I ordered these on Sofirnlight.com on Sept 1 and they arrived yesterday, 2 weeks from China to US, not bad at all. I won’t include photos since you can find them online easily enough. I have a few more on order from Aliexpress (particularly in 670nm red, not available at Sofirnlight) and they are not here yet, so maybe Sofirnlight.com is a little quicker.
The two lights look basically identical unless you look straight into the bezels. They have a mix of diameters and knurling on the battery tube. Machining is adequate, with a little bit of both forward/backward and sideways play in the threads, not more than we are used to. The tail end has some intricate milling with an endmill so it tailstands easily, while having a tiny hole for a split ring, a small round hole for a magnet, and an oblong hole for a tritium marker. I’m not sure about the idea of a $10 trit marker in a $4 flashlight, but they give you the opion. Each light came with a little baggie containing two spare O rings and a split ring. Weight of the battery tube is 9 or 10 grams (my kitchen scale with 1g resolution is not that accurate) and the head is 4 or 5 grams. The battery tubes and heads interchange between the two lights, but the heads are not machined the same way. The C01 has a 5mm led with a deep reflector while the C01S has a SMT led with an optic.
I dropped a fresh alkaline cell into each light and found the C01 has a large round hotspot without much spill. The C01S has a narrower hotspot with more spill. The C01S on low was maybe similar to the C01 in total brightness, and impressively bright on high. Afterwards I switched a charged NiMH cell (generic, not Eneloop) into the C01S and it didn’t seem as bright, but I don’t have any measuring gear so it’s hard to tell. Led color is nice and warm on both, with C01 a little warmer, I think. It would be interesting to see a voltage vs lumen graph of both these lights.
The C01S seems like a good EDC since the two levels are enough for most purposes. I am likely to put an L92 lithium cell into it to get the output a bit higher, on the idea that it is fairly sensitive to cell voltage. This is unlike some Fenix lights that had very flat regulation until the cell was near dead. The C01 is more of a party favor or backup because of its 1 level, though it is around 7 lumens, considerably brighter than the original 3 lumen Arc AAA that first popularized this format on CPF 20 years ago. So it is also perfectly usable as a go-everywhere light.
Each came with a black spring steel pocket clip made of quite thin steel, that seems nice and should be able to do the hat brim thing if you wear a hat. I usually carry a 1aaa light in my jeans’ watch pocket, so I tried clipping it there and the clip worked nicely. However, I had chosen a fairly light color (orange) for the flashlight body, and having it sticking out of my pocket made it more visible than I liked. So if buying again with this in mind, I’d pick brown or black.
I ended up pulling off the pocket clip with the idea of putting some heat shrink tubing over the rear of the flashlight, so I can hold it in my mouth more comfortably if I have to use it hands free. That means I also didn’t attach the split ring, so no lanyard or keychain for this at the moment.
Nice lights and good value, especially on AliExpress which offers the 670nm red led. I have heard they are discontinued so this is your chance to get them. On the other hand, if you miss out, there are lots of comparable lights now. I’m still awaiting a Skilhunt E3A which is a little bit smaller and brighter, supposedly.
I guess the most interesting feature of the C01 is the availability of the 670nm red led. I have never had one of those before (just the usual 635nm or so), so I’m looking forward to the two I ordered arriving.
