Maybe Sofirn could pull it off better than Lumintop did. Seems like a lot of moving parts just to get a tail E switch though. It would be nice if Sofirn made a slick little 18650 light under 100mm long with charging.
Probably not. The shortest 18650 lights I got are the MH20s (there are some shorter ones, but not by much), but it’s a side-clicky. Any tailcap-with-switch eats way too much length with the movable parts and spring.
You’re almost at 7cm just with the cell and contacts. Add springs at both ends, make allowances for protected cells and even button-tops, and it’s even more. Even a shallow TIR is at least 1cm high. Add a pillar/shelf for the LED+pcb, a driver, etc., and it’s a tight fit.
The MH20 gets away with some length-trimming because it needs button-top cells, as the contact patch on the driver is just a shallow Au-plated button, not a spring, so that’s only a few mm vs lots more for a compressed spring at the driver.
I think some Folomovs were just a few mm shorter, but can’t recall details.
Doesn’t stop people from bitching about it. They want 5000lm “sustainable” turbo from something the size of an S2+ while staying cool to the touch, and having 3hr runtime at those levels, too. Oh, let’s not forget massive throw from such a small reflector, with “usable spill”. :person_facepalming:
I’d prefer side switch. Wowtac has one, A6. Shorten the SC31pro tail cap and make it a TIR. A6 is 98.5mm long, sustains 400 lumens. I know you can do it. :+1:
pennzy, right on! I too would love to see Sofirn develop a “slick little 18650 light under 100mm long” based on the SC31 series.
I love my Wowtac A6 for it’s diminutive size with 18650, but it has a few shortcomings. I would more love a SC31 in A6 size!
My complaints with the A6 are the switch is way too small, no Anduril, and they don’t drive the LED’s hard enough.
You can milk an SST40 for 1700lm +, A6 only does 1200.
I also got a Thrunite T1 (XHP50.2) to use the head on the A6…but again under driven.
At 1500lm its no slouch, I guess you wouldn’t want to drive it to the max in such a small light but they can certainly squeeze more out of it
At least it has ramping (A6 does not) I’m using the T1 head on the A6 tube (18650) and the A6 head on the T1 tube (18350)
