is designed for finding keys, reading, EDC and emergency, etc. It can be operated from a single AAA battery (Alkaline/ Ni-MH). Rotate head to turn on / off.
Features:
Compact size more portability
Case Material is 6061 aircraft-grade aluminum,hard-anodized anti-abrasive finish, and better heat exchange
Stability, heat resistance, cold resistance, anti-fall, anti-pressure
Specification:
Head diameter: 14.5mmCRI (min): 95
Working Voltage: 0.9V-1.5V
Battery Options: One 1.5V AAA Alkaline battery or one 1.2V Ni-MH battery (Neither Included)
Flashlight body: Aerospace graded 6061 aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get the solidly built body, anti-crash geometry, and better heat exchange.
DIY Enabled: the tail cap stands upside down; the round hole is for a 5mm (diameter) magnet, and the other is a trit hole (magnet and trit not included)
Operation Instruction:
When OFF, screw down the battery case to turn on and modes from low-high; unscrew the battery case to turn off.
When On, unscrew the battery case to turn off and then rapidly screw down the battery case to change the mode; no memory function and default brightness is Low mode.
Head diameter: 22.7mm
Tube diameter: 21.2mm
Impact resistance: 1.5m
UV Intensity: 4700μW/cm2@38cm, 28600μW/cm2@15cm
UV flashlight has multiple usages as below:
Check the leaks in air conditioner and automobile circulatory system
Mark and blood inspection, examination of crime scene
Treasure and minerals searching, antique appraisal
Ink curing and glue curing
Identify counterfeit bills
Gas leaks inspection
Fluorescent reflection of special materials
Head diameter: 69mm
Tube diameter: 50mm
Waterproof level: Life waterproof
Low voltage warning: automatic power off
Illumination: Maximum 314.7KCD
Reverse polarity protection: None, the positive side of the battery should be facing the head
Mode operation instructions:
Click the button -> flashlight is turned on with last brightness -> press the button,brightness ramping up -> release and press the button again,brightness ramping down
Flashlight off, press the button -> moonlight mode 0.01A (0.2%) (This brightness will not be remembered)
Flashlight on or off, 2-click the button -> turbo 100%
Flashlight off, 3-click the button -> strobe
Flashlight off, 4-click the button -> tactical mode, only 100%, 4-click the button again to quit tactical mode.
Flashlight off, 5-click the button -> voltage detection (* means “flash”, * suspend* means 3.7V )
Flashlight off, 6-click the button -> ramping mode switch to 4modes 1–10–40–100
Flashlight off, 10-click the button -> Lock mode, The flashlight will flash once under any operation, which means the flashlight is locked. 10-click the button again to quit lock mode, please note that this is the only way to unlock.
Please note:
If you put the flashlight in a bag, be sure to loosen the connection between the battery tube and the head. Otherwise, the flashlight may be turned on by mistake, which has a risk of burning the contents in the bag.
Please use a USB Type-A to USB Type C cable and 5V adapter to charge the battery.battery should be facing the head
Max 2100 lumen blinding high light and 250m flood-light long shot; the patented dual-function tactical switch can access to momentary on or one-step strobe under any working conditions by halfway or fully pressing the switch; rotational magnetic switch around the tail cap for easy one-handed mode switch; strike bezel embedded with super-hard nano-ceramic beads to efficiently break car windows.
TA30 MAX comes with a USB Type C direct-charge 21700 battery, to reduce the frequency of changing batteries, more environmentally-friendly; 5000mAh large capacity, to ensure the long endurance and lower battery anxiety
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 38mm
Tube diameter: 28mm
Impact resistance: 2m
