The spill of the IF22 is much brighter than the IF22A. The TIR produces a very floody, low intensity spill while the reflector has the normal beam of a small thrower: bright spill with a sharp cutoff and small spot.
This picture shows a secondary “spill” which is caused by reflections from the glass lens and the rim of the reflector. With normal exposure you only see the “inner” spill and two spots (or one spot with pretty bright corona).
Just an outstanding review. Lots of cogent visual information without the ridiculous 900 useless and redundant glam photos that many reviewers tack in their reports. I love your brief, concise, yet thorough descriptions and observations. The quality beamshots and comparison presentation is stellar. Benchmark review material, right here.
Thank you for your time and effort. Reviews like this make it so much easier to come to a purchase (or not) decision.
I don’t have the EA01 for comparison, but the optics looks very similar. The SFT-40 without the dome in the IF22A should have a smaller hotspot and can be driven harder (but I don’t think it is – haven’t done any current measurements except for quiescent current which oscillates between 95 and 125 µA, a bit high).
I guess the spill from IF22 reflector is more usable at closer range in lower brightness.
The If22A needs to be cranked to turbo or higher current to be used at closer distance eventhough the flood is nicer.
So IF22 is better multipurpose light than the If22A TIR.
That is also my opinion. The IF22A is nice for large distances and the low spill helps to get some context to prevent tunnel vision. The IF22 is more universal but I prefer a second floody light.
Nice review! It looks like they throw about the same distance from the shots, though hard to tell. They are saying the IF22A throws a little better, but I see you noted the IF22 throws a little better?
Indeed, it’s really hard to see because there are so many trees in the foreground and no real target in the center. I tried to make better photos over an empty field, but the difference is hard to see on the photos (but visible in real life!).
I’ve just measured the intensity via my phone (not sure about its linearity, but I also use it for the runtime measurements, so …) and I got about 25% higher intensity with the IF22 (14200 pseudo lux) compared to the IF22A (11300 pseudo lux) pretty consistently. So the measurements support what I saw while making the beamshots.
Barry, I do not understand, why is such an inferior driver placed in this nice light? You have the driver of the SP35 available.
I like the review, and I like the IF22A in my hand, but it could have been near perfection with a better driver.
Although I do like the driver of SP35, the IF22A is an interesting thrower, that the other flashlight is not. Actually I have supported you, by buying an IF22A, and an IF22 prior to all the reviews. Friends of mine liked them, but I had to explain, what is hidden underneath the good package, so now I am waiting on an order of two SP35 and only one IF22A for them.
There are a lot of products, that are "very good in almost every aspect, but..." . I hope you can release a new version with a better driver, so there is no "but...".
Buck drivers are nice, a d we all like linear output, but they’re more expensive and can’t drive an LED as hard as an FET driver can. It’s a trade-off.
Thank you for your feedback! Our SP31V2, SP35, SC21 and SF47T are placed with buck drivers. the new products SP33S (up to 5000LM) and C8L (thrower) will come out with buck drivers too.
Thanks for an excellent review! I realize this thread began a while back but I hope you can help. I have an if22A on order from aliex and want to order a suitable holster that will protect the body as well as the lens. I keep finding differing dimensions online. I suppose some of that may be due to the different dimensions of the IF22 and the IF22A. I see you list one set of dimensions, but don’t specify whether for the IF22 or IF22A.
i hope either you or someone will let me know the true dimensions for the IF22A.
I also need to find a holster that fits well and protects the entire light including lens. So far my searches (sofirn site, aliex, banggood, scamazon) has come up empty.
