Yeah, I understand, and that's a common complaint.
I got used to the "double click for on" almost immediately, and because the flashlight has an electronic switch, the double click makes it so that the flashlight doesn't accidentally turn on in my pocket like my FW3A does.
Nice review RC, good to hear your opinion on this light, I believe most of us either bought one or is thinking about it (I’m definitely thinking), I think they have one of the most beautiful design on the market, I too would like to see it in green and other colors but this shade of blue sure is beautiful in pictures.
Please update us after some time of EDC, it would be great to know how it handles daily use
Thanks again
RC, how do you find the beam profile outdoors? For me, the XHP70 is extremely floody. I have a ZL SC700d, which uses a larger reflector with its XHP70. For me, that seems about as floody as I would want the beam profile in order for it to be useful outdoors.
Aesthetically, the light is super appealing. If it were me, though, I’d do the Ti version, but with 14500 and something more reasonable for the LED (SFT40 or SST20) or aluminum in 18650 with, again, something a lot throwier than XHP70. The reason I suggest Ti in 14500 is both cost and heat - Titanium lights generally can’t even handle 18650-tier heat outputs, I don’t know who they’re kidding driving an XHP70 hard in a Ti light.
FET drivers have high initial output, heat and battery drain. Brightness drops steadily as the battery drains. Regulated lights put out a constant brightness until the battery voltage drops to about 3.7 volts on high and then usually steps down to a constant medium level until about 2.8 or 3 volts.
