The OPEN Mini is a short bolt action EDC ballpoint pen. At only 3.66 inches long, this pen is short to put in your shirt pocket. Its tough aluminum body has dynamic hollow helixes that increase grip and just look amazing. The style is further enhanced by the blue body ring and ornate copper tail cap. The customized refill writes smoothly and won’t become empty until it finishes 800 meters of lines. The L-type bolt action is intuitive to pop out and retract the pen tip. With the pocket clip, you can conveniently clip it to your notebook, pocket, or backpack strap. - OlightWorld.com
Any deals for an Olight M2R Warrior Pro in black color?
I checked in the olightstore.com during the fan day promotion but couldn’t find it. The only place I see where I can get one right now is ebay.
EDIT, checked again today and found it at olightstore, not sure why I couldn’t find it during the sale but it wasn’t coming up. Also see it on amazon now too.
On ebay all the listings are around $20 higher now, I guess they were able to list the sale prices, but now have gone back to MAP?
Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized to military grade specification type III, anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
Water resistance i.a.w. IPX-8
Mode Memory: memorizes the last brightness level used in the general modes (except Strobe)
Low Voltage Protection: If the battery’s voltage is lower than 2.8V, TS21 steps down automatically to avoid battery damage by over discharge. At 2.7V the flashlight will turn off automatically.
Advanced Temperature Regulation (ATR) technology: By default ATR will reduce the brightness level automatically when the driver temperature reaches 45°C to prevent overheating. You can set a different temperature threshold by following the thermal configuration guideline.
Firmware: TS21 uses open source software called Andúril 2.0, distributed under the terms of the GPL v3. The source code is available from http://tiny.cc/TKAnduril
