Hhmm, I could try contacting them but I don't have any direct contact person there. Sure would be interesting in posting a review, but I don't see this light at many retailers at all, so seems like they are not pushing it.
This is true, Haikelite never pushes any product, even if very valid, they are not good at placing their torches, certainly they are not marketing geniuses. However, already with the Osram W2.2 Culpm1.tg the MT41 is very performing, I imagine a new one with 4 SFT40 instead of the current 4 SST40 of the MT40.
I have the haikelite as well it’s a great thrower for the money.
It easily beats the TM16GT I have in both throw and output, beats the astrolux EA02 I have in throw with 4 times the lumens.
I need to try it against my MF02 as they should be similar except in lumen output.
here is my quick video about how does it perform. It’s about 500-600m to the end of the mine. I’ll try my best tonight and I’ll make some more beamshots in various ranges, I even have drone footage of it, but I need to glue it all into single video all those interested ones - stay tuned!
Yes, the folks at Haikelite are not very good at promoting their products. BG has a new Haikelite that looks interesting. It isn’t even listed with a model name or number but is listed as Haikelite XPH50.2 (SIC). I can find no other info.
I’ve looked for the MT41, maybe it’s only available in some areas.
Does anyone here have an idea of what the best batteries to use for this would be? I just bought one and I want to double check that I'm picking the right batteries.
I'm looking at picking up button top versions of either 4x Molicel P26As (~25a continuous), Samsung 30Qs (15a continuous), or Sanyo NCR18650GAs (10a continuous).
I think the CSLPM1 won't pull more than ~9a per LED, correct? If that's the case, then I would see no performance benefit going for 30Qs or P26As over the Sanyos?
I want to make sure I'll be getting the absolute maximum performance out of it, and I'm happy to sacrifice some capacity for that, but if there's no benefit going for the higher drain cells then I might as well go for the Sanyos.
Those cells are probably in parallel, so figure 8 amps per emitter on Turbo, that’s 32 amp (barring losses for resistance, etc), so you’d be fine with GA’s, but to get the most out of it, go with Sony VTC6 (if you can find them). If you can’t find those, Vapcell rewraps them.
Thanks so much for your reply. I’m pretty sure I need button tops. I haven’t been able to find button top VTC6s in stock, or button top Vapcell rewraps of them. I assume 30Qs would be pretty equivalent, right?
Vtc6 hits a little harder and can sustain higher current for longer, basically the voltage sags less ss load increases. 30Q are fine, but GAs will be better I think due to the longer runtimes. That or LG MJ1 or Samsung 35E
I’m using flat - them works for me, not a single problem with connection, which is strange for me, because it shouldn’t work properly according to manual.
Well that’s…confusing. Maybe I just have to wait until it arrives to see what will fit in there. Though I suppose the safest bet would be to follow the manual and just get 4x button top P26As.
Maybe your VTC5As have slightly protruding flat tops? Maybe you could take a pic of the contacts in the light?
