Nitecore BR25 Bicycle LED Front Light
1*Luminus SST-40-W LED / 5-mode / 1400LM / pure white / 1*21700/1*18650/2*CR123/2*RCR123 / IP68 waterproof
New Arrival OLIGHT MARAUDER 2 LED Flashlight Set
12*OSRAM P9+1*OSRAM PM1 / 15-mode / 14000LM / pure white / 3*21700 / USB-C rechargeable / US / 800m spotlight beam / power bank function
Extremely Powerful and Flexible: Featuring an 800-meter spotlight beam from the central LED, and a 14000-lumen floodlight beam from 12 surrounding LEDs. Built-in 54Wh rechargeable lithium-ion battery pack (three 5000mAh 21700 batteries), ensuring up to 59 hours of runtime.
Double Button Cooperative Power: A simple toggle switch to select either spotlight or floodlight; an intuitive rotary knob switch to turn on the light and circle through 7 output levels. (Note: Rotate the knob switch quickly over 90 degrees to unlock it.)
Equipped With Powerful Power Supply: Capable of 30W charging and 30W reverse charging. Only take 2.5 hours to fully charge. Able to charge a phone, a pad, or any device that uses a USB Type C power source.
Durable Quality and Unique Design: The aperture-blade-style port cover can be opened and closed by twisting the tail cap, IPX8 (2m), Drop Test: 1m. Silicone surface for a solid grip; hidden lanyard hole for portability; indicators to reveal brightness level, battery level, and charging status.
With intelligent temperature control
The head has a built-in light sensor, if it is blocked by an object, it will automatically reduce the brightness to ensure safe use
Compatible charging protocol: QC2.0, QC3.0, PD2.0, PD 3.0, APPLE, DCP, AFC
Charging voltage/current: 5V3A, 9V3A, 12V2.5A, 15V2A, 20V1.5A
Reverse charging voltage and current: 5V3A, 9V3A, 12V2.5A, 15V2A, 20V1.5A
Please note:
When used as a mobile power source, the flashlight can only charge one device at a time. It is prohibited to use any multi-port USB hub to charge other devices or to use two or more devices at the same time.
Do not shine the light directly on the eyes, it may cause temporary blindness or permanent damage to the eyes
CYANSKY K3 LED Flashlight
1*Luminnus SST40 HI / 5-mode / 2000LM / pure white / 600m beam range / 1*21700/1*18650 / clilp / lanyard / IPX8 waterproof
Head diameter: 40mm
Tail diameter: 25.4mm
Voltage: 3.7-4.2V
Applicable temperature: –30’C~50’C
2m impact resistance
EAGLE EYE X6R LED Flashlight
1-LED / 1-mode / 350LM / 1*18650 / clip & lanyard
Reflector diameter: 32mm
Head diameter: 39mm
Tube diameter: 25mm
Tail diameter: 25mm
Lanyard length: 27cm
Beam range: 200-500 meters
Working voltage: 3.7V
CYANSKY HS6R Triple Output LED Headlamp
1*Luminus SST-40+2*Luminus SST-20-W LED / 9-mode / 1400LM / white & red light / 1*18650/2*CR123A / USB-C
Lumens: Spotlight (white main light): 50-1200LM; Floodlight (white auxiliary light): 50-500LM; Both of spotlight and floodlight synchronously turns on: 1400LM
Up and down 90 degrees rotation
Hi,
I just did a review of this here: https://www.youtube.com/watch?v=\_p85AaTEVfI&ab_channel=ThrowHound
But the listed specs are all wrong. It’s not “1-mode” or “350 lumens.” Please correct…it is SST-40, 1400 lumens, 495 meters beam distance, and 4-modes. This is one of the all-time best lights ever made!
Sofirn C01S 100LM 4000K Keychain LED Flashlight
1*Luminus SST20 LED / 2-mode / 1*AAA / IPX8 / 42m beam distance
C01S is a tiny Keychain light that is upgraded from BLF C01. With 2 modes and update to 100lm output. It is designed for finding keys, reading, EDC and emergency, etc. It can be operated from a single AAA battery (Alkaline/ Ni-MH). Rotate head to turn on / off.
Features:
Compact size more portability
Case Material is 6061 aircraft-grade aluminum,hard-anodized anti-abrasive finish, and better heat exchange
Stability, heat resistance, cold resistance, anti-fall, anti-pressure
Specification:
Head diameter: 14.5mmCRI (min): 95
Working Voltage: 0.9V-1.5V
Battery Options: One 1.5V AAA Alkaline battery or one 1.2V Ni-MH battery (Neither Included)
Flashlight body: Aerospace graded 6061 aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get the solidly built body, anti-crash geometry, and better heat exchange.
DIY Enabled: the tail cap stands upside down; the round hole is for a 5mm (diameter) magnet, and the other is a trit hole (magnet and trit not included)
Operation Instruction:
When OFF, screw down the battery case to turn on and modes from low-high; unscrew the battery case to turn off.
When On, unscrew the battery case to turn off and then rapidly screw down the battery case to change the mode; no memory function and default brightness is Low mode.
Trick or Treating! Check Our Halloween 10% Site-wide Coupon Sale
Dear valued customers,
To celebrate the upcoming Halloween 2021, we prepared a large-scale event for all users with a 10% discount. Choose any product you wish!
Offer: Site-wide 10% off
Valid Date: Oct 30th, 2021 - Oct 31st, 2021 (UTC-6)
Coupon Code: HALLO2021
Fasttech, I see that you don’t have any shipping options for knives to Poland. Are there any outlooks for that to change?
TANK007 UV320 365nm UV LED Flashlight
1*LED / 1-mode / 1*AA / IPX8 / below 50m beam distance
Head diameter: 22.7mm
Tube diameter: 21.2mm
Impact resistance: 1.5m
UV Intensity: 4700μW/cm2@38cm, 28600μW/cm2@15cm
UV flashlight has multiple usages as below:
Check the leaks in air conditioner and automobile circulatory system
Mark and blood inspection, examination of crime scene
Treasure and minerals searching, antique appraisal
Ink curing and glue curing
Identify counterfeit bills
Gas leaks inspection
Fluorescent reflection of special materials
ARCHON V10S II 1200LM 6500K Diving LED Flashlight
1*Cree XM-L U2 / 3-mode / 1*18650 / 100m waterproof / 100-200m beam range
Angle of light beam: 160 degrees
With battery over-discharging protection
Operation voltage: 4.2-3V
Head diameter: 28mm
Body diameter: 26mm
Convoy 4X18A 5400LM 5700K LED Flashlight
Luminus SBT90.2 LED / 9-mode / 4*18650 / USB-C charging / 1122m beam range / temperature control
Head diameter: 69mm
Tube diameter: 50mm
Waterproof level: Life waterproof
Low voltage warning: automatic power off
Illumination: Maximum 314.7KCD
Reverse polarity protection: None, the positive side of the battery should be facing the head
Mode operation instructions:
Click the button -> flashlight is turned on with last brightness -> press the button,brightness ramping up -> release and press the button again,brightness ramping down
Flashlight off, press the button -> moonlight mode 0.01A (0.2%) (This brightness will not be remembered)
Flashlight on or off, 2-click the button -> turbo 100%
Flashlight off, 3-click the button -> strobe
Flashlight off, 4-click the button -> tactical mode, only 100%, 4-click the button again to quit tactical mode.
Flashlight off, 5-click the button -> voltage detection (* means “flash”, * suspend* means 3.7V )
Flashlight off, 6-click the button -> ramping mode switch to 4modes 1–10–40–100
Flashlight off, 10-click the button -> Lock mode, The flashlight will flash once under any operation, which means the flashlight is locked. 10-click the button again to quit lock mode, please note that this is the only way to unlock.
Please note:
If you put the flashlight in a bag, be sure to loosen the connection between the battery tube and the head. Otherwise, the flashlight may be turned on by mistake, which has a risk of burning the contents in the bag.
Please use a USB Type-A to USB Type C cable and 5V adapter to charge the battery.battery should be facing the head
NEXTORCH TA30 MAX 2100LM 6500K Tactical LED Flashlight w/21700 Battery
Cree XHP50.2 LED / 6-mode / USB-C charging / IPX8 / 250m throw
Max 2100 lumen blinding high light and 250m flood-light long shot; the patented dual-function tactical switch can access to momentary on or one-step strobe under any working conditions by halfway or fully pressing the switch; rotational magnetic switch around the tail cap for easy one-handed mode switch; strike bezel embedded with super-hard nano-ceramic beads to efficiently break car windows.
TA30 MAX comes with a USB Type C direct-charge 21700 battery, to reduce the frequency of changing batteries, more environmentally-friendly; 5000mAh large capacity, to ensure the long endurance and lower battery anxiety
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 38mm
Tube diameter: 28mm
Impact resistance: 2m
NEXTORCH TA41 2600LM 6500K Tactical LED Flashlight w/21700 Battery
Cree XHP50.2 LED / 7-mode / USB charging / IPX8 / 272m throw / nano-ceramic strike tip
USB direct charge design
Super hard ceramic strike tips: Escaping from car windows & close quarter defense
Head diameter: 38mm
Tube diameter: 27mm
ARCHON J2 2-in-1 1000LM 6500K 100-Meter Diving LED Flashlight w/21700 Battery
Luminus SST20 LED / green laser / 7-mode / 100-200m throw
Head diameter: 46mm
Tube diameter: 28mm
Angle of light beam for White light: 10’
Operation voltage: 4.2V to 3V
TANK007 TC01 800LM 6500K LED Flashlight w/18650 Battery
Cree XM-L2 LED / 5-mode / IPX8 / 200m throw / glass breaker function
Head diameter: 34mm
Tail diameter: 29mm
Voltage: 3.7-4.2V
Nitecore HC65 V2 1750LM Triple Output LED Headlamp w/18650 Battery
Luminus SST-40-W 6500K LED / 4500K & red LED / CRI ≥90 / 11-mode / 1*18650/2*CR123/2*RCR123 / USB-C charging / IP68 / 165m throw
Enter coupon code MAP on the shopping cart page to see our unbeatable price.
Flashlight modes: Primary White Light Turbo > Primary White Light Hi > Primary White Light Mid > Primary White Light Lo > Primary White Light Ultra Lo > Auxiliary Red Light Hi > Auxiliary Red Light Lo > Auxiliary Red Light Flashing > Auxiliary White Light > Beacon > SOS
Waterproof: IP68 (Submersible to 2m)
Max beam intensity: 7000cd
100’ wide range flood beam
180’ all-round adjustable
Elastic and breathable headband with silicone sweat diverting strip
Highly efficient constant current circuit (non-PWM)
ATR (Advanced Temperature Regulation)
The power indicator can display the battery voltage (+/-0.1V)
WUBEN E12R 1200LM 6500K Camping Light LED Flashlight
OSRAM P9 LED / 6-mode / 1*18650 / USB-C charging / IP68 / 179m throw / power bank function
E12R delivers up to 1200 lumens with a beam throw of up to 179 meters, it can be used as a camping light or floodlight.
It utilizes 18650 Li-ion battery with circuit protection board, which has a run time up to 173 hours.
Premium temperature control design
Impact resistance: 1m
