Does anyone here have an idea of what the best batteries to use for this would be? I just bought one and I want to double check that I'm picking the right batteries.
I'm looking at picking up button top versions of either 4x Molicel P26As (~25a continuous), Samsung 30Qs (15a continuous), or Sanyo NCR18650GAs (10a continuous).
I think the CSLPM1 won't pull more than ~9a per LED, correct? If that's the case, then I would see no performance benefit going for 30Qs or P26As over the Sanyos?
I want to make sure I'll be getting the absolute maximum performance out of it, and I'm happy to sacrifice some capacity for that, but if there's no benefit going for the higher drain cells then I might as well go for the Sanyos.
Those cells are probably in parallel, so figure 8 amps per emitter on Turbo, that’s 32 amp (barring losses for resistance, etc), so you’d be fine with GA’s, but to get the most out of it, go with Sony VTC6 (if you can find them). If you can’t find those, Vapcell rewraps them.
Thanks so much for your reply. I’m pretty sure I need button tops. I haven’t been able to find button top VTC6s in stock, or button top Vapcell rewraps of them. I assume 30Qs would be pretty equivalent, right?
Vtc6 hits a little harder and can sustain higher current for longer, basically the voltage sags less ss load increases. 30Q are fine, but GAs will be better I think due to the longer runtimes. That or LG MJ1 or Samsung 35E
I’m using flat - them works for me, not a single problem with connection, which is strange for me, because it shouldn’t work properly according to manual.
Well that’s…confusing. Maybe I just have to wait until it arrives to see what will fit in there. Though I suppose the safest bet would be to follow the manual and just get 4x button top P26As.
Maybe your VTC5As have slightly protruding flat tops? Maybe you could take a pic of the contacts in the light?
here are some photos from me - still unable to capture decent range shot, because in my country every evening is misty right now (warm days, cold nights), but at keast you can check beam profile
I’m sorry, but I can’t. I even don’t have decent app for lumen measurement with runtime graphs on iOS. Maybe someone could recommend me something? I’m thinking about invest some $$ in gear this kind.
I have the MT41, and I also have the Haikelite MT40, I could compare it to the Astrolux MF02 (XHP35 HI) and the Fireflies T9R (Osram CULNM1) that I also have.
But I tell you a quick conclusion, the MT41 is a great buy.
tonight I found good air quality outside and shot some beam. Here is comparison of Emisar D4Sv2 with 4xosram W2 and our Haikelite MT41 with the same led - guess which is which
Also tonight was first time I lit my MT41 powered by Murata VTC5A - I’m really impressed with turbo performance on those green batteries.
