2xCR123A Flashlight Recommendations
20 posts / 0 new
CollectEverything
CollectEverything's picture
Last seen: 1 hour 1 min ago
I’m looking for a light to leave in the car with a baggie of CR123A cells. I’m looking for a 2*CR123A light minimum. More cells would be fine but 1 is too little capacity. This is to function as an emergency light. I’m not looking to spend over $40 and less is better. I do want to have a reliable light though.
Is it safe to substitute CR123A batteries in most 18650 lights, or does the driver need to support it?
I notice that on http://flashlights.parametrek.com some lights like the Thrunite TN12V4 are listed as being compatible with CR123A lights but I see no mention of it on the official product page.
Thanks!
EDIT: I’d prefer it if the light can take CR123A OR 18650 batteries. That way I could potentially swap my 18650 out of a hotrod EDC light and get a ton of runtime from the emergency light in an emergency where runtime mattered more than quantity or quality.
My Collection
Edited by: CollectEverything on 10/01/2021 - 11:40
xevious
xevious's picture
Last seen: 2 days 2 hours ago
What’s driving you to go with CR123A versus 18650? Is the idea to have CR123A vs. RCR123, so they’re one-time-use disposable cells? Or do you have a boatload of CR123A cells that you just want to use up?
Since this is considered a spare light, you could check the used market for an older flashlight and save a good bit. Olight, Nitecore, and Fenix have had a lot of 2xCR123 lights in the past. But then again, you could go with a new Convoy S2+ with SST-40, for $23… and it handles both 2xCR123A and 18650.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 8 min ago
There’s an inherent danger in using series-connected cells, even a pair of ’123s. I had a pair go China Syndrome in my MH20, enough to melt the wraps. Both ended up sub-volt by the time I got ‘em out, so nfi what happened. And the light was off, sitting on a table, minding its own business.
No matter what, they won’t drain perfectly in sync, and the runt of the litter will go dead first, probably start reverse-charging, and then all sorts of Bad Things will happen. Maybe even just sitting around.
If you insist on going the bag o’ batteries route, keep the light empty, and only load it when you need to.
That said, most Nitecores do 18650 or 2ב123, a bunch of newer Sofirn and Wurkkos, etc.
CollectEverything
Since this is considered a spare light, why not go with a used flashlight? Olight, Nitecore, and Fenix have had a lot of 2xCR123 lights in the past. That way you can easily keep it under $40.
But then again, you could go with a Convoy S2+ with SST-40, for $23… and it handles both 2xCR123A and 18650.
I live in an area where subzero temperatures during the winter are normal. I’ve read that primary lithium cells offer the best performance in those conditions. I’ve also read that 18650s do not perform the best in cold. If I really want to leave the light in the car all year then CR123A cells seem like the best solution to me. This truly would be a backup light too. I already EDC an 18650 light.
Thanks for the heads up on the Convoy model. I’ve been meaning to buy a Convoy one of these days. Might just go with that.
My Collection
ChrisGarrett
ChrisGarrett's picture
Last seen: 16 hours 32 min ago
“I’m gonna with a ‘naw’ dog.
Too many quality 16650/18650 lights out there, to fiddle with smaller ‘series’ lights, IMO.
Chris
CollectEverything
I did plan to keep the flashlight empty.
It’s funny, I recently ordered a Sofirn SF47 which has two 21700 cells in series. I didn’t even really think about that. I plan to charge the batteries in good charger though so I should be able to detect a cell dying (hopefully)
My Collection
pennzy
pennzy's picture
Last seen: 12 min 2 sec ago
What type driver does this S2+ have? I ask because there is no mention of 2xCR123A compatibility in the link. Wouldn’t it need a buck driver like a Sofirn SP32A to handle both?
CollectEverything
You live in Florida so the coldest it gets like like 30 degrees F. Where I live it dips down as low as -20 degrees F basically every year and can easily go lower. Lithium primaries should outperform an 18650 in our winters.
My Collection
CollectEverything
I would like a follow-up on this question from anyone who knows.
My Collection
TIFisher
Last seen: 1 day 18 hours ago
I’ve kept a Surefire G2X PRO in a GHB in my work vehicle for the last 5 or 6 years, all 4 seasons, loaded with SF branded CR123’s with no issues. Even though it’s a mechanical clicky, I do the tail cap lockout to prevent accidental activation in the bag. I swap new in batteries once a year or so, and use the rotation set individually in my Malkoff MDC HA. I always use new batteries from the same batch, and meter the voltages prior to installing. Gifted one to my son years back for the same purpose. He’s still alive.
pennzy
pennzy's picture
I live where it gets in the single digits and never had a problem with 18650 lights in the glovebox.
Correllux
Correllux's picture
Last seen: 21 min 55 sec ago
If it’s subzero all day long, but really even just for 10-12 hours overnight, I’d be inclined to get in the habit of having a little go-bag that comes indoors with me, keep it by the keys and carry it to the car each time. Slight hassle but I do the same (without bag) with gloves and a hat. This way your batteries and the light body are at least starting out with a little warmth even if that gets sucked away before too long. Would be smart for the primaries but also for li-ion.
I was thinking a buck driver would be necessary, too, but I’m not certain…probably depends on each particular driver and the chips used. For that matter, is there a low temp limit for any of these processors and such?
xxo
Last seen: 4 min 15 sec ago
Streamlight Poly Tac – they have several configurations to choose from:
https://www.streamlight.com/products/product-series/polytac
BTW to avoid problems with 2 CR123A cells in series don’t mix cells – always use 2 new cells from the same package and check their Voltage, don’t use Chinese made CR123’s and watch out for counterfeit cells.
xevious
xevious's picture
I’m not totally sure about the driver. While the light specification doesn’t call out 2*CR123A, a reviewer had mentioned using them with no problems. And if it’s just for infrequent use, shouldn’t be a problem. I just wouldn’t run the light on turbo for many minutes.
Lightbringer
Howbow just getting a SC21? Kick-arse little light, think it comes with its own 16340 but nothing’s stopping it from using ’123s.
https://budgetlightforum.com/node/78829
Forsythe P. Jones
Last seen: 1 year 3 months ago
There are some special ($$$) 18650s made for cold weather. Also if you don’t require super high output, you could get an AA powered light and use lithium 1.7 volt L91 cells in it. That would also give you the option of alkaleaks if you have to.
TheIntruder
Last seen: 1 day 20 hours ago
SP31v2 and SP32Av2 both take said cells…rated for 7.2v max before releasing the magic smoke.
CollectEverything
Thanks for the recommendation but I was hoping that the light would actually take 18650s too if needed. I should have put that in the original post.
My Collection
CollectEverything
This looks like a really solid option. Only ~$20 from Aliexpress. Thanks! Thumbs Up
My Collection
CollectEverything
I’m planning to make a go-bag too at some point, but in my opinion a car emergency kit should stay in the car. It wouldn’t do me much good if I forgot it at home!
My Collection
