Astrolux have just listed a light with the SFS80 LED:
Astrolux® A03 SFS80 LED 800LM Powerful 14500/AA
I ordered a P35 3v 4000k emitter and a P70 6v 6500k emitter today from Kaidoman with my other leds. Looking forward to both! they both look domeless, hoping the P35 competes with the sft40 but in 4000k!
Thinking of ordering one w/SFN55.2. I'll ask Neal for his best deal, and if it's in stock.
Do you still like/recommend it?
Definitely. It’s one of the more well-rounded lights in my collection. It’s only missing a buck+FET to make it spectacular. I mean a sub 60 mm reflector that throws over 700 m with a huge 7070 LED and 7000 lumens? Oh yah. Nothing else with a single LED and battery comes close. Plus PD charging and power bank sweetens the deal.
Just ordered the Astrolux ft03 mini with sfs80 claimed 1650lm & 720m throw! Sounds like a brighter CULPM1 to me!
My green OSRAM version of the FT03 mini does 910 meters, though at 900 lumens. Does the 720m compare well with a Boost HX? The Boost HX is still expensive as well.
My 4000K versions of SFS80 couldn’t sustain 8A. Two burned immediately and on a third one phosphor first bubbled and then fall off during routine reflow.
unfortunately I never put the HX in the FTO three mini, but you're right I think it would be more like 900 m going off of what the numbers are for a c8. I also have a p35 coming from kaidomam.com, Going to see how that does this too but I think that might be the same or better better
Not entirely sure these belong in this thread - But i just received the "P70" 6500k (6volt i believe), and the "P35" 4000k 80CRI (3volt !) from kaidoman.com :)) here are a couple quick pics, still figuring out which lights i want to throw these in. Bth of them are domeless HI versions.
Thinking a Emisar D1 for the p35 4000k (i have a couple D1 now and have been looking for a led to put in one). and thinking the Convoy M21e for the P70. Any thoughts?
*EDIT: its "too bad" (my own fault) I just sold my acebeam e70 xhp70 version, would've liked to seen this P70 in that little guy!
Not entirely sure these belong in this thread - But i just received the “P70” 6500k (6volt i believe), and the “P35” 4000k 80CRI (3volt !) from kaidoman.com :laughing:
The listing for the P35 says
Custom P35 HI White 6500K LED (SFS80) /
Custom P35 HI Neutral White 4000K CIRI80 LED (SFS80)
So they appear to be from the same manufacturer.
http://kaidomain.com/Custom-P35-HI-3V-8000mA-1800-Lumens-LED
The P70 doesn’t give much information but I assume it’s one of the others.
Interested to see how they perform.
P35 4000K’s seem to be quite fragile. I have one in Convoy S2+ with 5A driver and it works fine. I tried to build Convoy thrower with 8A driver and I burned two of them. During reflow the phosphor has started to bubble few times and then it peels off. Now I know that you have to be extra careful with them.
It’s best to test with a power supply the threshold of any LED. Had a surprise with CULPM1.TG from Yinding. Angry blue at 8 Amps, toned it down to about 6 ½ A.
Yeah, I thought I didn’t even push it hard with 8A. That is what Kaidomain’s specs said it should withstand. Seems like at least the 4000K version doesn’t.
Bummer to burn out a led. But this adds to the mystery of why some of my Yindings work at 8 A while others are screaming in pain. Poor QC?
thanks for info guys. i will be careful reflowing. i had major issues with (2) xpl-hi 2850k while reflowing recently, that one seems fragile, more so than any other xpl-hi I've reflowed, unless it was a bad batch (bought a couple months ago from Hank).
-> major issues where the top layer delaminating from the base. never saw that before, i didn't heat up hotplate anymore than normal. It sucked. The white base seemed weak and chipped too.
I wouldnt try putting 8amps through a 3535 led anyway, unless i knew it was capable, but since i know nothing about the P35 i will keep it around 6a, thanks for that info!
Think im gong to try it in a m21c, 6amp driver
Apologies Dave1010, didn't even notice it said (sfs80) in the P35 description...
Astrolux now have the FT03 Mini with SFS80
For comparison, specs for the same host, from throwy LED to floody LED:
Would be interesting to see how it compares to an Osram W2/Boost HX, CREE XHP35 and Luminus SFT40/SFT70.
Got this in from Neal, no doc on it. XHP70.2, MT-G2, and the BIG LED, SFH55:
16 LED's in one?
Same dims but the dye surface sure looks tiny on that SBT90.2:
So from that previous list of LED's, which one could it possibly be? Only one possible, the SFH55
Link to list again: http://tiebapic.baidu.com/forum/pic/item/aebad3ca7bcb0a466cff57807c63f6246a60af70.jpg
It's truly a 3 volt LED. Just lit it up under 3V with about 1 amp max on a bench PS, but was unmounted so didn't want to crank it up.
I measure roughly 36mm². That list seems to have a bunch of inaccurate LES measurements.
I have to go to bed, so truth be known, it's the SFH55, really the only thing it could be from that list.
Plan is it to mount it in a WT90, should be an easy swap, and with 3 30T's powering it, should be able to get some decent output out of it. Also can compare the throw with a SBT90.2 driven hard.
