If the GT94 stays cool enough to not need the temp control, then the temp control shouldn’t kick in. Anyway it’s certainly possible to compile Anduril without it.
I like it and will get one but I want one that uses 4 GT reflectors which would make the head about 250mm diameter and compete with the lemax super power.
To me it seems only an upgrade on the batteries. If the head diameter is still the same then I cannot see really an improvement on the intensity of this light.
I agree, once you get a 130 km ish reflector and push a 90.2 at 22 amps with 8 x 30Q’s then you are about maxed out on throw, lumens and runtime. But then the light is big and bulky to use. But this one looks mean and fun. :smiling_imp:
I would love to get one.
With 4 x 90.2 leds, it needs more power.
In my opinion the numbers don’t add up. If you increase the lumens from 20,000 to 24,000 the throw doesn’t go up from 2500m to 2950m. More like 2700m or so.
Awesome light but with that girth why even bother making it tubular? I’d like to see a square body with a built-in handle and an easy access switch at the handle like those cheap plastic 6 volt lights, or kinda like the streamlight litebox.
Exactly if the head is the same and the output is 24000 then we have the same launch of the GT90 around 2700 meters but it will never reach 2950 meters because it would need an output of at least 27500 lumens.
I’m thinking we need something more like a giant version of the fireflies e07, with 7x sbt90.2 and 14x21700 batteries. With a giant reflector there’s no reason we can’t hit 7 mcd. Where’s Imalent when you need them…
I am keeping my eye on this one. Same emitters as the GT94? Same reflector wells diameter and depth? Four or eight 21700, instead of eight 18650. Where do the extra lumens and extra throw come from?
