I would like a code please.
May I have a code, please?
I’d like a code. Thanks.
I’d like a code. Please and thank you!
Code please
Might as well. I’ll take one too, thanks!
Please send the code - thank you, Sofirn.
I’d like a code. Please!
Hello, I would like a code as well for the IF22A. Thanks!
I’d like a code please
Cuz the stock is limitied, so the codes will be delayed to send to you, thanks for your patience. I’ll send the code to above who had leave a comment. Thanks for your patience again.
Same here. I need a new code. Someone else must have used the code before I could. :rage:
Looks like I’m late, but if there’s still one available I’d like a code please.
Too late?
I’ll take a code if there is still one available. Thanks!
Sofirn,
I would like a discount code for IF22A Silver, to order from your Sofirn Official Store.
Does sofirm have USA stock of this item? Need link please
Received my IF22A - the battery charge level indicator is not working properly. It shows steady red, right after fully charging the battery inside the flashlight for several hours and turning the light on. I know the green LED works, as it shines green after fulling charging the light. I’ve fully tightened all of the connections - it is still steady red when I turn on the light. I’ve also tried opening up the light and removing the battery, then re-inserting it. Looks like this light will need to be returned to the seller. I’m very disappointed, as it seems like a great light, other than that problem.
