Test/review of JSC Energiya INR18650 1500mAh LITS-1.5 (Blue)
Official specifications:
  • Nominal capacity: 1500mAh
  • Nominal voltage: 3.6V
  • Maximum discharge current: 20C (30A)
  • Charge voltage: 4.2V (Other specification say: Open voltage 4.1V).
  • End of discharge voltage: 2.5
  • Cycle life: 300 cycles to 60% (Other specification says: Service life 500 cycles).
This is a Russian manufactured 18650 cell designed for battery powered tools, this means low capacity and very high current.
The two cells matches fairly well and the battery can maintain nearly constant capacity at any load.
Conclusion
The cell has fairly low energy content, but can deliver a lot of power.
Notes and links
The batteries was supplied by a reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Very interesting, I had no idea Russia even made cells at all! Are there others out there, I suppose?
Me either, but somebody decided to enlighten me. I have a couple of other cells from JSC I will publish reviews of in the next month or two.
I don’t want to sound like a smartass, but JSC in this case means Joint-Stock Company (same as A/S in Denmark).
The company’s name seems to be “Energiya” :stuck_out_tongue:
Name something good, but at least decent Russian-made, besides Kalashnikov?
Plenty of things; don’t be racist :slight_smile:
