They certainly are the best motion sensor night lights I’ve ever purchased, and amazing bright. The wife totally loves them!
Enough room in the LOFER light for a 21700 you think?
I converted one of the thin ones to a 1S4P 18650 external pack for a basement light. It’s a kludge, but works fine for what it is. The “large gum-stick” battery they come with is simply not up to the job. Other than that I like it.
https://www.amazon.com/Energizer-Flashlight-Resistant-Aircraft-Grade-Batteries/dp/B094LMMGQ7
Several other energizer lights in “Todays Deals”
21700 not possible… there is only ~2mm room with the 18650. But the MCPCB is just inserted in a slot in the extruded aluminum and you could probably fix it on top of the battery with some epoxy.
Yeah the lipo packs these movement lights normally comes with are designed to fail. Not a single one lasted me more than a year until severe capacity loss or swelling up. And even worse no way to get replacement batteries at decent prices. 18650 is the way to go…
Wuben E6 - 14,500 batteries included and a 30 % off coupon
“Compatible with two batteries: WUBEN E6 is a flashlight compatible with 14500 batteries and AA batteries. The flashlight purchased will be equipped with 14,500 batteries. Not to buy quickly yet! ! ! ! ! ”
The radio is decent enough considering the price. The included 2200mAh “Li Lon” battery tested ~1400mAh at 1A discharge. Anyone else? I don’t care if it’s just a low capacity battery but I’ll drain and throw it out if it’s damaged.
The Wuben E6 is cool. There was a better deal a while back and I got it for about $25.
The UI is severely lacking for an E-switch light. Three modes with memory and double click for strobe.
It’s got a big reflector for an AA/14500 light and that combined with the Osram emitter makes it a serious mini thrower.
Yeah, that’s my main complaint about Wubens (the TO46R being a major exception), awesome hardware, but UIs that cause slow but cumulative brain-damage.
GOLDSTON Magnifying Glass with Light,3 Color Modes Stepless Dimmable,Adjustable Swivel Arm, 5.5 Inches USB
Vipon says less but i got $19.33 in my cart…
I think that’s the same light I paid $27 for in July but brand was CUMKA. Nice deal.
While comparing, I found another magnifying lamp seemingly comparable to the one I posted above. Use code: 2PSM87S7 to bring it to ~$14
Thanks. This wasn’t in the product description, but in a “Compare With Similar Items” set at the bottom, which Amazon cobbles together on the fly. It’s kind of puzzling why they didn’t put this directly in their static chart section.
Anyway, it’s now $19…
Thanks — I already had a version of this one ( 1 is good / 2 is better ) that I made a portable Magnifier with— A block of wood base and a power bank — works great
Got the UNI-T UT210E Pro meter in. Thanks for the heads up on the sale.
Likes: Small(ish).
Matches my old Fluke at the few voltages I’ve tested.
Clamp-meter with 2A range – great for flashlights,
Non-Contact Voltage indicator, didn’t know it had this feature, (one less thing to carry).
Works with rechargeable batts (so no alkaleaks needed).
Comes with a pouch (cheap plastic) that has internal pocket for leads. Pouch has room for extra batteries.
Dislikes: Leads could be more flexible.
Wish the pouch could fit the meter with the leads attached.
Tips on leads only have a tiny contact area exposed – prevents sticking them into wall sockets to test voltages.
To measure a DC voltage takes several steps – Turn on meter with rotary dial, press function button 2 times to cycle from AC Volts to Hz to DC Volts. Wish it went right to DC Volts.
Hz won’t measure faster PWM Freq. Haven’t tested it to see what it will do yet.
Noticeably slower to display a DC voltage than my 1980s era Fluke. As in attache the leads, wait a moment, then see the voltage.
Like it, does more tricks than my old Fluke DMMs.
All the Best,
Jeff
Do you have the link to this? I went back a few pages but did not see this one, only the $18 one.
Have you got a link or code for the 210E Pro? I need a second one before I mod my old 210E, in case it does now go well since it is a software mod.
On my UT210E, the tips of the leads have inconspicuous covers that can be pulled off. You can’t really tell by looking at them. Try to see if you can slip them off.
Yup, the covers come off.
