Thanks!
I guess I need to learn how the different drivers react. But it seems that it is working correctly.
Thanks!
Hey guys,
I am using the SST-20 version as a spotlight for photography.
What is the highest sane temperature limit you recommend for prolonged non hand held usage?
80-85C. Mostly for safety of the battery.
Thank you. I had it set to 65°C but now I will raise it a bit more.
So I just got an Fw3a from a reputable seller. And it was working fine but now it is "glitching" bad. It worked fine for first couple minutes, but then i set up my thermal calibration, Temperatire, and stepped ramping guidelines. After that it has been acting glitchy. Click the button on, then click and hold and no ramp, just shuts off. Hold for noon just jumps on then back off. Sporadic output levels both hi and low. I cleaned the ends of the inner tube, tightened the tail cap retaining ring (it was actually loose) and check the head retaining ring, it's right. I loosened both the tail and head and tightened tail all the way down very tight and then the head, did that process multiple times. Using a fully charged P26a brand new molicel. Switched to a Panasonic ga and it was worse.
any suggestions? I don't want to return it. I'll change the driver if I have to. I like the color. Lol
thanks!
OK, so i just read thru the las page. Im going to remove the head and tail retaining ring, clean with alcohol, center the driver if needed, and reassemble. Ill try it tomorrow and see if it works better. I have owned 6 of these with no issues whatsoever. So Ii feel confident it will be resolved. and, if not, Lume driver from Neal it is!
Try slightly loosening the tailcap retaining ring. If the switchboard is slightly loose it can float. This may give a better connection than if screwed all the way down
OK cool, i will try that
You were 100% right. I loosed the tail cap retaining ring a little and its working.
Other things i did - I 'popped' out the inner tube (it doesn't free float like the KR4 does) and reinserted it. I also did NOT tighten everything down Extremely tight. I checked out a couple of my other fw3a's that work perfectly and noticed none of them are wrenched down ungodly tight, so i just tightened everything with medium/tight pressure, now the new fw3a that had the problem is working Perfectly.
Thanks for the suggestion!
Hi Artie T59, I just read about your experience fixing your FW3A.
I bought one FW3A from Neals Gadgets during the recent Father’s Day Sale, together with a SS bezel, a sapphire lens, clip, and (my big mistake…. an 18350 tube).
I did note that there is a “warning” not to open the tail cap. I was OK with that for several weeks, enjoying the FW3A as my EDC. But finally I decided to try changing the long tube into the 18350. And that was when I messed up the tail-cap switch. It fell apart, some parts are loose. It doesn’t click, and doesn’t turn on the flashlight.
I tried to put back the 18650 tube. But the switch doesn’t work any more.
I sent an e-mail to Neals to his Hotmail a few days ago; but he has not responded.
I want to find out whether Neals’ shop sells a replacement tail-cap switch for FW3A (?)
I have seen some Youtube videos about people inserting some colourful glow rubber part into the tail-cap switch. They look simple, but I just don’t have any tools to tighten the parts. Hence my question whether I can buy any replacement tail-cap switch anywhere.
Did you loose the little black nub that presses the switch? If not, you should be able to put it back together. If so, you can make a new nub with some plastic.
hey buddy, so I have seen members on Reddit recently with glow switches and all of that for the Fw3a, so I think they are still around (I think neal has a couple colors left actually), but from what it sounds alike that may not be your problem.
So when you started having the issue with the switch, did the switch come apart by any chance? Or was it just loose? I only ask because there is a very small piece of plastic in the switch that allows it to engage. People refer to To it as a nubbin. Anyway, if it is not in there, or if the switch was so loose that it become dislodged from its seating, then the switch won't work.
the good news- the only tool you need to work in the switch is a small needle nose plyer or even two small screwdrivers or even two small nails. Just something to put into the small holes in the retaining ring to loosen and tighten it. The switch design once you open it up is very simple and straight forward. And there is good info and pictures and even YouTube videos showing how to dissemble and reassemble the switch.
let me know where your at with it
Thanks Jason WW and Artie T59 for your quick kind advice. Will look for that small plastic part. I don’t recall seeing it when I tried to push and press the switch back in shape.
See this earlier post.
Or, if you want a stiffer switch that doesn’t come on by accident, try a –008 o-ring
Happy to help.
I think what is happening is that if the tailcap retaining ring is screwed down too tightly it is at a very slight angle to the top of the inner tube. This creates a very poor switch connection. If the retaining ring is left loose, the tailcap board floats slightly and can then press flat against the edge of the inner tube creating a good connection.
I first noticed this when I had problems with switch connection on a later model FW3A with the switch retaining ring tightly screwed down while the problem did not occur at all on an early model with no switch retaining ring. Slightly loosening the switch retaining ring solved the problem.
The “nubbin” is a tiny black plastic cylinder that sockets into the center of the rubber switch boot. It can get lost easily and the switch will not work without it (without modification).
Unfortunately, it’s likely that part is lost for good. The part is miniscule and due to its shape prone to rolling a long distance if dropped.
Fortunately, the nubbin isn’t required. Some options:
Thanks JasonWW, Jared M, and Firelight2 for kind suggestions.
Will try them all and learn.
If the worst comes to the worst, I may buy another FW3A (I like the brass) and enjoy having two heads of FW3A to play around.
I’m not sure if my question belong to this thread, but I found no other place.
In my FWAA (TiCu version) the SOS is broken.
Instead of . . . - - - . . ., it only blink with following pattern . . . . . . . . . . . . . . . . . .
Anyone experience the same?
Instead of . . . - - - . . ., it only blink with following pattern . . . . . . . . . . . . . . . . . .Anyone experience the same?
The FWAA has no SOS mode, only beacon.
