I donāt see a coupon on the Amazon page eitherā¦ and no results when searching on Vipon
Zippo HeatBank 3 Rechargeable Hand Warmer
Hold up on that meter if you want it for flashlights. That Zoyi does not have a low DC range and the 60A setting has a resolution of just 10mA. Much worse accuracy at 2% + 30 (thirty!!!!!) digits. Maybe fine for general stuff although I have no idea of that brand's/product's quality.
That low DC range is the only thing that makes the Uni-T 210 a standout in the world of cheap meters (has 2A, 20A, and 100A with better resolution and accuracy all around). Other units that will do that cost an arm and a leg.
Can peek at the manual and specs here: https://zotektools.com/products/zt-qb9/
Edit: If you really want this, looks like you can buy it on Ali for $26 here, or $34 on their official store: https://www.aliexpress.com/item/4000943578993.html
kotobuki wrote: [Digital Clamp Meter, Smart T-RMS 6000 Counts Multimeter Voltage Tester Auto-ranging, Measures Current Voltage Temperature Capacitance Resistance Diodes Continuity Duty-Cycle, AC/DC Current](https://www.amazon.com/HASAGEI-Multimeter-Auto-ranging-Temperature-Capacā¦(link) is external) Coupon will save an extra 50% of $35.99. It has all functions like Uni-T UT210E + temp measurement.
What coupon?slmjim
Sorry, they may ran out of coupon (check box) on Amazon ā¦
Here is another good deal of multimeter:
Save 50% of $34.99 (check box under the price)
Good luck!
Bluetooth headphones $10
https://www.myvipon.com/product/8857894-Active-Noise-Cancelling-Headphones-with-45Hrs-amazon-coupons
https://www.amazon.com/dp/B09C8K3F4C
These appear to be rebranded Mpow H17 headphones.
At this point, I think everything is a rebranded MPOW.
At this point, I thing everything is a rebranded MPOW.
Just about everything I post in this thread is.
I look for headphones that are a good deal on a daily basis, and most of what appeals to me are rebranded Mpow.
Canāt beat them. Iāve been using mine for a year now and they are still working great.
One set (H10s or H12s, forgot which) just stopped charging, so I have to use them unpowered only.
FlashPilot: Richie086: will34:Edit: Just noticed in the photos it shows 6x cells which makes a 20,000mAh powerbank not 26,800mAh, but in the descriptions it claims it uses 21700? which according to this you might receive the 8x 18650 version or the 6x 21700 version POWERADD EnergyCell Series Power Bank, Power Your Devices ā Poweradd
Poweradd is a well known charger & powerbank brand but something must have happened because seems like theyāre pulling all of their products off amazon and selling them cheap under energycell store. I do remember they have been offering free stuff for positive reviews in the past, maybe same fate as tacklife?
Anyways $13.59 for a 26,800mAh powerbank with 30W PD charging is a steal, well that IF you get the real poweradd product. There is also a 15,000mAh version for $10.
Just received both of these power banks. Both arrived in brand new unopened boxes and are each about 1/3 charged. I have them on the charger now and Iāll run
them through a charge cycle and let you all know if any issues arise. Thus far, all seems perfect, but I will try to open the larger 30,000mAh version and see what
type of cells are inside it.Thanks Richie. Im looking forward to your discharge results and 30k tear-down. Does the larger one allow for fast charging the pack? And can the pack be charged via USB C?
Iām charging the 30,000mAh PowerAdd from my large AFTIME power bank that I also recently received from Amazon. The AFTIME is sending the PowerADD 5.02v and 1.92a using
one of my USB-A to USB-C cables.
I just received mine alsoā¦. thought it was nice of them to send the extra charging āadaptersā. I was about to post asking how you were supposed to swap themā¦ then I found my glasses and a flashlight I hate getting old ā¦ā¦ā¦ā¦ Charging now.
Good deal.
I just ordered the 059 Lite for $10 for my kid for school. Thinking I might cancel that order and order these H17s instead since they have ANC. Alas the Vipon coupon has ran out for today.
EDIT: Looks like itās too late to cancel.
Vipon buying spree of the day:
Pixel RGB / CCT video light with tripod $20 with extra 10% clip-on. Has the generic UI with probably very bright 1% but comes with the dual mount tripod with the phone holder which is worth at least $8. I canāt remember how many of these I have owned and always end up giving them away because people say āwow thatās so coolā, so I borrow them out and never see them again.
Got one of these, very well build, very basic UIā¦ wish I could have bought a pair at that price.
$14 and rechargeable.
just like leaving the light
on without the light.
Interesting little NOAA AM/FM radio. Runs off an 18650. Around $11 for Prime members. I am pretty sure the sound is awful but for news and weather in an emergency, it might be good enough. I do believe we all have some 18650s sitting around!
Bluetooth headphones $30
https://www.amazon.com/dp/B098WVX1M9
These appear to be rebranded Mpow H21 headphones.
(I know that $30 is kinda pricey for Mpow, but someone might be interested.)
Very cool. I snagged one.
Grabbed one too. Thanks.
RovyVon A1x for $19.95 Been this low oftenā¦
Looks like all three colors are $16.95 for a lightning deal.
That's a good deal!
