I received my EBL batteries and charger — I went ahead and top them off in m y Powerex Charger —they top off easily —but today when I ran a capacity test they all tested around 2000 mah —- then they all charged up to that same capacity except one — that one cell was still charging after putting 2900 mah in it —- on a battery that size I usually charge at 800-1000 ma — I think thats what’s happening with the supplied charger —- I tried out the EBL charger with some Turnigy batteries and it worked fine
Hold up on that meter if you want it for flashlights. That Zoyi does not have a low DC range and the 60A setting has a resolution of just 10mA. Much worse accuracy at 2% + 30 (thirty!!!!!) digits. Maybe fine for general stuff although I have no idea of that brand's/product's quality.
That low DC range is the only thing that makes the Uni-T 210 a standout in the world of cheap meters (has 2A, 20A, and 100A with better resolution and accuracy all around). Other units that will do that cost an arm and a leg.
I just received mine also…. thought it was nice of them to send the extra charging ‘adapters’. I was about to post asking how you were supposed to swap them… then I found my glasses and a flashlight I hate getting old ………… Charging now.
I just ordered the 059 Lite for $10 for my kid for school. Thinking I might cancel that order and order these H17s instead since they have ANC. Alas the Vipon coupon has ran out for today.
Interesting little NOAA AM/FM radio. Runs off an 18650. Around $11 for Prime members. I am pretty sure the sound is awful but for news and weather in an emergency, it might be good enough. I do believe we all have some 18650s sitting around!
