I'm not sure, but it seems pretty floody.
Nice review, thanks.
For some reason this light seems too big in my opinion.
I think it's a reasonably compact 21700 flashlight.
If that's too big, and maybe it is, then stick to compact 18650 flashlights.
stephenk:Quick question - what is the angle of the spill beam?
I’m not sure, but it seems pretty floody.
Can you put it up against a wall and measure the angle please?
I'm not going to do that, but maybe someone else will.
pennzy:Is it regulated? Got enough DD lights.
Sorry, newb question here.
Is regulated simply the opposite of direct drive?
Or would regulated refer to a number of different methods that arent direct drive?Edit: Is regulated synonymous with current controlled?
FET drivers have high initial output, heat and battery drain. Brightness drops steadily as the battery drains. Regulated lights put out a constant brightness until the battery voltage drops to about 3.7 volts on high and then usually steps down to a constant medium level until about 2.8 or 3 volts.
CRC: pennzy:Is it regulated? Got enough DD lights.
Most regulated lights will still have thermal regulation though, so only put out a constant brightness after thermal regulation has balanced.
This is a nice light. It’s like 20x better than a convoy. Worth the money IMHO.
I think I’ll get one. Similar performance to the Convoy M21C/D, more compact, and looks amazing.
Is it regulated? Got enough DD lights. Holly molly, Amazon wants 95 bucks. No thanks.
It’s a boost driver. 6V for XHP70.2; 12V for GT-FC40.
pennzy:Is it regulated? Got enough DD lights. Holly molly, Amazon wants 95 bucks. No thanks.
Ah yes, XHP70.2 6volt. How’d I miss that. Thanks.
Stephenk, the hotspot is 23.7° and the spill is 84.9°
Thanks, LuxWad!
I'm glad you figured it out.
Thanks for the info. I’ve ordered one. Sustained brightness for size is very impressive.
I love this light!
I really like your review style RC!
Short and to the point and if i didnt own it this would be the review id want to read. I dont need 2,000 words when 200 will do!
I have aluminum gt fc40 3000k and a Stainless Steel xhp70 4000k. and i love them both equally.
There was a post on reddit to the effect that acebeam were working on a smaller form factor of the E70
Rayoui: pennzy:Is it regulated? Got enough DD lights. Holly molly, Amazon wants 95 bucks. No thanks.
If you see a flashlight with these LED’s, is it safe to assume the light must be using a boost driver?
I am not an expert by any stretch but if it is a single cell light the answer is yes. If it were a 2 series cell light it would be a buck driver. Anyone please correct me if I am wrong.
Yes, XHP70.2 can be wired in 6v or 12v configuration. GT-FC40 is always 12v. If it’s a single cell, it has a boost driver.
Two series cells for XHP70.2 could be buck, linear or even direct drive if wired in 6v. Most XHP70.2 lights I’ve seen are set up for 6v operation.
I updated this review.
Most importantly I added to the very beginning, "The flashlight images in this review are from Acebeam, and the images are being used with Acebeam's explicit permission."
