9000 Lumen Flashlight or 1100M Long Range Thrower
I have been using SF47 and SF47T for a while. These two are very impressive for me. I would like to say SF47 is one of the brightest, most powerful flashlight and SF47T is one of the most powerful thrower.
Item
SF47
SF47T
Emitter
4 * 6500K SST40 (20W)
1* Osram LED (25W)
Lumen Output
9000LM
1500LM
Beam Distance
522m
1100m
Battery
2 * 21700 batteries
2 * 21700 batteries
Charge
Battery charger
Battery charger
Size
208mm (length) × 48mm (head diameter)
247.5mm (length) × 55mm (head diameter)
Weight
248 grams (without batteries)
315 grams (without battery)
Form Factor
High Lumen, long working time
Long-distance beamshot, long working time, tail switch
SF47 which can pop up 9000 lumen, reach 522m. and sustain pretty decent of time. 9000 lumen for maximum output, you will get 495m for beam distance obviously this is going to be very flood light. It is a great tool to help light everything around you.
SF47T is a long range thrower. It can light up things out of 1100m and has incredible working time. It features two switch buttons, tail switch to turn ON/OFF, side switch to cycle through modes. If you are looking for a slim and portable thrower flashlight for camping, and security, SF47T is a good choice for you.
ANSI/NEMA FL1 Chart
SF47
SF47T
As Picture Shows, SF47 is shorter than SF47T. SF47 delivers a different hand-feel from SF47T. SF47 features good weight distribution, when I held it, I felt the whole body was steady and balanced. While I held SF47T, I felt that its head was a bit heavier than its tail since its deeper reflector. SF47T utilizes deeper reflector helping give that slight edge for throw.
Emitters
SF47
SF47T
Pictures explain their differences. One difference doesn’t show clearly in the picture is their switch.
SF47: Side Switch
SF47T: Side Switch + Tail Switch
Which one do you like, long-ranger thrower or high output flood flashlight? Anything you want know or any suggestion for improvement?
Hmmm, the emitter in that T version does not seem to be the same sst40 as the non t?
How about using the SFT40 instead of SST40 for much better throw.
1100m my ass…
Put a match box 1100m away and make a picture when illuminated.
That’s an OSRAM Boost HX in the SF47T, not sst40. Sst40 can not throw 1100 meters, not even if you fill the batteries with unicorn pee. You should put the SFT40-W in there instead.
9000 lumen turbo. Great!
But how many lumem can hold at room temlerature?
It is written in the specs - 1000 lumen.
No, thanks. Any single XHP70.2 with similar host can hold at least 1400 lumen.
Interesting comparison.
To get both 9000 lm and 1100 throw you need a much bigger light (and wallet!)
Although these are pretty close:
wall beam shot pictures
SF47T
SF47
Sorry, i made a mistake there. my bad. SF47T uses Osram 25W LED
Right, OSRAM Boost HX in the SF47T not sst40!
SF47 Review
https://www.youtube.com/watch?v=fHMZtUpF_CY
