Emisar D3AA is available now
Any predicted release date?
PLEASE tell me that anodization color is GREEN :))
such a CLEAN look! Take my money Hank
Bhahaha
Looks great from that end. Now we need a full body shot :smiley:
I love my D4v2 and I have the 18350 tube for it. To make it even smaller I’d reduce the head diameter to match the body diameter. Next thing after that would be go to 16650/16340 format. I’m not keen on the 14500 concept unless it’s dual fuel and tiny. And I think that doesn’t fit in with Hank’s general approach of making lights super powerful. I guess we will see.
I’m hoping for this new 21700 thrower to also offer a quad version with the D4S optic and tail e switch. That’s been my fantasy hank light for a while now. Putting the LEDs in series and running them off a boost driver would be icing on the cake, but 1S linear driver is fine too.
Yep, head option for single and quad would be great.
While I’m guessing, will this new light have an M in the name?
He does have it in the dm11 directory, so that’s probably its name.
Hank can you please use the 90+ CRI version for XHP35. I know it might sacrifice some lumens but quality CRI over anything would be much appreciated over minimal output increase. We would pay a few bucks more to get the best emitter.
What is the believed advantage over the B35AM?
Also would like to know the lumen to candela ratio with the nichia B35AM?
Lm/mm² for the 70CRI versions at peak output (data from eurekatronix and koef3 data)
B35 - 320
XHP35 HI - 475
Assuming the same relative outputs for hiCRI, XHP may out throw the Nichia by a factor of 1.5:1 in terms of cd/lm.
Throw distance would be something like 1.2:1 in m/lm
Looks awesome! I’m really excited for this light, it seems to have an excellent blend of features. In particular AUX under the large optic is really cool!
Sorry if it’s been stated already, but what kind of performance should we expect? With this size optic and an XHP35, what sort of intensity will it be able to produce?
Just spoke to Hank via email about B35 and he confirmed B35AM will be used instead of AR.
Good choice, lots of CCT available with AM.
I have them in sw30,35,40,45,50,57 & 65. All looking great and what’s most important, R9080 :-)
Cool white xhp35 around 75kcd and sst40 in the 60kcd range, b35am around 30kcd, sft40 around 100kcd.
Note that these are conservative figures and could be (likely) 30% higher, but ratios should be roughly accurate.
Hank, have you given any thought to GT-FC40 LED, either in this host or any others? Really want that LED in an Emisar/Noctigon product!
The throw could be a bit lower than expected for the XHP35 and B35AM versions, since in order to eliminate the black hole,
we use slightly frosted optic. Other LEDs versions like Osram, SFT40 stilll use the small angle optic in order to reach longer throw.
And may the post count multiply :partying_face:
Thanks for the picture and feedback on figures. Looking forward to this one!
