Anyone who has followed my previous projects can guess that this year too I will build a caving headlamp
I.e.: a super durable, helmet mounted headlamp with a dual optics.
For this year challenge, I want to rebuilt a classic caving headlamp: the Petzl Duo
Since the 90's this light considered as the best caving light by the many cavers because of its great durability and waterproofs.
During the years many upgrades to the original light tried to keep it relevant with recent LEDs improvements but since the plastic body does not allow heat dissipation it could not provide same brightness as the modern lights.
In the 2nd post of the tread I will describe the history of this legendary caving light.
My dream is to make a light that will look as close as possible to the original light but will provide the same brightness as the modern caving lights, and of course to preserve the durability and waterproofing.
I am planing to completely rebuild the light:
1. Replace the old bulbs with new LED emitters.
2. Add a modern driver with my new FW.
3. Add an Aluminium heatsink to the plastic body.
4. Change the switch to a momentary switch.
5. Modified the 4*AA battery box to 2*18650.
Basically I am planing to change EVERYTHING, but since I am still using the original body I guess it need to be under the modification category....
Petzl DUO caving light modification
Sun, 09/12/2021 - 14:14
#1
Edited by: YuvalS on 10/28/2021 - 05:49
So I did some research on this iconic caving lamp.
1st generation
The first generation was introduced on 1999 (I thought it was a lot earlier around mid 80's)
It had 2 light source: a 6v bulb and a 6v halogen bulb.
The light come with one replacement bulb of each type and had a special place to store them.
I could not find data on how many lumens each bulb produced but it was very low.
The halogen bulb could move inside the reflector to change the beam type.
The operation of the light was very simple move the switch up turn on the halogen, move the switch down turn on the regular bulb, switch in the middle - turn of.
While in of mode the switch had a mechanical lock off.
Models:
All generation had few variations: (I don't have all the variations so these pictures are from the internet)
1. Duo - the original headlamp with rubber bands
2. DuoBelt - with longer cable and bigger battery box for 4 C cells to carry on the belt (reduce wight on the head and can keep batteries warm under the closes)
3. Fixo - to mount on a helmet.
4. ATEX - (black color) for hazardous areas (explosives etc.)
5. Explorer - Fixo + Aceto (Carbid lamp) mounts on an EcrinRoc helmet
2nd generation
An upgrade with 5 LEDs was introduced on 2006.
It was a simple PCD with 5 LEDs connected direly instead the old 6v bulb without any driver.
The operation was kept simple (on/off)
The PCB was also sold desperately as an upgrade to the 1st generation
The 5 LEDe output was 40 Lumen for 28 meter and last 65 hours.
The halogen beam was for 100 meters and last 4 hours (no lumen data)
For this version also the locking mechanism for the switch and battery box was made from Aluminum instead of plastic (probably after costumers complained)
I only have the ATEX version for this generation but of course there was also a regular version (and also belt, fixo, explorer...)
3rd generation
An upgrade with 14 LEDs was introduced on 2008.
Petzl kept the old halogen bulb with zoom option but offered an upgrade to the led PCB.
The PCB was a lot more complicated with a regulated current and 3 mode of operation:
Maximum: 34 meters, 110 hours, 67 Lumen
Optimum: 36 meters, 148 hours, (no lumen data)
Economic: 15 meters, 183 hours, (no lumen data)
The halogen (same as before) 100 meters, 4 hours (no lumen data)
I only have the Spelios version for this generation but of course there was also a regular version (and also belt, fixo, ATEX...)
Spelios is the successor of the explorer. 14 led Dou mounted on Elios helmet without Aceto
That is the actual light I am planing to modified since it is already mounted to my favorite helmet
4th generation
The last official upgrade by Petzl for the Duo was 1W LED to replace the original Halogen bolb.
since it fits to the same place it also had the zoom option
Unoffiacal generations
Since Petzl stop upgrading the Duo light (they do make some models named DuoZ, DuoS etc. but not related to the original Duo except from the name)
Some very talented cavers start making their own modules to upgrade the Duo.
The most famous is a British lights manufacturer John Biffin who sells them under the name Customduo.
I have 2 of his modules, 1 to replace the Halogen and one with 2 emitters
As you can see the limitation of this modules is heat dissipation so the maximum brightness is around 500 Lumen
This post turn out to be A LOT longer than I thought but I think it explains the history of this light and the reason it is impotent to me to keep the tradition and to upgrade this model to the most advanced LED technology.
Hope i didn't bore you too much
My FW repository
My BLF/OL contest entries: 7th | 8th | 9th | 10th |
Here for the show
Good luck for the contest and the mod
MY REVIEWS THREAD /// My Flashlight Collection /// YouTube Channel
Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Review's Blog (PT) /// OL Contest 2019 /// OL Contest 2020 /// OL Contest 2022 /// GIVEAWAYs: 1 / 2 / 3
Nice historical review. Best of luck / good fortune.
BLF Member Map, add yourself
My 10th Annual contest entry.. My 9th Annual contest entry. My 8th Annual contest entry.. My 7th Annual contest entry.. My 6th Annual contest entry... My 5th Annual contest entry... My 4th Annual contest entry...
My DBSAR inspired SRK lantern hand made mod
I suppose water resistance is important. That gets to be a challenge for sealing and cooling at the same time while retaining the original “look”.
Today I started Working on the light
Sine I want to restore this light for a long time I did some research a while ago and figure out that to enable decent brightness I will have to allow the heat dissipate from the sealed body using an external heat sink so the first step was to remove all the old components from the body and make some place for the new components and heat sink
1. Take everything apart
2. I mean everything
3. Remove unnecessary plastic supports (don't worry I will add Aluminum supports instead)
4. make place for a rear heat sink
5. And now it is ready for the new components
My FW repository
It is the big challenge in this protect I hope I will mange to do it Although I don't like using glue, I think that it is the best option for this mission.
My FW repository
With my wood lights, I sometimes joke that I don’t worry about making them waterproof because the glue I use is not waterproof.
Looks like a good start.
Thanks for the reserch. I came to speleology only 10 years ago and have not seen duo era. Very interesting.
Good to see you are making a good light for caving, YuvalS.
Water Cooled MT35 PLUS RE-MODDED------MT35 Plus with SBT90.2 mod ( GT90 kit from Texas Ace )
7th annual BLF/O-L contest Haikelite MT07 upgraded-----8th annual BLF/O-L contest “SKELETON”
Water Cooled 20K lumen POT LID LIGHT------ Cyclops 18M cd flashlight Mod------Q-beam mod to led
Convoy 4x18 Luminus 90.2 mod with 86mm reflector
Think outside the box too long , cannot find your way back in
A waterproof wooden lights sound interesting, consider use another glue
I still see some cavers using them, mostly with the CustomDuo inserts but they are rare now
That is the only type of lights I build
My FW repository
Had some progress with the body today.I cut 4mm aluminum I had at home to the shape of the internal space of the light in order to have some mass to absorb the heat and conduct it to the rear end where I will place the heat sink.
Cut cardboard templates
Saw it using a Jigsaw
First I glued it in place with heat resistant RTV
Then I glued it with headsink plaster
And clamp everything together till it dry
My FW repository
I use the hide glue because it cleans up very well. The waterproof wood glues can appear to have the squeezed out glue cleaned of completely but sometimes when one clear coats (or stains) you see a difference in coloration where there was a dried and near invisible film of waterproof glue. It doesn’t always become apparent until too late, after clear coat has been applied.
A water proof wood light might float. Could be a cool idea. Maybe I’ll have to think about that one. Include a motor and propeller/fan that could cool it in air?
I spend a lot of time waiting for wood glues to dry.
A bit more progress today:
I had to file the heat sink so it fits to the roundish shape of the light and the helmet and also to add small piece of aluminum to fill a small gap left a the side of the light
Using the cardboard technique to find the correct shape for the heat sink
Fitting the aluminum piece for the small gap
Gluing everything with thermal plaster
And waiting....
My FW repository
After the Heat sink plaster cured, I did s bit more sanding to fit it perfectly to the helmet mount (had to leave a small gap to allow airflow to help with cooling.
I also drilled the place for a 12 mm waterproof momentary switch
Then, I drilled a hole for the switch wires (winch I forgot drilling before gluing :facepalm)
And (as promised) sealed all gaps between the aluminum and the original body with glue to maintain waterproof
My FW repository
That heatsink looks nice, definitely better than only plastic.
Good job with cutting and squeezing in the aluminium heatsink parts.
My Youtube channel: Alllightson Reviews
My OL contest builds: 7th 8th 9th
My reviews: Sofirn SP31 V2, Nightwatch NI40, Sofirn C8F 21700, Brinyte WT01, Sofirn SD05,Ti AAA keychain, Sofirn SP33 V3, Skilhunt M150
My video-reviews: Brinyte WT01, Sofirn SD05, Ti AAA keychain, Sofirn SP33 V3
Good to see progress.
I’ve been stalled.
I took a break from working on the body and moved to the battery box.
Although the body is more interesting, the real challenge for me in this build is the battery box since it was designed for 4*AA batteries and the it is really hard to squeeze bigger 18650 cells into it.
another problem is the contacts, since I want to use 3.7V, one contact have to be placed on the lead and I have to find a way to wire this contact to the bottom part. I really have no Idea how to do it without risking with contacts or wiring problems.
Anyway, the first step was to remove all the old AA parts. Because the plastic structure is deep and none of my tolls was able to remove all the old parts and make place for 18650 I had melt the plastic at the bottom of the box using my old soldering iron (did it in a well ventilated place to avoid birthing melt plastic
Original AA contacts
After melting the bottom parts
Not enough place for 4 cells
My FW repository
This project is up my alley! I’ve modded/retrofit l9ghts from incandescent to LED and it’s not easy so great job so far. For the batteries have you considered using 14500’s? They are not as high capacity as 18650, but you can use them in parallel for more capacity. Or just use 3 18650 unless you need series or series/parallel.
Imagine 8 × CR123As…
(16mm, not 18mm.)
Thanks Guys.
I have chosen 18650 cells for few reasons:
First, I have tons of 18650 from old laptops so it is practically free.
But more important, in caving we always carry 2 or 3 lights for backup and spare batteries for each light. So it is easier when all lights are running the same battery size so I only have to carry one type of cells.
Single 18650 headlamps are very common and I have few so it make sense to use 18650 for this light too. It also allows me to borrow cells from friends in the cave in case I am running out of cells
It is also the reason why I chose no to use 1S2P pack that can solve a lot of problems and make the built a lot simpler.
My FW repository
Nice, “planning to change EVERYTHING”. Looks like an epic modification
Building a boat, are we?
Tanks PP, everything but the host
We should have a Budget boats forum
My FW repository
A bit more progress today with the battery box today,
I decided to use only two 18650 in parallel so I will have space in the box for wiring and the cells will sit in the center of the box to keep it balanced.
Two decent capacity cells will last a whole day of caving on low (~150 lm) to medium (~300 lm) brightness with short periods of Turbo (~1000lm).
Placing the springs at the bottom of the box (and not on the lid) will pop the cells out so I guess it will be easier to changes cells.
First step was to create a template for the lower board
Than to copy it to the Prefboard (on the right is the prototype
And cut and solder springs
I know that many BLF members are bypassing the spring but since my "Turbo" is only 2.8A, I decided not to use bypass.
Next step is it the wiring, I have some Ideas how to connect the contacts on the lid but still not sure what is the best way
My FW repository
And if that 2.8 amps is supplied by two cells in parallel it is only 1.4 amps per cell. IMO, you don’t need to bypass the springs.
Exactly what I am thinking
Didn't have a lot of time today so I only made a small progress with the battery box wiring.
) for the wire connecting the battery box to the lamp.
I decide to use screws terminals (not sure if it the correct English term, in my language we called it chocolate connectors since it looks like chocolate table
The reason I prefer screws over soldering is that most caving lamp issues are related to the cable and using screw will allow some troubleshooting "on the field".
The black wire is for the negative pole on the lid but this will be explained on the next update...
My FW repository
As promised, today I made the wiring from the power cable to the lid.
I considered many option and the two best option IMO were:
1. A dummy cell to conduct between the bottom board and the lid.
2. A wire (with or without connector)
I decided not to use a wire since I am afraid that frequent battery changes may cause contacts issues along the cable or at the soldering points and as a primary caving lamp I need to be super reliable.
For the "dummy" cell I used an old piece of Polypropylene I have from another project
I cut and sand it to fit inside the battery box with a small groove for the 18650 on the other side.
The top part had to be smaller to allow closing the lid
After a lot of hand-sanding it fits perfectly
You can also see the drill for the wire at the center
Currently I am planing to only use a single dummy cell and use some kind of foam to support the cells from the opposite side since:
1. It is lighter
2. It is less work
3. A foam will prevent the cells from rattling in the box.
My FW repository
Looks good to me.
