Great photos!
Thanks for the photos
Thanks for reviewing!
Does the spill of the IF22A appear to be brighter near the edge compared to the IF22?
I would’ve thought there’d be less spill with the TIR.
Very nice in-depth review.
I like the Sofirn IF22 and Thank You for all the pics, they really help determining their capability.
I have a Manker U22 with a xhp35 led and it is my usual go to light, so maybe I need to get one of these, Thanks
The spill of the IF22 is much brighter than the IF22A. The TIR produces a very floody, low intensity spill while the reflector has the normal beam of a small thrower: bright spill with a sharp cutoff and small spot.
This picture shows a secondary “spill” which is caused by reflections from the glass lens and the rim of the reflector. With normal exposure you only see the “inner” spill and two spots (or one spot with pretty bright corona).
Just an outstanding review. Lots of cogent visual information without the ridiculous 900 useless and redundant glam photos that many reviewers tack in their reports. I love your brief, concise, yet thorough descriptions and observations. The quality beamshots and comparison presentation is stellar. Benchmark review material, right here.
Thank you for your time and effort. Reviews like this make it so much easier to come to a purchase (or not) decision.
:+1:
Would the Astrolux EA01 be similar in beam profile with the SST40.?
I don’t have the EA01 for comparison, but the optics looks very similar. The SFT-40 without the dome in the IF22A should have a smaller hotspot and can be driven harder (but I don’t think it is – haven’t done any current measurements except for quiescent current which oscillates between 95 and 125 µA, a bit high).
Very nice review!
I guess the spill from IF22 reflector is more usable at closer range in lower brightness.
The If22A needs to be cranked to turbo or higher current to be used at closer distance eventhough the flood is nicer.
So IF22 is better multipurpose light than the If22A TIR.
That is also my opinion. The IF22A is nice for large distances and the low spill helps to get some context to prevent tunnel vision. The IF22 is more universal but I prefer a second floody light.
Nice review! It looks like they throw about the same distance from the shots, though hard to tell. They are saying the IF22A throws a little better, but I see you noted the IF22 throws a little better?
Indeed, it’s really hard to see because there are so many trees in the foreground and no real target in the center. I tried to make better photos over an empty field, but the difference is hard to see on the photos (but visible in real life!).
I’ve just measured the intensity via my phone (not sure about its linearity, but I also use it for the runtime measurements, so …) and I got about 25% higher intensity with the IF22 (14200 pseudo lux) compared to the IF22A (11300 pseudo lux) pretty consistently. So the measurements support what I saw while making the beamshots.
Great review. I’d really like to see someone do a direct compare between the Thrunite Catapult Mini and the IF22A. Anyone here have both?
Nice review! it’s impressive. I like those photos!
Barry, I do not understand, why is such an inferior driver placed in this nice light? You have the driver of the SP35 available.
I like the review, and I like the IF22A in my hand, but it could have been near perfection with a better driver.
well, if you love the buck driver of SP35, please choose SP35. Thank you for your support!
Although I do like the driver of SP35, the IF22A is an interesting thrower, that the other flashlight is not. Actually I have supported you, by buying an IF22A, and an IF22 prior to all the reviews. Friends of mine liked them, but I had to explain, what is hidden underneath the good package, so now I am waiting on an order of two SP35 and only one IF22A for them.
There are a lot of products, that are "very good in almost every aspect, but..." . I hope you can release a new version with a better driver, so there is no "but...".
Greetings!
Buck drivers are nice, a d we all like linear output, but they’re more expensive and can’t drive an LED as hard as an FET driver can. It’s a trade-off.
Thank you for your feedback! Our SP31V2, SP35, SC21 and SF47T are placed with buck drivers. the new products SP33S (up to 5000LM) and C8L (thrower) will come out with buck drivers too.
