About $10?
As far as I can tell, the Pro version can measure AC Frequency. The non-Pro doesnât have that function.
The Frequency function - so far - has not been able to pick up on PWM square waves.
I havenât tried it on much yet to see if thatâs the case for different PWM Freqs.
All the Best,
Jeff
Iâve heard people refer to these things as âroach clipsâ but that brings a whole new dimension to the fun you can have with alligator clips. Wow, just wow.
Check out TCLâs soundbars on Amazon Here . I needed one and a friend highly recommended them. Very happy with mine. They are great quality for the price.
my sound bar is behind the couch . Iâm loosing my hearing a bit and having it across the room was causing me to turn the volume up a bit too high for the other family members
The 210E Pro is a 6000 count meter versus a 2000 count meter. With tools just about like our light programmers one can basically update/calibrate and add functions to the 210E.
Check it out⌠The 210E can be almost fully converted to the Pro. Plus the backlight time can be adjusted, the auto off timer can be adjusted, the meter can be calibrated, it can be converted to dotless (range expansion) and frequency can be added to it. Other things are possible, but the modded one I have used was not fully modded.
