Test/review of Vapcell INR21700 5000mAh P50 (Red) 2021
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 23 hours 48 min ago
DSC_4610
Official specifications:
  • Model: P50
  • Size: 21.3*70.7mm
  • Typical Capacity: 5000mAh (0.2C discharge)
  • Min capacity: 4900mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 15A
  • Max Discharge Current: 25A
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 72g ( Appr)
  • Internal resistance: 15mOhm ( Appr) AC 1kHz
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 4000mA
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-info
This is a high capacity 21700 cell.
DSC_4608 DSC_4609
DSC_4611 DSC_4612
DSC_4613
DSC_4614
DSC_4615
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-Capacity
The two cells tracks very nicely and the cell can deliver rated current.
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-Temp-15.0
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-Temp-20.0
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-Temp-30.0
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-CapacityTimeHours
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-Energy
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-PowerLoadTime
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-TripCurrent
Vapcell%20INR21700%205000mAh%20P50%20(Red)%202021-Charge
Discharge-Vapcell%20INR21700%205000mAh%20P50%20%28Red%29%202021-pulse-1.0%2010%2010-IR
Conclusion
This is a good high capacity 21700 cell with a decent output current.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Henk4U2
Henk4U2's picture
Last seen: 5 min 56 sec ago
Thank you for the review HKJ. I looked up some data in your comparator. They are almost identical twins.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Correllux
Correllux's picture
Last seen: 7 hours 58 min ago
These look great. Thanks for testing them!
I see that you tested the newer Sofirn 5000mAh 21700 cells. Do you have their original 4000mAh in the lineup? Seems like they’re still supplying that one with lights and few or none of the 5000 (but they sell it separately in their ali store).
HKJ
HKJ's picture
I have not tested the 4000mAh Soshine.
The best way to check if I have tested a cell is to check my website.
Find the pages with individual reviews and use the search function in the browser: https://lygte-info.dk/info/indexBatteriesAndChargers%20UK.html
