WildTrail WT1M & WT3M
WildTrail WT1M XHP50.2/SST40 3000-3500lm
WildTrail WT3M 3* XHP50.2/SST40 5500-6800lm
USB Rechargeable Flashlight Group Buy
For reference, this is my order timeline for our Group Buy.
Note: speed of delivery varies from country to country.
Group Buy Price: from $3-.99 (usual $57.99)
Freeme's Exclusive Coupon: Request in this thread
Can't wait for our reply??
Price: from $40.25 (usual $57.99)
Coupon: BGWT3M
Features:
1. Emitter: 3x 3V Luminus SST40 5000K (DC) 70CRI, mounted on copper DTP MCPCB
2. 3x 3V XHP50.2 6.000K (1D) 70CRI, mounted on copper DTP MCPCB
3. Intensity: SST40: up to 44.000 cd (ANSI throw up to 430 m) XHP50.2: up to 22.500 cd (ANSI throw up to 300 m).
4. Firmware: Open source software called Andúril, distributed under the terms of the GPL v3.
5. The source code is available from http://tiny.cc/TKAnduril
Specifications:
Battery | 1x 21700 rechargeable lithium-ion battery (Battery length must be within 70mm and 72.5mm) |
Driver | FET driver with temperature control (see calibration in the UI chart). Reverse polarity protection, low parasitic drain (< 120 µA) |
Charging | USB-C port (input up to 5V 2A) |
Reflector | Orange Peel (OP) aluminum alloy reflector |
Lens | Glass with doubleside anti-reflective coating |
Body | Aluminum with hard black anodized or clear coated aluminum alloy |
Button | Tactile electronic side switch with back-lit boot |
Ingress rating | Equivalent to IPX-8, do not immerse in liquids |
Size | Length: 103.5mm / Head: 39.6mm / Tube: 28.5mm / Tailcap: 29.2mm |
Impact resistance | 2 m |
Weight | 128 grams without battery |
Package Included:
1 x WildTrail WT3M Flashlight
1 x Manual
Group Buy Price: from $2-.99 (usual $42.88)
Price: from $30.34 (usual $42.88)
Coupon: BGWT3M
Features:
- Emitter: 3V Luminus SST40 5000K (DC) 70CRI, mounted on copper DTP MCPCB
- 3V XHP50.2 6000K (1D) 70CRI, mounted on copper DTP MCPCB
- Intensity: SST40: up to 93000 cd (ANSI throw up to 610 m)
- XHP50.2: up to 40000 cd (ANSI throw up to 400 m)
- Firmware: Open source software called Andúril, distributed under the terms of the GPL v3.
- The source code is available from http://tiny.cc/TKAnduril
Specifications:
Reflector | Smooth (SMO) aluminum alloy reflector |
Weight | 163 grams without battery |
Dimensions | Length: 125.6mm / Head: 44.7mm / Tube: 28.5mm / Tailcap: 29.7mm |
Package Included:
1 x WildTrail WT1M Flashlight
1 x Manual
Images:
