There’s a link in this thread. Some german webshops also carry it. See if you find one that delivers to Russia with moderate s&h.
I downloaded a few of the older APK files, and none of them has the dark theme, with R9 measurement.
It's probably just a software thing, but not available to us, users.
Jon, I really agree with you. Not having accurate’ish DUV or R9 is the issue. CT are easy to make an informed guess about, still, but to a lesser extent after having looked at so many it is fairly easy to decide where the DUV is more or less. Camera shots with right WB and again a good eye will tell you a bunch on a calibrated screen.
Because Im also interested in comparing the flicker score of various LED light bulbs I have bought, I decided to contact Opple and have ordered one for delivery to USA
you all can wait for my review, or go ahead and open your wallet
here is the purchase link I used
opple from china to USA
I have no affiliation of any kind… I paid the price shown in that link (about $35 w shipping), for the one I just ordered. Will post impressions after it arrives.
Holy cow. $31 after coupon and shipping? That’s a pretty good deal for what it advertises to be. It may not be a professional-level tool, but according to the test results that have been posted here so far, it seems to do what it claims to do.
That’s what I consider a deep discount for a unique tool.
Congrats for finding it at this price! I’m sure you’ll like testing it. I’d be interested about your findings regarding lux measurements. I found some deviations from the Benetech GM1020, but that’s surely not a reference device.
This Opple is sold to professionals, and part of the job is measuring brighness. So, it should be good at that, taking into account there are standards about e.g. office/workspace brighness values.
I did a side by side test, at 5 meters, compared the lux measurement manually with my Hagner E4-X luxmeter.
Mode1-Mode4 were with a Olight Seeker 3 PRO with unknown LEDs
Thrower is a Fenix C7 with SST70 (not so much of a thrower, but more throwy than the Olight)
I used the Hagner measurement as 100%, and then did the math. I wonder what everybody else gets.
Here are the results in terms of candelas (calculated from the lux I measured)
Hagner | |
Mode 1 | 275 cd |
100% | |
Mode 2 | 1375 cd |
100% | |
Mode 3 | 5000 cd |
100% | |
Mode 4 | 17000 cd |
100% | |
Thrower | 59000 cd |
100% | |
So, an average of about 11% higher than the Hagner.
The 9% at the start and 14% at the second mode are not as consistent as the other measurements that were close to 11% each time.
So that is good to know. Just take off about 10% of the measurements, and it should be okay!
thanks for sharing your testing… what light source and LED did you use?
There may be variations due to spectrum. In any case 11% is not enough to worry me.
Within 10% is acceptable for a ballpark figure and good enough for casual testing. For around $30, that’s very good.
Thank you, Chibim!
I have inconsistent results with the Benetech, depending on LED. But the culprit is probably not the Opple but the GM1020.
I didn't mean to say that 11% was bad, but more like: if you subract 10% of the readings it should be in the ballpark.
The first few measurements weere done with the Olight Seeker 3 PRO (unknown LED)
and the 'thrower' is actually a Fenix C7 with SST70, which isn't very much of a thrower, but more than the Olight :)
10% high sounds good enough, and after 10% substraction you are within a few percent. For a complete picture how it performs as a luxmeter, light sources with some more varied spectra could be compared with the Opple+Hagner , from 2700K to 6500K, from 70CRI to 95CRI.
fwiw, there can be a large difference in the way my light meter reads LEDs
for example, the SSC P4 in my Original Novatac, reads 70 lumens on my meter… but Hogo swears he calibrated it to 120 lumens, after making an adjustment for the spectrum of the LED
by contrast my HDS w XP-G, which is factory calibrated to 200 lumens, reads 210 lumens on my meter… which I then adjusted to match the 200 lumen HDS.
so, an XP-G reads very different than an SSC P4
another example
Maukka bought a 200 Lumen HDS w sw45k. On Maukkas meter it read 235 Lumens. This tells me that HDS used a different spectrum conversion factor than Maukka.
so yes, if the Opple reads within 10%, that is totally OK, and can be attributed to testing Low CRI Cool White LEDs, which read differently than High CRI LEDs, or LEDs with a different spectrum distribution.
Im looking forward to comparing the Opple to my Light meter… with various different LEDs…
I am looking forward to comparing it with my Canon 5D ii spot meter, it seems to be very good a color temps.
Next little test.
Distance is approximately 4 meters this time.
Solarforce with warm white Nichia High CRI (can't remember if 119 or 219)
Hagner | Opple |
2275 cd | 2475 cd |
100 % | 108.79 % |
= 8.8% higher |
is it possible to make runtime graphs for flashlight testing in this app?
No way to record or export data except taking screenshots.
I personally use a fairly inexpensive setup I created using an ESP8266, documented here
I also recently noticed that my luxmeter (UNI-T UT383BT) has logging capabilities and can export the data to a CSV file or PNG. The capture time is adustable: 0.5s, 1s, 2s, 5s, 30s, or 1m. I do not know how long of a capture it can take. The app is called iENV.
Received Opple Light Master Pro
did a quick test of a Tool AAA w sw35
CCT estimate seems very accurate:
Flicker index:
Spectrum:
calculated DUV from X-Y coordinates:
I plugged in the Opple to recharge… it only had 1% battery left when it first arrived.
First thoughts
very tiny, pretty good CCT measurement… dont know what to think of the flicker index yet…
So far, Im happily entertained. The unit took 21 days from order date to in my mailbox in USA
I do not know if there is an R9 or DUV display, yet. But the spectrum chart shows Tint below BBL… seems good…
sw45k test:
