New xhp50 with small but deep reflector, pcoketfriendly
I own some xhp50 lights, some pocket friendly, some don’t.
I own a gt mini with xhp50 but the head is too big in diameter. A sofirn sp33 v2 and 3 and sd05 and a olight seeker?! With xhp50.
I search a light in size of a wurkkos ts21 or as small as it need to be. 18650 and 21700 is fine. Cw and nw, warm white is nothing i want or need.
I need throw and a small diameter head, so a deep reflector. Any suggestions?
XHP50 is not what you want for throw. My favorite recommendation for a small thrower is a Convoy M2 with CSLNM1.
Higher lumens and less throw from something like a Wurkkos FC12 using SFT40. Convoy S21B with Osrams are another compact throw option.
Yeah i don’t like the wurkkos, too long. And yes i want a xhp50 with throw. I know it works, like in the gt mini with xhp50
Alrighty then. You could try the fw1a pro FW1A Pro - Lumintop with a whopping 11 kcd peak throw for a few seconds…
Yes, M2 ^
Yeah read zeroairs review about the fw1a pro, not really appealing
The throw is more correlated with reflector diameter than reflector height. To increase throw you need bigger reflector diameter or smaller emitting surface.
I want a max 42mm diameter at the head
Convoy M21B with XHP50.2.
Astolux EA01, although not a extreme thrower, it is pretty good. The XHP50.2 in the TIR produces a very good smooth beam with a decent amount of throw.
Thrunite t1
How about a Mateminco MT35mini-S with the 18350 tube?
Right: Lumintop GT Micro
Middle: mini-S with 18350 tube
Left: Mini-S with 18650 tube
