It does look like the pebbled lens has some kind of ringed bit in the center. Head is more rounded and now the body has a flared out segment at the head base. Also, looks like they may have modified the magnetic charging port?
25$ shipped?
New model release! H300 H300R 2500 lumens LED headlamp
Wow, a good amount of options: black vs grey, reflector vs TIR, 6500K or 5000K, no battery vs 3100 mAh vs 3500 mAh. And UI looks good: click for on/off, long press for low, double click for turbo, 4 click = lockout with optional indicator. I’m liking the looks of that optic. Can’t wait to try it out
Is the bezel easily removable like in previous models (e.g. H03)? What is the LED voltage?
Pole looks warmer on the left.
Promotion Sales on our Website, www.skilhunt.com
- 6% OFF Coupon Code: blf06
- Orders over $69 to get E3A keychain light 30% Off
- A Free E3A light as gift for orders over $79
- Extra 8% OFF for orders over $99
H300 review sharing
Review sharing
Обзор Skilhunt H300 CW
http://forum.fonarevka.ru/showthread.php?p=1374432#post1374432
New UI for H04 series headlamps
Big fan of Skilhunt, I have more than ten Skilhunt flashlights , most of them from M-serie, plus one headlamp.
But, I count like five UI incarnations in the last three years in M-serie and headlamps.
Here we are:
- M200 - 1.gen. : 2x4 modes
- M150 - 1.gen: 2 UI groups (the second one non-programmable)
- M150, M200 - 2.gen: 2UI groups, the second one is programmable
- H300 - 7 modes
- H04old to H04new - like H300
Thats simply too much. Where is the continuity, where is the stability? Looks like Skilhunt dont know, what they want. Its really bad, because otherwise they produce great lights.
535 lm T2 and 395 lm H… Why? Why…!?
It would be MUCH better to replace the old XM-L2 to higher efficiency SST40 or Osram PUSTA1 first.
Then turbo levels can be also higher which makes sense.
Isolated charging port. Stronger tailcap magnet. these are also good modifications.
I personally love the option to set the number and power of the levels. You could leave it this the “new” Armytek-like UI. It’s only programming.
My skilhunt H04 RC is my most used headlamp.The thing I dislike is the extra long press from off goes into lockout which appears to be fixed.
The biggest complaint is that I can’t cycle up from moonlight into low, medium etc. You have to turn it off and rely on last used mode which may be too bright.
M150 new metal grey color
Any discounts for the M300?
injust bought this two days ago, but I got black. From alix store. Anyway to change my order to metal gray?!?
is the GRAY M150 available yet?
Yes, available now
