I can’t believe I never knew this all these years owning this meter—- Thanks
Pennsy, did you find it?
More expensive now by a few bucks.
Sure enough the little boots slip off the probe ends.
My case is plastic with a pattern embossed to make it look like cloth.
Least I think it is….
I’ll give one of those semi-hard cases a try. Needs about 8” inside to fit.
Got a JBL speaker case for my LT1 and it’s just right.
Least I think it is….I’ll give one of those semi-hard cases a try. Needs about 8” inside to fit.
Actual usable inside measurements of the one I linked are 3-5/8” x 7-3/8”……meter itself is just shy of 7”. There’s enough extra room lengthwise to fit a AA battery and plenty of space at the side for gizmos. Takes up a little more room in the chest than I’d prefer but it’s nice having all that stuff together.
More expensive now by a few bucks.Sure enough the little boots slip off the probe ends.
Yup, put it on my Honey price drop list. Thanks
Does anyone know the difference between the Uni-T 210E & Uni-T 210E PRO?
The Wuben E6 is cool. There was a better deal a while back and I got it for about $25.
The UI is severely lacking for an E-switch light. Three modes with memory and double click for strobe.
It’s got a big reflector for an AA/14500 light and that combined with the Osram emitter makes it a serious mini thrower.
But this one comes with 14,500 extra batteries .
About $10?
As far as I can tell, the Pro version can measure AC Frequency. The non-Pro doesn’t have that function.
The Frequency function - so far - has not been able to pick up on PWM square waves.
I haven’t tried it on much yet to see if that’s the case for different PWM Freqs.
All the Best,
Jeff
By the way, if anyone needs some good clamp leads for meters, these are excellent. I don’t know if you could do better unless you make your own set which would cost a lot more. 18awg high strand conductors, super pliable cover (not sure it’s silicone but it’s not pvc), good fit and great spring tension. Not a deal, per se, but a good price on great leads. Most of the others out there are a smaller wire and can’t carry much current (fine for most things, though). For real hotrod lights you’d probably want to go to a heavier wire than these.
Ummm….?
ROFLMFAO!
Whaaaaat
I’ve heard people refer to these things as “roach clips” but that brings a whole new dimension to the fun you can have with alligator clips. Wow, just wow.
Hahahahahah!
Thanks. I will never look at alligator clips the same way again.
Anyone know of a good sounding Bluetooth sound bar for a TV. Would also like to connect my phone, wirelessly to hear music.
Budget, budget, budget.
Check out TCL’s soundbars on Amazon Here . I needed one and a friend highly recommended them. Very happy with mine. They are great quality for the price.
This is the one I got on sale for $100…… here
chooma:Anyone know of a good sounding Bluetooth sound bar for a TV. Would also like to connect my phone, wirelessly to hear music.
Budget, budget, budget.Check out TCL’s soundbars on Amazon Here . I needed one and a friend highly recommended them. Very happy with mine. They are great quality for the price.
Oooh, thanks, price is right, do you remember which one you have?
I have two different Vizio 2.1 sound bars and really like them for the price. Models SB3621n-H8 (newer) and SB3821-C6 (older).
I've never owned a soundbar.
I have my TV hooked up to some budget, but nice, computer speakers.
my sound bar is behind the couch . I’m loosing my hearing a bit and having it across the room was causing me to turn the volume up a bit too high for the other family members
So it’s closer and quieter where it is
Correllux:By the way, if anyone needs some good clamp leads for meters, these are excellent. I don’t know if you could do better unless you make your own set which would cost a lot more. 18awg high strand conductors, super pliable cover (not sure it’s silicone but it’s not pvc), good fit and great spring tension. Not a deal, per se, but a good price on great leads. Most of the others out there are a smaller wire and can’t carry much current (fine for most things, though). For real hotrod lights you’d probably want to go to a heavier wire than these.
Ummm….?
Ohhhh……wow. Wow. lolol. If that was there when I ordered I totally missed it. That’s just excellent. lol
