What did you mod today?
thanks! You have very good taste :beer:
Heres whats on the bench for this weekend:
M2r Warrior - install xhp35 HI 4000k
KR1 - install sbt90.2
S2r Baton II - Install either SFT40, CULPM1, or xpl-hi 2850k
D1s - install 7.5a driver (SFT40 already installed)
D1 - Install 7.5a driver (CULPM1 and KR1 reflector already installed)
Wish me Luck! :))
Good luck!!! :sunglasses:
Is there a sense resistor on those new drivers to bump the 7.5 up to say 9 with the sft40?
On the K9.3 driver the sense resistor is 10mΩ and and the sense voltage is bumped to 90mV compared to 50mV in the 5A KR4/D4V2.5 driver (also with 10mΩ Rsense). I assume it’s the same for the 7.5A driver, no change to Rsense and Vsense = 75mV.
Either can be changed to get the desired current.
Curious as to what numbers you’ll get from the KR1 and the D1S!
Couple simple aesthetic mods to my Zebralight SC52w triple.
  • replaced stock clip with titanium deep-carry clip
  • added a few strips of Talon Grip Tape.
Not sure if I’ll keep it like this or go back to the stock clip and no grip tape.
Here are some pics next to an FWAA:
Nice to have patients for the operating table. :smiley:
Thanks!
I am not sure, i will have to look at it, maybe someone can share a picture of what that should look like?
I know, i ordered these 6 weeks ago. Had i realized i was using a sft40 i would've asked for one of them to be 9amp. but then again, heat is a factor, so 7.5a might not be terrible in that small host.
hmm. this sounds interesting. would you be able to share with me what part would be needed, and where it should be soldered, to make this change? I have a feeling i get the concept of what needs to be done, because -
I feel like there is an old Matt Smith (Adventure Sport) youtube video where he mods a driver of some sort by soldering / stacking resistors onto each other to get more current? I wonder if this is the type of mod you and JaredM are referring to?
That ZL looks SO Good!
CNCman - haha! yes it is, im pretty excited. Will probably take me both days due to small obligations around the house. lol
TmaxxJJ - I know me too! I know the FET enabled KR4 driver shold pump out some amps with the Molicel P26a i will use in that KR1, I'm excited for that!
And the D1s should be good, once i can properly tune that beam! its been rough, and i've got over an hour just into reaming the reflector and swapping between different centering rings, no rings, kapton tape, etc.. If i cannot dial in the beam very well, i may try the CULPM1 in the D1s as well... but i really do not want to "throw in the towel", but that D1s reflector is being a motherf**&er to try and dial in with that SFT40.. It started out horrible, so at least I'm making progress lol..
D1s from what I remember hearing had a flawed reflector. I believe the GT mini reflector fits it however… but maybe I have that backwards.
About the sense resistor, you’ll see a relatively large resistor marked with R010 or something similar. That would mean its .010 ohms or 10 milliohms. Whatever the value is, the formula is as follows.
Sense resistance (milliohms) * current (amps) = sense voltage (millivolts)
For example
10mOhm * 7.5A = 75mV
You then use this voltage and work backwards using your desired current. Lets say you want 9 amps
75mV / 9A = 8.33mOhm
So thats your target resistance
Resistors in parallel behave such that the total is the inverse sum of the reciprocals.
So 1/0.00833 = 1/.01 + 1/x
1/x = 20.05
X = .050
So stacking an R050 on top of a R010 should yield 9A.
And to modify Vsense you can change R3 :
R3 = R4 x (VCC-Vsense) / Vsense
With VCC = 2.8V and R4 = 3.3k
For 50mV you get 181.5k (180k is used), for 75mV 119.9k (probably 120k is used, check the code on the resistor), for 90mV 99.4k (100k is used).
Flawed reflector, or just tuned perfectly for a XPL-HI? IIRC nothing with that LED throws as well in its size class.
Artie - Have you got yourself a light meter yet so you can measure some numbers? Also for the tuning, or are you doing that by eye?
As I said, I may have had that backwards. D1 definitely had a bad beam, and I remember some folks swapping reflectors between D1s and GT mini. I can’t remember which was better and never had either personally.
Got a cheap triple flashlight from Alonefire. It comes with a white, warm, and UV LED. Swapped out the random white and warm LEDs with a XPL-HI 5000k and a sliced LH351D 2700k. Apologies since I can’t really manipulate white balance properly. The LH351D looks more orange IRL rather than rosy.
Sunwayman V11r
LH351D 2700k sliced dome
low 0.02 lumens
Turbo 335 lumens
repacked control ring w Nyogel 767a
unfortunately the beam is unacceptable due to a dark shadow in the spill (this does not happen with dome on)
redid the reflow to an LH351d 2700k with stock dome on
low 0.03 lumens
Turbo 425 lumens
the beam is Much better!:
So far, i got the xhp35 HI 4000k in the M2r warrior, and i got the D1s done! 3.5 hours later! heres some pics. sorry for the link, dont have time to upload pics, but wanted to share!
https://imgur.com/a/Dm7jSnC
Highlights:
Emisar D1s
7.5amp KR4 driver, Anduril 1
Lighted Cyan Switch
SFT40 LED (still needs to be tuned properly, height adjustments)
