Well, if the NI03 is any indication of performance to the ft03, I say get it. You won’t be sorry. I don’t think the heat sinking is as good though on the ft03 so your duty cycle on higher modes will be lower. Use the 26800. I really like that cell and it’s probably diminishing returns to use a P42A.
Pretty excited. Wish it would show up before this weekends trip.
I hope to use it boating. I have tried so many lights for the range inside an aspheric thrower. We will see. I will try to get pictures, probably October though.
Kaidomains Custom P35 SFS80 4000K version can’t take the 8 amps that they tell it should. I fried one, reflowed the second one with more care and it also fried at 8A.
Received my nightwatch valkyrie. Great flashlight. The sfn55.2 has a great beam shape in this (op reflector) light. I’m impressed. I would definitely prefer 5000k, but I’m impressed by the emitter. I might buy the same light with sbt90 just to compare, I do think I’d prefer the beam shape of the sfn55.2 based on beamshots from the web and using this light. The spill is very bright, sort of reminds me of a TIR.
I ordered a P35 3v 4000k emitter and a P70 6v 6500k emitter today from Kaidoman with my other leds. Looking forward to both! they both look domeless, hoping the P35 competes with the sft40 but in 4000k!
Definitely. It’s one of the more well-rounded lights in my collection. It’s only missing a buck+FET to make it spectacular. I mean a sub 60 mm reflector that throws over 700 m with a huge 7070 LED and 7000 lumens? Oh yah. Nothing else with a single LED and battery comes close. Plus PD charging and power bank sweetens the deal.
My green OSRAM version of the FT03 mini does 910 meters, though at 900 lumens. Does the 720m compare well with a Boost HX? The Boost HX is still expensive as well.
My 4000K versions of SFS80 couldn’t sustain 8A. Two burned immediately and on a third one phosphor first bubbled and then fall off during routine reflow.
unfortunately I never put the HX in the FTO three mini, but you're right I think it would be more like 900 m going off of what the numbers are for a c8. I also have a p35 coming from kaidomam.com, Going to see how that does this too but I think that might be the same or better better
Not entirely sure these belong in this thread - But i just received the "P70" 6500k (6volt i believe), and the "P35" 4000k 80CRI (3volt !) from kaidoman.com :)) here are a couple quick pics, still figuring out which lights i want to throw these in. Bth of them are domeless HI versions.
Thinking a Emisar D1 for the p35 4000k (i have a couple D1 now and have been looking for a led to put in one). and thinking the Convoy M21e for the P70. Any thoughts?
*EDIT: its "too bad" (my own fault) I just sold my acebeam e70 xhp70 version, would've liked to seen this P70 in that little guy!
P35 4000K’s seem to be quite fragile. I have one in Convoy S2+ with 5A driver and it works fine. I tried to build Convoy thrower with 8A driver and I burned two of them. During reflow the phosphor has started to bubble few times and then it peels off. Now I know that you have to be extra careful with them.
It’s best to test with a power supply the threshold of any LED. Had a surprise with CULPM1.TG from Yinding. Angry blue at 8 Amps, toned it down to about 6 ½ A.
