HKJ
(HKJ)
September 25, 2021, 11:48am
1
Vapcell INR21700 5000mAh P50 (Red) 2021
Official specifications:
Model: P50
Typical Capacity: 5000mAh (0.2C discharge)
Min capacity: 4900mAh (0.2C discharge)
Nominal voltage: 3.60V
Max Continuous Discharge Current: 15A
Max Discharge Current: 25A
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Weight: 72g ( Appr)
Internal resistance: 15mOhm ( Appr) AC 1kHz
Standard Charge: 2000mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
This is a high capacity 21700 cell.
The two cells tracks very nicely and the cell can deliver rated current.
Conclusion
This is a good high capacity 21700 cell with a decent output current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Henk4U2
September 25, 2021, 12:00pm
2
Thank you for the review HKJ. I looked up some data in your comparator. They are almost identical twins.
Correllux
(Correllux)
September 25, 2021, 6:01pm
3
These look great. Thanks for testing them!
I see that you tested the newer Sofirn 5000mAh 21700 cells. Do you have their original 4000mAh in the lineup? Seems like they’re still supplying that one with lights and few or none of the 5000 (but they sell it separately in their ali store).
HKJ
(HKJ)
September 27, 2021, 1:05pm
4
Correllux:
I have not tested the 4000mAh Soshine.
The best way to check if I have tested a cell is to check my website.
Find the pages with individual reviews and use the search function in the browser: Batteries and chargers
