REVIEW: Wurkkos TS21 (SST 4000K ...Anduril 1) - An Excellent Budget Enthusiast Light
7 posts / 0 new
LuxWad
LuxWad's picture
Last seen: 16 min 13 sec ago
This review is for the Anduril 1 version of the light, which has been superseded by a newer version offering Anduril 2 and powerbank functionality:
https://wurkkos.com/products/wurkkos-ts21-new-color-metal-gray-and-champ...
So you guys have all seen several (great) reviews of this light already, I’ll just share some thoughts and opinions in this written portion here.
First, test results (all done with the included 5,000mAh cell):
Wurkkos TS21 (SST20 4000K) Review – Test Results
!https://imgur.com/UJsbSKy
!https://imgur.com/sXVKx6h
!https://imgur.com/iKgq658
!https://imgur.com/ycZhSDE
!https://imgur.com/NV8Ow4D
!https://imgur.com/99uZlYO
!https://imgur.com/Lk4UpeG
Turbo Max Output (Startup): 2,237 Lumens
High (Default Ceiling): 1,096 Lumens
Max Regulated Level: 126 Lumens
1/150: 0.24 Lumens
cd/lumen: 3.7 (8,277 max cd)
AUX LED current draw:
High: 3 mA
Low: 0.08 mA
Off: 0.03 mA
Moonlight (1/150) Current Draw: 2 mA
One of the most talked-about issues with this light is the thermal step-down. It is very aggressive, and I tested four different target temps (configurable in the UI): 45C, 50C, and 55C.
Note that in the graph, 50C actually performed a bit worse than 45C, which I suspect is due to ambient temperatures, as I don’t have a very well-controlled environment… as always, my measurements are not super accurate, so take them for what they’re worth.
I found that 60C made for a significant improvement, and while normally I would not set my lights this high, I don’t find it to be a problem here – it still steps down quickly enough that it doesn’t get too hot to hold.
This light uses the 4000K 95CRI SST20s, which I think are the perfect match for value, performacne and color rendering. They’re not the most accurate, but I still find them very pleasant to use.
Even better, the TS21 uses a custom optic (as confirmed to me by Wurkkos) which provides a very clean and very nicely-shaped beam. This is my favorite part of the TS21, the actual light quality is very nice and highly functional.
Pros:
  1. CHEAP
  1. Excellent beam quality
  1. Anduril!
  1. 21700!
  1. USB C charging port (with a great cover!)
  1. AUX lights in the switch
  1. Small enough to carry with ease
Cons:
  1. Sharp thermal stepdown
  1. No flashing pads Sad
  1. Mediocre efficiency
My thoughts:
The TS21 is a fantastic budget option for those looking to get into enthusiast light, those interested in Anduril, and/or those wanting a very functional light with all the fun featrues. It also makes a great gift for flashlight nerds. It comes very highly recommended from me.
Note that Wurkkos did send this light (free of charge) for review, at my request. All test results and opinions are my own. Thanks for reading/watching!
My Review Channel - https://www.youtube.com/luxwad
Edited by: LuxWad on 10/12/2021 - 22:01
how crazy is this
Last seen: 9 hours 41 min ago
Thank you for the great review and charts! Nice to see some objective info to clarify what my experience has been. Great job of explaining the thermal management.
In another thread I said that the ATR worked great for me and it does as a toy. As a tool I think it is important to note that it can definitely be an issue as if the light is needed for more than a few minutes the ATR can drop the output to a level that affects its usefulness as a tool. You did a nice job of demonstrating that by upping the max the output sustained is much more useful as a tool. I think there is also an output level where the light will maintain higher lumen due to the ability of the ATR. Perhaps one or 2 steps down from top of ramp?
I noticed that my SC31 Pro with Andruil seems to have a much less aggressive ATR. Did not occur to me that this is just the manifestation of your con 3. The SST 20 4000k is my favorite emitter. Efficient it is not;-( Don’t much care for the 6500k SST 40 but it is much more efficient and you can certainly see it in the difference in the ATR.
Seems to me that there must be a point on any light that say you set the temp to 60c, for a given emitter, you should be able to maintain a certain amount of lumen. Sustained output? Thermal limit of the light? In other words if you put 3 Amps of heat into it the light can dissipate 3 Amps and maintain the 60c. Whatever that number is for a particular light and DTP, that would be a very useful thing to know. How many amps can a given light dissipate at a reference temp? Unfortunately, this is where the wonderful sst 20 would not fare too well. The rather ugly sst 40 would be able to sustain about 2x the lumen while dissipating the same amount of heat.
What is the max regulated level? Can one set it?
LuxWad
LuxWad's picture
Glad you liked the review!
I’m not sure if this is true, my understanding is tha Turbo actually lasts longer relative to the amount of heat produced, since the heat is generated by the LEDs instead of the components (as a reuslt of direct drive), and the temp sensor takes longer to heat up as a result. Any lower than 150/150 and the compenents would take more of the current and will produce more heat.
Yes the efficiency definitely makes a difference. It is also worth noting that the SC31 Pro has just a single emitter, so efficiency aside, it’s not really capable of putting out as much heat as a triple like the TS21.
It definitely would be useful to have a standardized number like this, it’s a great idea. We have lumens and candela, it would be nice if we had a number that would tell us total heat dissapation at a current draw – there must be something like this already I feel, but I don’t recall seeing it in the flashlight world. This would of course change with the emitters/components as you say.
The maximum regulated level is limited to the highest amount of current regulation provided by the onboard 7135 chip, which is rated for 350 mA, so it can’t be adjusted. Anything above 350 mA (126 lumens on this light) will be more current than the 7135 is designed for, so the FET will be used to provide more current for higher outputs – which is much less efficient.
Wurkkos
Wurkkos's picture
Last seen: 2 hours 30 min ago
Thanks a lot for the review
zoulas
zoulas's picture
Last seen: 2 hours 18 min ago
The TS21 is a must have. Great review.
zoulas
zoulas's picture
Waiting on new color releases.
LuxWad
LuxWad's picture
Thanks for making such a great light, and for sending it along!
I would love to see the purple color from the FC12. The champagne on the updated version looks very nice too
