As a followup, I think C8 is a good standard to measure throw since it is probably the most popular host and works with most emitters. For example, I’ve never seen someone attempt to put a SBT 90.2 in a S2 body.
The SST40 with 80 kcd has a 5A driver, and the CULPM1 with 210 kcd has a 7A driver. I also have XHP70.2 in C8 sized hosts and they have 30-35 kcd at 6V and 5A. The 30 kcd has color temperature of 4000k and the 35 kcd is at 6500k.
SST70 and SST40 are both 5050 size although the emitting area is a tad larger on the SST70. But given SST70 can push 3500 lumens I would assume that it can get close to 100 kcd in a C8. I think a SFT40 would push 150 kcd or so but it would be nice if someone here has actually tested it.
