Replacement switch for Lumintop FW3A copper flashlight?
Hi, I’m hoping someone can help me figure out what to do about a Lumintop FW3A copper flashlight that seems to have a defective switch.
I ordered the light from China, and I really like it, but sometimes when the light is on, the switch gets stuck in the depressed position and cannot be clicked off. And sometimes when I am ramping up, I remove my thumb from the switch and it keeps ramping up by itself. I am concerned about the possible safety implications of a powerful light that won’t turn off.
I attempted to discuss this with the seller by email but to no avail. Can I get a replacement switch? Also I understand that there may be different versions of this model, so I would want to be sure to get the right switch.
I have no idea how to install a new switch on this light but I’m pretty handy so I could follow instructions. :slight_smile:
Many thanks for any help you can offer.
Peter
I would start by removing, cleaning and reassembling the tailswitch… there is not a lot in there that can cause the switch to stick… hopefully you will be able to solve that…
I dont know if Lumintop sells spare switches… suggest you email them and ask
hope you get the light working properly, soon
Hey Jon, Your suggestion worked! Thanks so much. -Peter
congratulations! :+1:
I have a similar tail-switch problem with my FW3A. It doesn’t turn on the light.
Bought it from Neals Gadgets during the Father’s Day Sale, together with a SS bezel, sapphire lens, and (my poor decision) a 18350 tube. I enjoyed having it as my regular EDC for several weeks…until I finally decided to try changing the 18650 tube with the 18350 tube.
Very difficult to open the tail-switch. That was when I messed up the tail-switch. Parts inside fell loose. I couldn’t turn on the flashlight with the 18350 tube. And when I returned to using the 18650 tube, it also wouldn’t work anymore.
I have sent an email to Neals’ hotmail. But no response.
I have sent a similar enquirty to Lumintop China. And one response from “Victor” just advised me to reassmble the tail-switch. I couldn’t.
I want to find out whether I can get a replacement tail-switch from either Neals Gadgets or Lumintop China, since this FW3A is only about three months in my possession.
One lesson learned: Don’t open the tail-switch of this flashlight!
Just revisiting this… I know it’s like 2.5 years old, but I thought I’d add a little of my experience here.
First, the very early FW3A flashlights had no retaining ring in the tail cap. They did this probably for cost savings on manufacture. But it created a tragic vulnerability. Most people are used to taking off the tail cap to get to the battery. And when you do that, the loose parts can get jostled, or even fall out. Putting it back together is a delicate matter and can result in some things out of alignment, causing the switch not to work properly.
The 2nd production run (and all others going forward) introduced the tail cap inner retaining ring, which eliminated that particular vulnerability, but… it didn’t solve the other problem–the inner connecting tube. You really shouldn’t ever need to disassemble the tail cap. It sounds to me like you had the inner tube connectivity fault, and by disassembling the tail cap there’s either a misalignment or a missing part.
The design fault of the FW3A, as I see it, is that the distance between the connecting ring on the mcpcb is very close to the metal retaining rings. It’s so narrow that if enough conductive debris builds up inside it, there ends up being a short. Also, upon periodic battery changes, if the tube isn’t treated super carefully, some of the anodizing can get worn off along the edges… which will guarantee a short.
My early FW3A shorted out only once, years ago, and hasn’t since I made sure to thoroughly clean the contact rings and the inner tube. And I always replace the battery from the front.
A 2nd production FW3A I own that I decided to convert to 18350 then 18500 has been problematic. As 18350, it was infuriatingly unreliable upon reassembling after a battery change. I’d have to fiddle with it a lot to get it back to working again. It nearly suffered a battery explosion when it shorted out unattended. Thankfully I got to it in time.
I had tried TWO different 18350 tubes and both were problematic, so my last attempt was an 18500 tube. That has been more reliable. However, I have to clean the inner contact points periodically or else it suffers shorts.
The FW3A is an historic flashlight, the first most widely successful implementation of Anduril. But, it has been surpassed. Lumintop made no effort to fix the original problem, except to release a side switch version that solved this issue, the EDC18. I have to believe FW3A sales have dropped off significantly. Even the top of the line LM10 inventory hasn’t been depleted and is frequently offered at super discount prices. It’s sad that it came to this.
The switch shorted? How could that make it explode?
It wasn’t the switch shorting. It was the circuit tube.
If a flashlight goes “runaway” and cranks up to turbo, with an unprotected cell, and the driver’s protection algorithm is bypassed? The flashlight will overheat and that’s a risk of possible battery explosion.
Like setting temp regulation to 90° or something? Yeah, that could end up badly.
