21700 with Hi-Cri and type-c
15 posts / 0 new
beatl
Last seen: 2 days 22 hours ago
Hi everybody!
Choosing the light meeting some requirements. Don’t be so strict – combining them makes the choice rather narrow and uneasy.
Generally need a flooder\universal beamshot with tir-optics or orange peel reflector. With no extra-extra-tactics design features.
Must have:
- built-in type-c charger;
- protected batteries (that’s why noctigons ain’t no going);
- hi сri led with cri 90+ and 4000-5000k;
- the simpler – the better control (yeah, I know, but Fenix is ok for me, arduino-style not much appreciated, only if it will be the only disadvantage for me);
- convenient discharge indicator (that’s why acebeam 65 isn’t good here);
- “normal” size, meaning no huge head also;
- tail-stand;
- high quality case and finish (fenix, surefire are as example, convoy – not the one).
Better be:
- moonlight;
- magnet tail.
For now Acebeam 65 is good, but disharge indicator is simply absent, also looking at Wuben 21, but can’t tell what Cree 70-2 version used there, have doubts it 90+ cri. What did I miss?
Parametrek
Parametrek's picture
Last seen: 2 months 6 days ago
That is an easy search for my flashlight database. Here are 5 lights meeting your core requirements. Of those only the Wurkkos HD20 has both a sub-lumen firefly and a magnetic tail. Though the UI might be more complicated than you prefer since it has 2 emitters. I don’t know if it can fit protected batteries.
Try the largest, fastest, most flexible flashlight search engine: parametrek.com
58 brands, 2773 models and still growing!
NEW: US battery database and European battery database
MascaratumB
MascaratumB's picture
Last seen: 30 min 30 sec ago
If the type C charging could be micro USB, I would suggest the Wuben TO50R (high-cri 5000K, 21700 battery, floody beam., magnet tailcap, tailstands, has battery indicator in the switch).
If type C is “mandatory”, I don’t know Oops
beatl
Wow, didn’t know about your base, thanks! I’ll take a look!
beatl
MascaratumB wrote:
If the type C charging could be micro USB, I would suggest the Wuben TO50R (high-cri 5000K, 21700 battery, floody beam., magnet tailcap, tailstands, has battery indicator in the switch). If type C is “mandatory”, I don’t know Oops
Thanks, but better be, migrating all electronic devices to type-c port, even bike lights Smile
Ryzbor
Ryzbor's picture
Last seen: 3 days 16 hours ago
How come you need protected batteries?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
beatl
Well, let it call paranoia…
tantien11
Ryzbor
Ryzbor's picture
Unprotected batteries are perfectly safe unless you are a total moron.
beatl
Maybe I am Wink At least I’m totally ignorant in electricity. You have any good lights in mind? I also forgot to put digital stabilization and PWM absence in first post.
clientequator
clientequator's picture
Last seen: 1 day 1 hour ago
My dream flashlight is 21700 battery but still something small like Zebralight SC700d, but with USB C charging, and Anduril control.
You are describing something like the loneoceans Lume X1 driver with ultra low firefly mode. Hopefully some manufacture will work with him to make one flashlight. Loneoceans made driver for Fireflies flashlight and they have very good quality USB C charging, so this sounds like it is possible.
JaredM
JaredM's picture
Last seen: 1 min 29 sec ago
Thrunite T2 swapped to GT FC40 4200K led. All features except tail magnet. I have one for sale, but it’s been carried and has a few scratches and dings.
beatl
It’s an interesting one, but chosen by manufacturer light steps are quite odd (from 300 right to 1700 lumen), also changing led a bit tricky – ‘cause I won’t be able to do it myself
beatl
tantien11 wrote:
ACEBEAM E70 with FC40
No built-in type-c – it may go with the battery with slot, but it’s not optimal.
beatl
Went for this asked for Samsung 4000k HiCri led, thanks everybody!
