I don't even know what you said here, but it's exciting! Lol. And yea I'll sacrifice lower range anyday on a large thrower for regulated top end and no fear of burning out my led.
this may be a dumb question- but here it goes. I thought I have seen you "piggyback" a driver before. If I'm not mistaken, you strip away components from the original driver, and then run leads to a new, smaller driver that has the regulation/UI/etc that you need for the light, and solely keep the original driver "shell" / pcb for its size and fitment.
I imagine you need space in the head to do this, but could something like this be done with say the noctigon K1 driver? Or better yet, a kr4 9amp A2 driver? Because it's cheaper to buy. Because that'd be awesome.
A 9A K1 driver piggy backed actually sounds like a great idea. Would still recommend low amp cells to keep the heat down since you lose your thermal path doing this
Even then unless you add some thermal compound, maybe silicone potting to increase thermal dissipation to the original driver/host I think the piggybacked linear driver will step down too fast, before the host is hot, depending on the output level.
See this graph with an SST-40 and 50mΊ of non driver stuff (springs, wires, cell), which is kind of a high number for four cells in parallel, even if they really low CDR.
2~3W is a lot for a board without thermal path to the host.
Hhmm, I got some high amp lights piggybacked. I always run 2-4 jumpers for ground to the piggybacked driver though - I'm thinking it helps, never proven though. Dunno - on some stock drivers, there isn't a whole of contact surface to the shell, so I' not sure the way I piggyback is much worse.
Here's an Amutorch X9, triple XHP50.2 3V hand burner" that I measured 30.7 amps with a GOLISI 26650, about 10,000 lumens at start:
Yeah, but it didnât take me too long, I just placed the components quickly, itâs pretty easy since there is a lot of space, I used 46mm but Iâm not even sure what the actual size is ?
Something even better would be a buck driver, especially since the original carrier is 4S ? For high efficiency and full current for the whole battery range, but thatâs more complicated of course.
46 mm is about perfect! I measured 45.6 mm for TA's driver for the GT90, and 45.75 mm for the TA MT09R driver and both fit loosely, so 46 mm is actually better.
The GT drivers has a big (wide) brass button while the MT09R driver has a spring. As long as you have a wide enough pad on the spring side, the brass button can be transferred.
I put a 12mm batt+ pad and the GND ring is 4mm wide, are these sizes okay ?
I can put it up on OshPark, though youâll have to wait for Gchartâs DAC implementation.
You got the dims exactly matching - the 12 mm batt+ pad and the 4 mm GND ring - matches the TA GT90 driver perfectly. The MT09R driver is also 12 mm batt+ pad and a 3.5 mm GND ring.
