The bombs available here often fail to ignite. And I hate cleaning up after them.
Fizz is lethal to any flea trying to bite her, and will be for the next 6-9 weeks. And in 6 weeks I'll dose her again - at huge expense but it saves a lot of bites on me.
And the whole house smells of flea killers. Since that stuff smells vile, I baked some bread - it smells a whole lot better.
In another country I fumigated a house with hydrogen cyanide. Then left out sodium azide and sugar solution to see off the ants and roaches. The cyanide fumigation was to get rid of the bats (Which in the UK would earn me a prison sentence, they are very protected here).
I blame the flea outbreak on a bat that got into the house early this week. I suspect the little @£$^% left a few unwanted passengers behind. I spent Tuesday night from midnight till 2am trying to get the little @^&^&^ back out of the house.
Likewise, I vary the treatments, but I defy anything to gain immunity to cyanide or azide - but they are a bit hard to buy here. Attempts to buy sodium/potassium cyanide here are likely to be greeted with arrest under the Terrorism Act - as will taking photographs in public places but that's another rant.
It's not that hard to make your own though...
Azides are a bit harder but any scrapyard will get you more than you ever want to be exposed to - that stuff is way more dangerous than cyanide. But they are not good things to have around in the company of a large and very hungry dog.
Doesn't seem to be here in the UK - not that it would be a big deal getting it online. I used Indorex and have had no bites in 36 hours now. That plus Frontine on Fizz and a lot of effort with the vacuum seems to have got it under control. Remember to make sure you have insecticide in the vacuum bag or the fleas will just walk out of it afterwards.
Fizzy has never been scratching so evidently wasn't bothered by any bites she may have had.
Took cortisone to sort out the nasty bites on me. But I am very run down just now (doing 4 people's jobs for 5 months will do that to you) and my immune system appears to be on holiday.
On the bat problem... How about a Ultrasonic generator to drive them off?
PS: On the other chemicals you are mentioning (LOL).... Remind me to wear my hazmat suit when I come over to your house.... burn it before I get in my car to leave...
Have you tried Diatomaceous Earth, Sevens Dust, Boric Acid?
Problem solved, the weather has turned a lot cooler and he bedroom window is now closed. It's the only time I've ever seen a bat indoors here. They are heavily protected by law here so you do have to be a bit careful about discouraging them.
I haven't done alot of research on bats, but a Ultrasonic generator would be a non-lethal way to make them go elsewhere....
Ultrasonic generators are used for non-lethal pest control. Imagine a recording of a song, noise that you really hate playing over, and over, and over... It's sort of like that for the pest, although I could see some kind of laws applying if used OUTSIDE your home as bats hunt by sound.
Description:
An electronic pest-control device which includes a plurality of electrically energizable ultrasonic transducers, each of which is operable within a different range of ultrasonic frequencies. Circuitry is provided for simultaneously energizing the transducers, with each generating ultrasonic waves whose frequencies are continuously randomly varied throughout the transducer's operating range. The ultrasonic waves generated by the device are directed into an area desired to be kept free from infestation by pests, such as rats, which are sensitive and responsive to ultrasonic energy. Through the use of a plurality of different, continually changing frequencies, the pests cannot become acclimated to the ultrasonic waves and thus become immune to their effect.
So slightly relevant to flashlights. If you get a bowl of water, add some dish soap, and point a flashlight/light source at the bowl at night, it makes a flea trap. You can use Dawn but also Jet Dry but obviously be cautious of animals drinking the water. They can live up to 24 hours in water so make sure you flush it. You can also rinse fleas combs off in a bucket with Dawn water instead of putting them in the trash.
The dogs use an oral 180 day flea medicine these days and don’t have the negatives of flea medicine on their backs.
diatomaceous earth (DE); not poison, but don’t breathe it, I rub it into my cats fur and sprinkle it around out of the way places; you can also mix it into your pet’s food for internal pests. I buy mine at Walmart; it’s also used in some swimming pool filters.
I will second DE, but it needs to be paired with one of the decent sprays or bombs. I our part of the midwest, fleas are a way of life. For a month or so in the summer, depending upon rain amounts, you cannot walk across the yard without your feet getting covered. Our cats are indoors and never, I repeat never go outside. But, they have them every summer thanks to human foot traffic.
I have 4 neighbors cats around all the time, one of them is sleeping on the sofa right now.
For infestation sprinkle food grade Diatomaceous earth but also use flea killer spray (I got mine cheap off eBay). Spray generously just before leaving the house for a few hours. Air your house afterwards properly.
I only had one infestation and after doing above started using 24/7 water tray flea trap with S21A flashlight at the end(I tried several including cheap zoomies and S2+).
Water tray is excellent because if any fleas come off an animal, rather than you being target they will most likely go for the light. I only had a flea a few times where there is at least 1 or 2 fleas in the traps per day. You will probably need to spray more than once.
For water tray flea trap I found this to be the best combination after trying water only, water with white light and water with green and blue light:
Bright green tray (any color will do but green tray reflects green light the best)
Water with washing up liquid (to brake surface tension, I tend to put loads to deter cats from drinking it, not that they tried)
Convoy S21A (smallest Convoy 21700 and perfect size head to match throat for 750 ml and 1 L bottles. 4800 mAh Convoy battery, 1 x 71350 driver, Osram flat green on 20% setting. Lasts just under 2 days.
Small bottle to diffuse the light (I use cone shaped 750 ml “Harrogate Spa Sparkling water” bottle, it has some square pattern on the glass which diffuses light nicely and throat opening will seat S21A ok. It is maybe a couple of mm narrower that I would like)
Fill the bottle with water for light diffusion and anchor but empty and clean periodically to avoid Legionares.
Gaffa tape to stick S21A on the top of the bottle pointing downwards. I leave the tape on and bounce battery off the driver spring when replacing battery.
Once, one of the cats brought in some fleas, which grew like gangbangers.
I sprinkled DE all over inside that it looked as if Mt Vesuvius erupted in the living-room, and dosed all the cats with Frontline at least 2 cycles.
The FL works best, ironically, by letting the fleas land on and biting the cats, to get sick and die. And FL is ostensibly effective against all stages of fleas, not just when adults.
I’m sorry to hear the bowl of water didn’t work at all! I used it in the past and it has worked for me, not getting rid of all the fleas mind your, but aiding in the attack. I’ve worked up to a bowl full of them. It’s just stuff around the house and non-toxic so thought it was worth a shot.
