So far I’ve only experimented quickly with unscrewing the bezel and tuning it maglite style. The plan is to punch out round discs of aluminum tape to build up the mcpcb around the emitter. Thinner tape for fine tuning after that or sanding the spacer.
It looks like yours is underperforming. I measured with the stock gasket at 20m and got 365kcd
I know that measuring a thrower like this at 9m it’s roughly 100m less
To check my lux meter I compared it to the 1Lumen review of the Maxtoch L3K, I reviewed the same flashlight. I got 2,900m,1Lumen got over 2,700, which if their meter is correct then mine is 5% too high. That would still make it 346kcd
Just curious, I tried to compare 2 units of the L21B with SFT40.
I notice one has a slightly smaller corona but a slightly larger hotspot,
whereas the other unit has a slightly larger corona but a slightly smaller hotspot.
(Tried to take picture of it, but my camera is unable to capture it properly; although this can be observed with the naked eye when I point the 2 units on the ceiling, at slightly lower brightness levels so it’s not too glaring)
Any idea, which one of them will have a farther beam distance? (hard to tell just by doing side-by-side naked eye observation)
Thus: is the one with the smaller hotspot more throwy or the one with the larger hotspot more throwy?
(conventional thinking indicates smaller hotspot likely a bit more throwy, but in this case, it seems that having a (just slightly) larger hotspot might result in slightly more throw = which seems to match what you stated)
It’s less about the size of the hotspot, but rather minimizing the relative size of the corona. So the first one you mentioned likely throws farther but definitely is in better focus.
Swapped the sft40 from the L21B into another light. Now I’m running a Cree XPP and replaced the the R010 with two R056, so the current should be around 2.85A (will confirm later).
With the 30T @ 3.8V, I was seeing 305kcd. Cell is charging and I’ll get more measurements later.
I chose the small 1.1mm² emitter so that I could better characterize this reflector. With the SFT, I was seeing no meaningful change in lux values @ 5m when raising the reflector from ~0.5 to 0.9 mm. The emitter was being too forgiving to nail the focus height… with the XPP, I think I perfected it. Using the stock 3535 9mm gasket (0.59mm) with a 3535 ‘butterfly’ gasket sanded lightly to 0.79mm, the corona has the sharpest ‘petals’ and highest center beam cd. The butterfly gasket also helps center the emitter since the convoy 3535 gasket is a bit loose around the emitter.
The XPP is 0.75mm tall, 4040 NM1 measured 0.80mm, SFT40 was 1.10mm.
The base of the reflector should then be 0.63 above the LES.
With the SFT40 and supplied 5050 9mm gasket which comes in at 1.06mm tall, then we should space up an additional 0.67mm.
I have some oval base 5050 gasket that is 0.66 thick, and by dumb luck, that’s what I tried first to space the reflector when I first started messing with it.
I tried mine, only got 57 meters, and the stupid thing broke when it landed. Tried my c8+ and got 62 meters and it broke too. All these people talking a thousand meters are full of it. Dont believe a word they say.
The focus needs adjusting by increasing the reflector height by 0.3mm. The focus was much worse upon release, but after my input another gasket was made, only for it to be wrong. Not sure if Simon gave the factory the wrong dimensions or the factory screwed it up. Thankfully my instructions were followed for the 4040 gasket. Another gasket is being made for the 3030.
I measured 250m less with a CSLNM1 3030 gasket, than using my own gasket. The very first L21B gasket performed worse than the C8+
Buy two of the original 3030 gaskets and sand one down, removing the risen edge that the reflector sits on. Sand it flush or till 0.5-0.6mm and glue both together
0.5 + 0.6 = 1.1mm. 1.2mm gets a tiny bit more, but easiest is just the 1.1mm.
The height of the gasket is 0.6mm where the reflector sits. Just so you know where the 0.6 above came from
Thanks for the confirmation.
(I was suspecting this but was unable to test more precisely to note the difference)
Also, while my eyes can see the “hotspot” and “corona”, I can’t seem to get that image taken with the camera, even when adjusting settings manually (I’m no expert in camera adjustment settings though, so maybe there are settings that can allow a camera to take a better picture of the hotspot/corona thing…
Ideally you want to reduce the corona for better throw and the 2nd photo looks larger. It certainly made the hotspot look nicer, but who knows whether it was correctly centered to begin with.
Easy way to try is to unscrew the pill a little at a time and see what happens
I tried 3D printing a centering ring for my L21B NM1 since the original one was a bit loose around the LED and was constantly losing its centering.
I admit it’s not the cleanest. On the one hand using a circular hole for the LED might be better to avoid torquing the emitter while tightening the bezel, but on the other hand the square hole seems easier to center if the dimensions aren’t perfect.
I used 1.2mm like above for the gasket thickness. Unfortunately I didn’t do before/after measurements, but the corona looks nicer and it was much easier to center when reassembling, compared to the original gasket. Hopefully it holds up to the heat of the LED, it’s only PLA plastic so it may not be ideal.
By the way, did you ever get around to tuning the gasket thickness for the S2+? Does a thicker gasket improve the throw?
You should get a decent bump in range at 1.2mm. I never bothered to try any further tuning of the S2+ , I had no reason to since I doubt Simon would bother and I don’t have an S2+ of my own, they’re all for sale and I certainly don’t want to make a custom gasket for those, takes too much work without a 3D printer
