What did you mod today?
Welcome to BLF ‘zumlin’ :sunglasses:
Nice mod, I love the color. :heart_eyes:
I second the appreciation for that ano color. Which this deep violet would be more common.
Welcome and nice mod!
Nice. I love the violet host for UV…wish Simon would sell them already made up that way. Sounds like a smart build going for series/buck. Can you nip a coil from the tail spring and gain any room?
Great photo, btw!
wow that light is beautiful! welcome!
Have a pleasant time at this friendly forum, zumlin!
Nice shade of violet!
It won’t help unfortunately. It is actually the retaining ring of the switch that is pushing against the battery.
Thank you Firelight2, this is very informative!
So, maybe I could build a D3A around that 15mm driver from copper and current.
Cheers!
You could also try filing down the front-most few threads on the pill so that it screws in further
Jetbeam TCR-1 mod to sw45k
I plan to put together a l6 convoy with a luminus sft70. Do you know of a 30mm driver for this 6V led? I need a strong one because surely this led will last more than 10A
It may not be 10A, but can’t you just use the XHP70.2 driver that is made for the L6?
Should work fine. There’s a notable lack of enthusiast drivers (particularly, anything using Anduril) for 2S input
Got my second shipment of FD2 bin SST20s last night.
Immediately installed half of them into my DQG Tiny IV triple and my modded Emisar D4 with lighted metal switch.
I love this emitter! Blows away all other SST-20s I’ve seen. Creamy rosy tint even at low power settings. Makes even the SST-20s that came with my FWAA look like crap. Much rosier than even XPL HI 5D.
I think I should order more.
I built Convoy M21C with Xhp35.2 6500K 80cri from Kaidomain. I used Convoys 12V 2,5A boost driver with it.
Hotspot had weird yellowish center with tiny blue dot in it. Around that yellow area beam was about 6500K as it should.
After some use emitter had donut hole symptoms and I checked the reason. Whole emitting surface was charred black. I cleaned it and underneath the black stuff the led was perfect. After that I tried it again. No more yellow area and no more charring.
Seems to handle 2,5A well. I don’t know the reason for charring. I cleaned the led with q-tip and electric cleaner just before closing the bezel. After the charring I cleaned it with same method and it seems to work just fine.
Maybe I burned and cleaned extra CRI values away. :smiley:
Edit: corrected typo
only 5A? I think it would be wasting a sft70
There’s 30mm FET driver for 2S input (suitable for L6 with XHP70.2). Would that work?
that might be too much. can you show a link anyway?
There was a 5 A driver but I can’t find it at Convoys.
Would this GT FC40 Driver and switch for Convoy L6 be adequate? How much current?
30mm FET from Mtnelectronics. I’m on mobile or I’d link it directly. Suitable for 6v emitters with 2s input.
GtFc40 is 12 emitter
So that GT FC40 would be a 12 Volt emitter. Didn’t know as not much stated on Simon’s listing. There was some talk about on the forum, but it wouldn’t be getting anywhere so I dropped the thread. Basically new LED and not much known about it.
Would be nice to have the link, always less hassle in trying to get some info without all the fuzziness. Still curious about the current output. Richard doesn’t commit to any ballpark values (I suppose that’s because it could have multiple input configurations).
Pardon my interest as isn’t altruistic but for myself – was looking to build such light with an SFT70.
