Nichia 219BT-V1, R9080 Warm White, 2700K is available
3682 posts / 0 new
thefreeman
thefreeman's picture
Last seen: 12 min 47 sec ago
ToyKeeper wrote:
That’s not the extent of changes needed for the driver. It needs an entire second power circuit, isolated from the first one… and it’s already a tight fit with just one.
Plenty of space on the 22mm driver, especially since the DD FET channel becomes unnecessary, the wires would be more problematic but still doable by replacing the relatively thick aux silicone wires with thin Teflon wires, the main negatives wires could lose a gauge and use Teflon as well. I mean even in the current D4v2 it’s a bit of a mess, personnaly when modding one I replace the aux wires with Teflon, much more room to work with.
ToyKeeper
ToyKeeper's picture
Last seen: 16 hours 18 min ago
iamlucky13 wrote:
Hank Wang wrote:
Tint ramping version Noctigon K9.3 is available. The FET turbo mode is still valid for the non E21A version.
That sounds like a really great improvement that adds a lot of flexibility to the use of the light.
The K9.3 currently has two sets of firmware:
  • Tint toggle
  • Tint ramp
The tint toggle method was the original, where 3H simply switches from one set of LEDs to the other. It’s like having two separate lights, with only one powered up at a time. This is instant, and effectively uses a different ramp for each set of LEDs because one is a 5A linear and the other is a 9A linear plus a DD FET.
The tint ramp method is brand new for this light, and is a little more complicated…
  • Ramp levels 1-130 use smooth tint ramping between both sets of LEDs, with only the linear power channels. This has variable tint resolution depending on how bright it is, so high levels are very smooth but the lowest levels are less smooth when ramping “sideways” between tints. However, the up/down brightness ramp is smoother than before, since it uses the new dynamic PWM thing from a few weeks ago.
  • Ramp levels 131-150 smoothly turn off both linear channels and power up the DD FET instead. So turbo is always the 9 main LEDs, no matter what tint is active elsewhere in the ramp.
  • Switching from the 9 main LEDs to the outer 3 LEDs takes about 4 seconds because of the smooth ramp between. This allows all the in-between blends to be used, but isn’t as fast if the user wants only the endpoints.
  • At the far ends of the tint ramp, past the end, there is an auto-tint mode. It goes from one set of LEDs to the other, based on brightness.
If you like to use one set of LEDs or the other, but not both at the same time, the toggle method is better. If you mostly want to use a blend, the smooth method is better.
There are also some other recent changes included:
  • added an option to select turbo style / 2C style: Anduril1 style, Anduril2 style, or no turbo. This is configurable for both simple UI and advanced UI, so people can get turbo in simple mode now if they want.
  • added an option for whether hold-from-off should ramp up or stay at the floor
  • made smooth ramp speed adjustable (can be slower)
  • enabled auto-lock in simple UI (but it requires going to advanced mode to turn it on)
  • made the ramp auto-reverse window a bit shorter, so it’s easier to ramp up, stop, then ramp up again
  • made it easier to enter large numbers in config menus… click for +1, or hold for +10
  • added a configurable “jump start” to get moon level to turn on faster on slow drivers (needs to be configured per-light, though, since hardware varies so much)
  • added dynamic PWM (a.k.a. PFM, pulse frequency modulation) for more precise brightness resolution at the bottom of the ramp
  • fixed audible whine on DD FET modes on some lights
  • fixed corner cases in the hybrid memory timer, so it resets reliably to the saved level
Basic usage is still the same though… click for on/off, hold to change brightness. All this extra stuff is just improving things people asked for.
ToyKeeper
ToyKeeper's picture
Oh, um, before anyone asks… the “tint toggle” and “tint ramp” firmwares are not going to be merged into a single runtime-selectable option any time soon. They use totally different code, and the toggle method uses a bunch of custom overrides which aren’t compatible with anything else. These two don’t even use the same hwdef file. The differences between them are deeper than it might seem.
thefreeman
Here is a very quick component placement for a dual linear driver (no tracing, no layout optimizations)
Plus as bonus, dual current sense for a 1 000 000:1 dimming range (i.e. super low moonlight), which would also solves this :
That is if HDR/dual sense is supported, and supported for tint ramping (which looks like it would need a lot of changes to the tint ramping code).
Alternatively two small FETs + resistor channels could be used, that means supporting 4 total channels and 2 channels per LED tint ramping.
Anyhow putting the high dimming range aside, it would have 8 components on the back, only one more than the D4V2.5 driver. In term of cost, probably similar or if more, not by much : smaller cheaper linear FETs since only 2 LEDs per channels, no DD FET, since the 2 linear channels should be capable of close to direct drive performance. The op-amps being the most expensive parts, doubled, but slightly less precise and cheaper ones than in the D4V2.5 can be used if dual sense or resistor channels are used since thoses give much more dimming range.
ArtieT59
ArtieT59's picture
Last seen: 27 min 55 sec ago
Hank, in anticipation for your next project, i cobbled this together. Thanks for selling me just the driver and switch for this mod!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
Hank Wang
Last seen: 3 hours 49 min ago
Nice, by the way, Nichia 219BT-V1, R9080 Warm White, 2700K is available
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
carsknivesbeer
carsknivesbeer's picture
Last seen: 38 min 51 sec ago
Are the Nichia 219B 2700k new or refound. Any measurements?
id30209
id30209's picture
Last seen: 3 hours 23 min ago
Hank, can I order KR1 with 219B?
WTB Titanium 4sevens 2xAA tube
ch1ir
Last seen: 2 hours 53 min ago
A quicker option is to email him directly
Emisar D⁴, Astrolux C8, BLF A6, Sofirn sp36aV2, Reylight Mini Pineapple, BLF 348 KillZone, Lumintop IYP07, Emisar D18, Boruit D10, Manker e01, Ultrafire z1, Massdrop titanium AAA, Astrolux HL01, Armytek Wizard Pro Nichia, Tacklife LFL3A, Astrolux FT03, Zanflair T1
id30209
id30209's picture
I did but no response. That’s why i stired the water here.
ToyKeeper
ToyKeeper's picture
I doubt it. I’m not sure, but I think the KR1 driver’s regulated circuit only goes down to 5A as the lowest turbo level. This is fine for the W1/W2 LED options, and for XP-L and SST-20… but Nichia 219B can’t really handle that much power. It’s rated for 1.5A and really should be kept at 3A or less. So Hank would need to make a lower-powered driver for it, or use special firmware which never goes above 50% or maybe 60% power.
For some lights, that’s worth doing… But in a thrower, 219B doesn’t really make much sense.
ArtieT59
ArtieT59's picture
nice! 2700k is much more exciting than 3500k for me! Thanks Hank!
id30209
id30209's picture
Thx TK for explanation!
Hank just emailed me saying to be patient, they are soon releasing small HI CRI thrower…
ToyKeeper
ToyKeeper's picture
Yeah. I don’t know much about it, but it sounds interesting. I sent him a quick test firmware just to help verify if the driver works, and to check if I’ve got the right pinouts… but I haven’t heard any more details yet. Just some initial hardware-enablement type stuff.
Meanwhile, I’ve been enjoying a KR1 W1 in 18350 form. It’s small enough to lose in my purse until I need it, and throws way farther than such a small light seems like it should be capable of. I leave it in lockout mode, with a manual memory level set somewhere practical, so I can just pull it out and use 2H for momentary at a useful brightness. The beam is similar to an Emisar D1S, but the light itself is only a fraction of the size.
id30209
id30209's picture
Yeah, I'm curious too TBH. There were many Reddit talk about the 14500 model
stephenk
stephenk's picture
Last seen: 9 hours 5 min ago
Just something like a FW1A, but with higher quality Intl Outdoor build quality would be great.
id30209
id30209's picture
That’s what i’m hoping for CC driver and 219B.
Forsythe P. Jones
Last seen: 2 weeks 15 hours ago
I hope it uses a t1616 driver.
RamBull
Last seen: 51 min ago
Thanks, TK!
id30209
id30209's picture
Apparently, the new thrower will use TIR optic, 21700 cells and one of the following emitters: SST40, SFT40, Nichia B35 and XHP35...
Let's wait.
trakcon
trakcon's picture
Last seen: 40 min 25 sec ago
id30209 wrote:
Apparently, the new thrower will use TIR optic, 21700 cells and one of the following emitters: SST40, SFT40, Nichia B35 and XHP35…
Let’s wait.
I’m excited about this, especially a B35 variant.
Pavlo
Last seen: 2 hours 2 min ago
If there’s a B35am variant, I’m in!
JaredM
JaredM's picture
Last seen: 2 min 57 sec ago
Let’s wait.
Fingers crossed! Sounds it could be a real winner.
Hank Wang
There will be B35AR variant, but since B35AR does not work with DTP, it can only be mildly driven,
the brightness won’t be that impressive comparing to the multiple LEDs flashlight.
id30209
id30209's picture
Hank Wang wrote:
Pavlo wrote:
If there's a B35am variant, I'm in!
There will be B35AR variant, but since B35AR does not work with DTP, it can only be mildly driven, the brightness won't be that impressive comparing to the multiple LEDs flashlight.
I am running B35AR on Eurekatronix board at 2A@12V without issues…
B35AM in my Convoy is pushed to 4A @6V without any angry blue beam.
Hank Wang
id30209 wrote:
Hank Wang wrote:
There will be B35AR variant, but since B35AR does not work with DTP, it can only be mildly driven, the brightness won’t be that impressive comparing to the multiple LEDs flashlight.
Nice to hear that, I’m still deciding how much current to use for B35AR. What is the brightness when you drive it at 2A? And which optic/reflector for B35AR?
thefreeman
AM would be preferable since efficiency of a boost converter is higher at 1S>6V vs 1S>12V, but I assume AR was chosen so that the same 12V boost driver for XHP35 can be used.
Regarding current handling, on a MCPCB with high thermal conductivity dielectric and thick copper pours it is reasonably good (7.6W/m.K, 3oz pours):
But those high perf MCPCBs might be cost prohibitive.
id30209
id30209's picture
Hank Wang wrote:
Nice to hear that, I'm still deciding how much current to use for B35AR. What is the brightness when you drive it at 2A? And which optic/reflector for B35AR?
Sorry Hank but i’m still waiting for meassurement tool to come but it’s bright as xhp35 to my eyes.
But AR is available only in R9050 version only. Wouldn’t it be better to get AM version which is R9080?
At the moment i’m using B35AM in Convoy S21A with stock reflector and 3535 gasket which was trimmed a bit cause B35 is 3636 or 3737 format. Gonna try next weekend with TIR and report which is better.
thefreeman
Ledil Olga RS produces a very nice beam with it IMO, what optic size are you considering ?
Hank Wang
Nice suggestion, we will use R9080 B35AM LED then.
