Ummm….?
Uni-T UT210E current clamp hacking
Specs batteries: 2xAAA battery life: 200 h; current consumption: current measurement mode 6 mA other measurement modes 2 mA 12 mA with backlight Accuracy in DC current mode is 2% + 8 counts in the …
Ummm….?
ROFLMFAO!
Whaaaaat
I’ve heard people refer to these things as “roach clips” but that brings a whole new dimension to the fun you can have with alligator clips. Wow, just wow.
Hahahahahah!
Thanks. I will never look at alligator clips the same way again.
Anyone know of a good sounding Bluetooth sound bar for a TV. Would also like to connect my phone, wirelessly to hear music.
Budget, budget, budget.
Check out TCL’s soundbars on Amazon Here . I needed one and a friend highly recommended them. Very happy with mine. They are great quality for the price.
This is the one I got on sale for $100…… here
Oooh, thanks, price is right, do you remember which one you have?
I have two different Vizio 2.1 sound bars and really like them for the price. Models SB3621n-H8 (newer) and SB3821-C6 (older).
I've never owned a soundbar.
I have my TV hooked up to some budget, but nice, computer speakers.
my sound bar is behind the couch . I’m loosing my hearing a bit and having it across the room was causing me to turn the volume up a bit too high for the other family members
So it’s closer and quieter where it is
Correllux:By the way, if anyone needs some good clamp leads for meters, these are excellent. I don’t know if you could do better unless you make your own set which would cost a lot more. 18awg high strand conductors, super pliable cover (not sure it’s silicone but it’s not pvc), good fit and great spring tension. Not a deal, per se, but a good price on great leads. Most of the others out there are a smaller wire and can’t carry much current (fine for most things, though). For real hotrod lights you’d probably want to go to a heavier wire than these.
Ummm….?
Ohhhh……wow. Wow. lolol. If that was there when I ordered I totally missed it. That’s just excellent. lol
The 210E Pro is a 6000 count meter versus a 2000 count meter. With tools just about like our light programmers one can basically update/calibrate and add functions to the 210E.
Coscar: chooma:Anyone know of a good sounding Bluetooth sound bar for a TV. Would also like to connect my phone, wirelessly to hear music.
Budget, budget, budget.Check out TCL’s soundbars on Amazon Here . I needed one and a friend highly recommended them. Very happy with mine. They are great quality for the price.
TCL Alto 6+ 2.1 Channel Dolby Audio Sound Bar with Wireless Subwoofer, Bluetooth – TS6110, 240W, 31.5-inch,
JenkinsMatti:Does anyone know the difference between the Uni-T 210E & Uni-T 210E PRO?
About $10?
As far as I can tell, the Pro version can measure AC Frequency. The non-Pro doesn’t have that function.
The Frequency function - so far - has not been able to pick up on PWM square waves.
I haven’t tried it on much yet to see if that’s the case for different PWM Freqs.
All the Best,
Jeff
Thank you both for the clear cut answers & comparison chart. I appreciate that.
I am thinking considering my limited knowledge, the 210E will probably do me just fine.
Thank you. But I am somewhat confused. Are you saying the 210E can be upgraded by the user??
Also wondering about the “count”? Amazon says th3 210E PRO is 2000 count. A picture shows this also. Is this a misprint at Amazon?
I am assuming 6000 count is better?
Check it out… The 210E can be almost fully converted to the Pro. Plus the backlight time can be adjusted, the auto off timer can be adjusted, the meter can be calibrated, it can be converted to dotless (range expansion) and frequency can be added to it. Other things are possible, but the modded one I have used was not fully modded.
Information gathered on the Uni-T UT210E multimeter. - GitHub - bdlow/UT210E: Information gathered on the Uni-T UT210E multimeter.
8 votes and 1 comment so far on Reddit
Ummm….?
Oh, c’mon…
“Banana”, “rubber”, “kinks”, “firm”, “mates”, “tight”, etc., how did anyone not see that nipple-thing coming?
That ad was like major-league fapping material.
…but that brings a whole new dimension to the fun you can have with alligator clips. Wow, just wow.
Alligator clips suck.
Alegator clips are awesome!
Uni-T UT210E current clamp hacking – The Arduino Shed
W0W… Good information, thank you so much!!!
