➤ 3*18650 budget camping lantern with warm light! 17$ mustbuy
27 posts / 0 new
Lumeniac
Lumeniac's picture
Last seen: 3 hours 13 sec ago
Bleak and dull is choice of inexpensive camping lanterns. In 10 cases out of 10 it will be a disgusting blueish cold light and UI of 2-3 modes + strobe.
Of course, you can find something with good price\functionality ratio even in this fecal variety. I have already reviewed $5 mini lamp with a built-in battery, which is worth every cent spent.
The more I was surprised to find a good looking lamp with a long-playing power supply from 3 * 18650 batteries (important), warm light (very important) and power bank mode (not very important, but good).
So, with a price tag of $ 17, I did not hesitate for a second and immediately ordered this lamp at aliexpress in THIS STORE
btw, i would also recommend well known (it was sold under name of Zanflare T1 and Beamday T1) lamp from Amazon, read review
It is worth noting that there is a fairly close in functionality analogue from YPL – Bright Beam (that`s what YLP stands for originally in russian) CL-360a “Camping Chandelier 6”. There’s the same warm light and replaceble 2*18650 batteries. Brightness goes in ascending order + there is a red light mode. Unfortunately, it is almost impossible to buy it outside of CIS.
Package and appearance
Design of box is even better than I could count on the price. Taking into account the fact that you still throw it away – design makes no difference.
You can immediately see that there are 2 options: 30 and 20 watts (9900mah \ 6600mah). In general, abstract figures from which one can deduce that one version has 2 batteries, the other 3.
In addition to the lamp, kit includes: a short charging cable, a leaf dotted with hieroglyphs and a metal square with a stycky tapy backing.
The lamp itself looks and feels, albeit a budget, but definitely not as frankly basement made cheap. And it’s definitely, definitely not small. Due to this, as well as extremely modest waerproof protection, I would not consider it for serious tourism in any way. It makes more sense to take something reliable from Nitecore \ Fenix . But for a simple weekend rest in open air, fishing or hunting, not to mention a simple reserve of light in case of blackout.
Thick dark blue plastic with no molding defects. Doesn’t stink. Of the obviously budgetary features there is only a lurid orange pair of button and plug. But the same honeycomb looks very stylish here! Implicitly budgetary – tiny gaps and unsettled corners. For 17 bucks, you don’t give a damn about all this.
Thre are a magnet ring and a suspension hook on the top. The magnet is strong enough to hold the lamp with confidence.
Aforementioned button and plug are not the thickest and most reliable, frankly. There is also a 4-segment indicator window next to it. And there is 1A powerbank mode USB-A port.
The plafond is slightly dented, which is an advatnage – less chanes to crack if dropped. It can be effortlessly removed, revealing a disc with soldered LEDs.
Arh, zero thermal paste! However, due to a rapid drop from maximum brightness, the disk only heats up to “just warm”, nothing more – I checked it in my hands.
And one more “argh” is that, according to the good tradition of almost any superbudget product from aliexpress\amazon\bangood, the battery capacity is lower than stated. Here you can see 2500 mAh through the heat shrinkage, which in any way is close to stated 9900 mAh.
Ease of access and constructiveness lets you to swap these batteries to the same cheap Liitokala NCR18650B and add significant extra 2000 mAh capacity.
I guess that if you solder some higher drain cells you can improve the situation with stepdown and male rutime chart line more flat.
I do not presume to comment on the circuitry, it is possible to understand that everything here is extremely simple and expected.
In general, quite, quite good for this price. Substantially higher than what I expected.
UI
Better than you get with similar price model, but stil crap.
The inevitable stroboscope is still tucked in here , luckily it is hidden and can be activated by holding the button.
The rest of the brightness goes like this: High-medium-low-off
It’s not cool at all, you will definitely get blinded at night. you will have to press the lamp with a shade to the belly and rewind the brightness down.
Starting from minimum brightness would be definitely more practical.
ILLUMINATION
In terms of battery life, everything is decent, 7500 mAh is actually a lot. The maximum mode is comparable in brightness to a 60-watt incandescent lamp, but drops to 55% in a couple of minutes. In general, any (except Sofirn LT1) camping lantern will give you the same drop. But you shouldn’t consider it as a normal short-term turbo, a drop to the undeniably bright MID level will be last about 50 minutes. During this time, you will have a really bright light, and then the flashlight will also work at a good level.
At minimum brightness, you have more than two days of continuous work. Visually, this is something on the order of 20-30 lumens, which is quite good.
Well, for the rest … Here is the most relish. A combination of two winning characteristics:
a) This is actually a bright camping light. Even taking into account the short maximum brightness.
b) This is a LED camping light with warm light. which is nonsence…
Most of the branded camping lamps (Fenix ​​CL and Nitecore LR) give a sort of 5000K color in best case. This, of course, is a way better than 7000+K blueish light any budget camping lantern. But there is still no comfort, there is no cozyness!
But here the light is around of 4000K, no higher. And that’s really cool.
There is also a minus – the minimum brightness is too high for comfortable light in the “firefly” mode. Due to the price, the brightness here is probably regulated through PWM, and if you lower it to the level of about 1 lumen, then the light will decompose into hertz pulsations. I hope that Sofirn, to whom I gave the link and pushed the idea of ​​deep OEM modernization, will resolve this issue nd release their model based on this lantern.
And the most interesting thing – how does this camping lamp illuminates? Yes, it does it flaswlessly. Performs perfectly in suspension. As enchantingly steep as Sofirn LT1 is, its shape gives light to the sides, leaving a dead zone below. But form of the saucer, of course, acts opposide way – the light goes down.
For comparison, from right to left: 50 watt incandescent lamp \ review lantern \ $ 5 yellow soapbox.
As a result, it turns out that in the summer, the average brightness is enough for your eyes to light up the same gazebo pretty well (you can play cards without discomfort) until dawn. Some days ago electricity turned off in my village. But a considerable company of people was drinking and playing cards under this lamp in MID mode without any need of extra light.
At a height of one meter from the table, you can read with ease for the eyes. absolutely comfortable light in this mode for such needs.
Alas, the lower mode is definitely too bright for a night light. In the gazebo, it gives a cozy twilight, maybe even brighter. It depends on how high you hang and what size the gazebo is. In the same garage, you can move freely, everything is perfectly visible. But it will work in this mode for 2 and a half days. Well, look at the video, everything is clear there.
check final part of video review of this camping lantern, there are way more examples of it`s light.
OVERALL IMPRESSION
Of course, this cheap alixpress camping lantern has its drawbacks. It has an extremely primitive and rather uncomfortable UI. It has a significantly overstated capacity and insufficient reliability for serious tourism.
But! All this pales in comparison with its advantages, the first of which is the cozy warm light. Any other budget camping light will have a nasty, cold light. And in order to get something with at least a decent color temperature, you either need to use a flashlight with a diffuser, or buy an expensive brand model. And that, believe me, with the rarest exceptions will still not have the same cozy light. And also (the only exception is one – Sofirn LT1) unconditionally merge according to the runtime.
The second advantage is the price. 17 bucks (and even less if you have a coupon or promotional code) is just a gift. Absolutely everything that you can buy for such a price will be worse in everything: runtime, UI (catch the strobe after maximum brightness), and, in fact, light.
By and large, one such lamp is enough for your eyes. For one full-fledged night, it will give a wonderful light in terms of brightness. But! Personally, I tend to think it’s worth taking two. For outdoor rest such brightness will be excessive, destroying the magic of night outdoor recreation. But in a gazebo or at the countryside (and just as a source of backup light in case of a power outage), launching two pieces at once in medium mode will allow you to achieve a really high and long-lasting brightness level for a more than affordable overall price tag.
I want to remind you that Sofirn manager showed interest in the price-functionality ratio of this model, it is quite possible that after the upgrade they will offer a much more interesting model with a slight difference in cost comparing to this original one. At a basic level, I see improved UI and the installation of better capacity batteries. Stabilization is quite real in deep modernization. And if absolutely, ideally, then 3 * 21700.
For such a version, it is no longer a pity to put two high price tags, it will still be at the level of junior camping lamps from Fenix ​​\ Nitecore.
Edited by: Lumeniac on 08/24/2021 - 01:20
Robin Dobbie
Last seen: 2 min 46 sec ago
None of your images load except the .gifs and your redirect doesn’t work. Why not just link directly?
Lumeniac
Lumeniac's picture
hm. strange. i see all these pics.
will try to fix them
Robin Dobbie
To be honest they never load for me on your other reviews. I guess some provider in the chain nukes that host. Like i said the gifs load and I see the adtube embeds as well.
jeff51
jeff51's picture
Last seen: 18 hours 59 min ago
I can see the images.
A great review on an interesting lantern.
What a shame these things always go High, Med, Low. How hard would it be to simply make them cycle low, Medium, High?
Such a change would make so many of these cheap lights more usable.
Lumeniac, In the lower modes does the light pass the finger wave PWM test?
As in you wave your fingers quickly in the beam, do you see a jerky – shudder motion or is it smooth?
All the best,
Jeff
Lumeniac
Lumeniac's picture
hm. really strange. author of 1st comment and you are both from TX. he doesnt see pics, but you do
nevertheless, i will use 3rd party pic host in future.
i`ve just reuploaded them there.
about UI...well, even big brands make some really strange things sometimes. what to say about noname ? ))
no, i dont see PWM shimmering even in LOW mode.  i did regular pen test + fan test .
Robin Dobbie
The images are loading great, now. The link to the product still gets stuck on got.by so I don’t know. I looked at another review and while the redirect was a different domain, it still also gets stuck! Lol Im sure the problem is on my end.
jeff51
jeff51's picture
Robin, his reviews with lots of pics often hang on me too. Or at least really drag.
Lumentiac,
Somewhat on this review, but often on some of your other reviews, the images are so large and have a goodly number of images….
The page loads so slowly that unless I’m really interested in the light, I just close the page because I’m too impatient to wait for the whole thing to load.
I’m not sure what resolution you are linking to, but anything over about 1200-1600 pixels wide is wasted for most of us and slows the image load times.
I did a post a while back about image size, and BLFs could chime in about what they were seeing and load times.
https://budgetlightforum.com/node/73728
All the Best,
Jeff
Lumeniac
Lumeniac's picture
hm, i am surprised that couple of dozen 300-500kb pics may be problem in time when 100Mb/s net quite common.
i dont have problems with opening my reviews neither at laptop, not at smartphone.
i assume reason is that pic host i used is in Ru.
what is situation with this review, where i reuploaded pics to foreign pic host?
problem is that is the way i used before. and when this host died, lots of my reviews lost all the visual content.   it is not that like 2 yeas old model is subject of interest. but i still wouldnt like to loose pics.  normally i upload them to ixbt.ru, where is post my russian versions of review.
but, ok. there are lots of readers from states, so in fotgcoming reviews i will decrease size to *1600 from 1920.
protechteus
protechteus's picture
Last seen: 21 hours 58 min ago
I see all the pictures – both on pc and mobile.
Thank you for the review Lumeniac!
jeff51
jeff51's picture
Lumeniac wrote:
hm, i am surprised that couple of dozen 300-500kb pics may be problem in time when 10Mb/s net quite common.
I’ll bet you are right about the host site location. That would explain why sometimes the page loads so slowly.
My download speed tests at 30mbs, but in reality a download from a site is usually in the high teens or low twenty’s.
All the Best,
Jeff
Lightbringer
Lightbringer's picture
Last seen: 3 hours 12 min ago
Amazingly, I see ‘em all.
raccoon city
raccoon city's picture
Last seen: 8 hours 52 min ago
Yup, I see them too.  :THUMBS-UP:
angerdan
angerdan's picture
Last seen: 1 hour 9 min ago
Ordered a copy Thumbs Up
angerdan
angerdan's picture
Got my copy, color temperature is 3300K Thumbs Up Cool
Lumeniac
Lumeniac's picture
so, what are ur impressions?
i have ordered several more since posted this review
angerdan
angerdan's picture
Unbelievable bright, especially for this price tag!
Comfy warm white light, good color rendering index, around 2400 lumens.
So for mounting upside down or on magnetic surfaces it’s perfect.
Plasmatoast
Last seen: 9 hours 28 min ago
Good times are over. It’s 20$ from China and 24$ from US warehouse for 9900 mah. Still seems to be a good buy though
Lumeniac
Lumeniac's picture
3$ difference is not that much for this lampi uave orrdered like 5 of them after posted this review.
buvide
Last seen: 1 month 1 week ago
Can you tell me how long it takes to recharge this lantern. It looks good, but I’m looking for something fast to charge.
Are these the correct run times in hours: 12 (hight) 15 (medium) 24 (low)?
angerdan
angerdan's picture
buvide wrote:
  1. Can you tell me how long it takes to recharge this lantern.
  2. It looks good, but I’m looking for something fast to charge.
  3. Are these the correct run times in hours: 12 (hight) 15 (medium) 24 (low)?
  1. I’l measure the current it takes for charging
  2. Then get the Blf LT1 and charge the 4× 18650 cells in a 2A Charger like the Vapcell S4+ or Miboxer C4-12:
  3. 1:40h high, 15h medium and 26h low
buvide
Will it be much difference to charging inside the light (how I charge)? 3hrs max might be ok! I can’t guess these. Wuben F5 with type c is 4 hours says the listing on Aliexpress. Thought that would be quicker.
Ok. Wuben is 5200mAh —- 4hours to charge
This one is 9900mAh & not even type c —-
It said high is 12 hours in the picture. Typo! Well, medium sounds good still. I like the style, wish there was one that fast charges.
Thanks for the info.
Lumeniac
Lumeniac's picture
that is not mistake for high mode.
if you take a closer look at chart, you see that high itself is really short, then it simply steps down after some minutes. steps down at the level below MID.  that`s why it lasts 12hours. it is still high mode, but not at initial level.
my charts are precise. i dont know how these 1:40h high from post above were measured. lantern cannot sustain high at real high level
Asbestos
Asbestos's picture
Last seen: 5 days 17 hours ago
Thanks for the excellent review and work. The images loaded just fine for me. and were very helpful
I point to others in this group to justify how many flashlights I have.
angerdan
angerdan's picture
5.2V @ 0.6A = ~3W charging. So it could took ~15h for a full charge.
buvide
I have trouble reading charts.
Oh, one of those heat step down things. So each time you turn it on you only get 8mins of the highest brightness. Wondering now, if you turned on for only 8mins each time do you still get the full 12 hours? Is that how flashlight ppl measure it? Oh, actually they would just leave it on and measure it as it dimmed out… Well, it could be either. I always thought it was the first way.
But the brightness sounds fine from the reviews.
Do you know approx recharge time?
xevious
xevious's picture
Last seen: 10 sec ago
Yes, the deluxe edition was originally $17, now $20 if you order from China (slow shipping). I’m expecting it’s still a very good deal for what you get. (nabbing a BLF LT1 v1 with 4×18650 3000mAh Sofirn batteries for $55 shipped feels like a better value per dollar, IMHO). I wonder how well the power bank feature works on this light… I imagine not as good as a BLF LT1 v2 w/power bank feature. Still, for $20… not a bad backup for a charging source.
NOTE: In that same listing as above, there’s a new option for a solar recharged light in neutral white or warm. I’ve not checked the specs, as listing is totally remiss in providing a spec sheet. It does look weaker than the Dexlue YN-F03 and I imagine it doesn’t have a power bank feature.
